oil reset - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 05-27-2004, 08:03 PM
terry325xiwagon terry325xiwagon is offline
Go MSU
Mein Auto: 325xiT
oil reset
What resets maintenance computer for oil change intervals? Taking off the filter or do the service guys reset it manually? Those who take off the oil filter before 15k first oil change keep wanting to reset computer. I'm trying to figure out why.
Old 05-27-2004, 08:19 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
1. It's not automatic. It needs to be connected to the dealer computer or you need to go through a key sequence.
2. What are you trying to ask?
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 05-28-2004, 12:41 PM
Go MSU
Mein Auto: 325xiT
If I change my oil and filter myself before first oil change (15k service), can BMW service center tell its been changed. Would it be free at 15k?
Old 05-28-2004, 12:56 PM
SergioK's Avatar
SergioK SergioK is offline
Donkeybike?
Mein Auto: HP2Sport - R1200GS - F30
The dealer most likely won't know you changed it yourself unless you put in something other than an OEM oil filter / oil.
Don't reset the count down inbetween the 15k services. I simply change my oil when it says 7500 miles to go, then again when it's at zero.
Old 05-28-2004, 03:23 PM
operknockity's Avatar
operknockity operknockity is offline
My TARDIS is a BMW
Mein Auto: '02 325i
While under maintenance, all the scheduled (eg every 15K) oil changes are free. If you want to change the oil more frequently, then the additional oil changes are on your dime, whether you do them yourself or have the dealer do them.
How many posts could a repost post if a repost could post posts?
Old 08-25-2004, 09:10 PM
jayf jayf is offline
Mein Auto: 2002 m3c
how to reset
I am out of warranty on my 02 m3. I did my first oil change and needed to reset the oil service indicator. There is some sequence of pressing and holding buttons on the dash to reset. Does anyone know the sequence. I hate to pay my dealer for an oil change just to reset the indicator
Old 08-25-2004, 09:20 PM
BahnBaum's Avatar
BahnBaum BahnBaum is offline
Empowered Consumer
Mein Auto: 1 - 4.20hp, 1 - 420hp
On my e30, I reset my oil service indicator by jumping two connections in the service plug.
I found a similar diy for the e36: http://www.unofficialbmw.com/e36/ele...ce_lights.html
I found this on roadfly to reset the e46 (I haven't tried it, so don't know if it works): Press and hold the trip meter button and turn the ignition key to accessory position. Hold for 5 secs until you see "Reset" appear. Release and immediately press and hold again for another 5 secs until "Reset" flashes. Release and press again and the service counter should read a little over 15k miles.
Alex
Old 08-27-2004, 08:34 AM
Mein Auto: 2002 m3c
Alex
Thanks, Alex: I think that works for my car. I watched the SA do it once but he would not tell me what he was doing
Old 08-27-2004, 12:17 PM
BahnBaum's Avatar
Empowered Consumer
Let us know if it works!
Alex
Old 08-27-2004, 12:45 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
That sequence I believe only works on E46s after the deletion of the DLC (SOP 09/00). I've never tried it on an earlier one. The earliest car I've done it on was a 03/01 M3 about 3 weeks ago. The display actually blinks 'Re' not 'Reset.'
Old 08-28-2004, 08:19 AM
Plaz's Avatar
Plaz Plaz is offline
Mein Auto: '11 1M;'08 MCS;'02 325iT
Originally Posted by Kaz
That sequence I believe only works on E46s after the deletion of the DLC (SOP 09/04). I've never tried it on an earlier one. The earliest car I've done it on was a 03/01 M3 about 3 weeks ago. The display actually blinks 'Re' not 'Reset.'
It just worked on my '02 330i.
2011 1M
2008 MCS
2002 325iT
Old 08-28-2004, 11:48 AM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Oops, I meant SOP 09/00. 330s between 06/00 and then had the DLC, so I'm not sure if you need to use the DLC and reset tool or if the key sequence works.
Old 08-29-2004, 11:23 AM
SergioK's Avatar
Donkeybike?
What's DLC (SOP 09/00)?
Old 11-19-2004, 08:39 PM
Mein Auto: 2002 m3c
sequence worked on my '02 m3
the sequence worked on my '02 m3. My buddy did it on his "01 m3 and it also worked. Thanx
Old 11-20-2004, 04:35 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Nobody pointed out, that if you reset the indicator for an in between oil change, your dealer may give you a hassle about changing it when it is due since the service indicator will not agree.
Also, for low mileage people, you get a free oil chane 1 year after the last oil change, even if you haven't driven enough miles yet. The SI si NOT rest for these annual oil changes, and you still get one when it is due by the SI. The deal is, if SI is expected to roll over within 60 days of the 1 year mark, the do the oil SERVICE and reset the counter.
On some models there is a difference between an oil SERVICE and an oil CHANGE. Details are in your Warranty and Service manual.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-16-2004, 05:54 PM
Poison Rice Poison Rice is offline
Tchao
Mein Auto: e30
Wow, you guys change your oil at every 15,000 miles? Or is it Kilometers?
"Custom can never be beat"
Old 12-16-2004, 10:16 PM
My TARDIS is a BMW
Mein Auto: '02 325i
Old 11-06-2005, 08:02 PM
Lanc3r Lanc3r is offline
Banned
Mein Auto:
Sequence worked for my 2000 323.
Also completed my first DIY oil change on the E46. It wasnt so bad, except when I was trying to figure out what 25 Nm means in ft lbs, as my torque wrench has a wierd Nm scale on the back and 25 Nm = 120+ ft lbs. I knew that couldnt be right and figured it to be about 18.5 ft lbs. That seemed to work. No leaks.
Old 11-08-2005, 05:33 PM
Pinecone's Avatar
M Mad
Actually the service indicator starts counting down at 15,525 miles. Only if you drive like a granny will you go that far between changes. The record for count down is someting like 6,500 actual miles. It is based on fuel consumption, so the harder you drive, the earlier you get a change.
And no matter what, you get oil should be (and BMW will do so for free) changed every 12 months.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-31-2005, 02:58 PM
dcrofford dcrofford is offline
Mein Auto: 2000 323i
Thumbs up thanks a lot it DOES work!
Alex
I live in Texas and my bimmer sis is in Ca. I changed my oil after the local dealer closed so I called her to get Creviers # in Ca., only to find they were closed as well. This is New Years eve so now Im calling BMW of Maui only to find the answer was here on Bimmerfest all along.
Thanks Again,
DC
Old 12-31-2005, 03:21 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Thanks Again,
DC
No, THANK YOU for using search to find your answer instead of asking another inane question which has been answered 100 times. Seriously. More people here can learn from you.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 01-01-2006, 05:16 AM
Pinecone's Avatar
M Mad
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 06-21-2007, 04:12 PM
FunnyMoneyOSU FunnyMoneyOSU is offline
Mein Auto: 2005 330i
Oil Change Mileage
It just worked on my 2005 330i... thanks!
Old 06-25-2007, 07:20 PM
dragon52 dragon52 is offline
Mein Auto: 2004 330CI
Tried it on my 2003 325I but no success...
got the __set light come on; then reset; then blinking reset... but no reset.
it may have to be done manually by computer.
Old 07-07-2007, 01:20 AM
dwnhiler dwnhiler is offline
Mein Auto: 328i
what if i have a 328i 2007 which is a keyless entry i dont think i know how to put it on accessory position and to hold it down any suggestions
