Old 05-03-2012, 10:28 AM
gsimpson7 gsimpson7 is offline
Mein Auto: 2009 BMW 750LI
265-30-22 front and rear
Has anyone put 265-30-22 on front and rear of a 750LI instead of going staggered?
Old 05-03-2012, 05:33 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
depending on the on the offsets, you may run into some rubbing while turning in the front, and on the rears they should be okay, just it may look a little odd because its slightly narrower than the factory tire.
My suggestion is to go with 255/30/22's on the front and 295/25/22's on the rears, much more aggressive stance!
Old 05-03-2012, 08:52 PM
265 30 22 is the suggested size for the front. I was going with the same on the rear to eliminate the staggered bigger but thinner tire on the rear which is a 295 25 22.
