The X5 SAV Forum
Old 05-04-2012, 01:27 AM
kzhlin kzhlin is offline
Mein Auto: BMW X5
2003 X5 door lock motor broken?
Hey guys,
I have a 2003 x5 and the driver's side door will not lock or unlock wirelessly with the key. I have to manually stick the key into the keyhole to lock/unlock it. My key can wirelessly unlock all the other doors, just not the driver's door. I had heard that the locking motor might be broken.
What do you guys think?
Thanks,
Kevin
2011 E92 335i
2003 E53 X5 3.0i
Old 05-04-2012, 07:19 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Originally Posted by kzhlin View Post
Hey guys,
Thanks,
Kevin
The rule of thumbs:
1) door can't be opened from outside when it's already unlock, carrier busted (part #15)
2) door operating rod (part #4) can't go up-down consistently with remote or central locking, but door can be opened from outside once it's unlocked, door actuator busted (part #1).
In either case door can be opened from inside.
Old 05-04-2012, 06:50 PM
Mein Auto: BMW X5
From what you are saying, it sounds like my actuator is broken.
Diagnostics:
1. I am able to unlock all doors from the inside (manual. 2 pulls on the handle). Inside lock/unlock button can unlock the other 3 doors.
2. Key can remotely lock/unlock all doors EXCEPT driver's side door.
3. Driver's side door cannot be locked/unlocked using key or inside lock/unlock door button.
Old 05-09-2012, 04:46 PM
Mein Auto: BMW X5
How much is it to fix an actuator?
Old 05-09-2012, 06:45 PM
I'd call a auto-shop specializing in BMW for a quote, they know to the T how much labor to do it. For dealer add 25-30% over indy price.
It takes me about 3-hr total to do the driver's side.
Old 05-09-2012, 11:27 PM
Mein Auto: BMW X5
What's a ballpark estimate for parts and labor?
2011 E92 335i
2003 E53 X5 3.0i
Old 05-10-2012, 07:41 AM
ballpark,
for indy: I'd say 3hr x $110 + $200 for actuator or $100 for carrier (whicever you think busted). Dealer will be more for both labor rate and parts
for list of independent BMW shops:
http://www.bimmershops.com/
these shops are not mom-n-pop, this shop tends to know the ins-outs of BMW cars and their weaknesses.
Call several of these indy shops and get quotes over the phone.
Good luck.
Old 02-15-2014, 08:40 PM
pguercius pguercius is offline
Mein Auto: 2006 X5
Is my Actuator Broken?
Cannot lock/unlock the Driver side door (Only) using the key remote or the Lock/unlock button on the center console.
Diagnostics
1. Using Remote key;
Lock-> will lock all the doors except Driver side
Unlock -> will unlock all the doors except Driver side
2. From inside the car using the lock/unlock button on the center consol
Lock -> will lock all doors except Driver side
3. Manual operation of lifting and lowering the button in each door.
Lock and unlocks works for all
4. using they manually on the Driver door
Lock and unlock works.
Old 02-15-2014, 08:57 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
sounds like you guys have a bad lock actuator problem, same symptom I had back in july 2013, lock actuator was 254.00 can shipped I ordered mine from these guys and got it within a week to canada. http://www.bmwofbloomfieldpartsonlin...p=FRONT%20DOOR
2003 X5 3.0i
Old 09-07-2015, 09:11 PM
leejim leejim is offline
Mein Auto: 2005 X5 4.4 V8
RF door locking remote problems.
Hi my car is 05 but I had a problem with the RF (on RHD) lock not locking or unlocking but other 3 doors ok. It was the white plastic plug on the interior switch panel not connecting properly sprayed it with CRC contact cleaner and made sure it was plugged in tight no more trouble ? Easy to pull out just carefull screw driver under each end and lifts up maybe worth a try. Took me ages to fathom out.
