BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#226
Or google on why Passat TDI gets better economy than Jetta. There are a number of posts about it on the TDi forums. Sounds like basically since DEF allows Nox reduction that they can tune the motor differently and rely on the DEF to reduce that. Where as on the Jetta they basically rely on the burn off process more so and fuel is used for that process. But unless I am misreading things it sounds like they both still have a burn off process but it happens less often on the Passat due to able to tune the engine differently for overall emissions. Or maybe I am reading wrong on the burn off process have squat to do with it either way. I only skimmed things before posting but it seems pretty definite that by adding DEF to the cars it allows for better fuel economy.
--Aaron Last edited by Snipe656; 05-31-2012 at 03:18 PM. |
#227
Brought mine in on Weds morning, got it back last night. Apparently they ran into some kinda of glitch when first uploading the new software and has to install the 'bus' as it was missing, according to the papers at least. I told them about the SIB for the A/C belt but they said they couldn't find it in the system. No F30 loaner too
#228
The burn-off is for the particulate filter, to keep the particulate count down. DEF does not impact particulate "pollution," it is primarily to keep the NOx numbers down. So you are correct, a DEF system will not impact the need for a periodic "burn off."
#229
On my commute today, car seemed peppier but the loaner was a 328i so this is the likely explanation.
Colonel (Ret) US Army / Hagerstown, MD 2010 Z4 s30i Alpine White/Beige PP/SP/CWP/6MT/CA/NAV/ipod/USB ED 1-29-10/Redelivery 3-8-10 (weekend car) 2013 Audi A6 Quattro (daily driver) 2011 335d (Ret) 2009 335i vert (Ret) 2007 335i vert (Ret) 2000 740iL (Ret) 1998 328iC (Ret) 1990 535i (Ret) 1988 635CSi (Ret) |
#230
http://www.factsaboutscr.com/perform...operation.aspx Which states within there: Quote:
http://www.demanddetroit.com/performance/emissions.aspx Which states within there: Quote:
--Aaron |
#231
Theoretically, if you open pipe the 35d engine and delete/bypass all of the emission systems /nothing after the turbos - no DPF, no SRC no DEF/, what % gain in the performance and MPG do you think will occur? At the same time - how contaminated will be the exhaust gases?
2011 X5 xdrive35D - The Ultimate Oil Burner - Alpine White / Oyster - Premium - Technology - Winter - Comfort Access - Rear Climate - 3rd Row - Roof Rails - Running Boards - Ipod/USB Adapter 2004 E46 ///M3 6SP Manual - Imola Red / Cinnamon - Premium - Luxury - Winter 2004 X3 E83 2.5i Auto (SOLD) 1996 318ti E36 Hatchback 4-cyl 5SP Manual (SOLD) Last edited by tol4o; 06-01-2012 at 10:22 PM. |
#232
--Aaron |
#233
So after the recall I've been leaving it auto, driving very gently to encourage faster upshifts at lower revs.Does anyone know how long or how many miles it takes for the tranny to reprogram itself?
Current: '10 335d Titanium Silver Premium, Nav, Ipod, Sat '07 A3 Ibis White, Tint, 2t, DSG, Premium dual sunroof Retired: '69 VW Fastback '73 MGB '78 Camaro LT ttops '80 VW Diesel rabbit '81 Audi 4000 4E '84 Audi 5000 5sp '87 Audi 5000 auto '90 Audi V8q '92 Millenia '01 Acura TL '93 Miata b Candy Apple red, AC, Factory hardtop |
#234
i didn't even know that the transmission is adapting the shifting depending on how you drive the car. Is that for real?
2011 X5 xdrive35D - The Ultimate Oil Burner - Alpine White / Oyster - Premium - Technology - Winter - Comfort Access - Rear Climate - 3rd Row - Roof Rails - Running Boards - Ipod/USB Adapter 2004 E46 ///M3 6SP Manual - Imola Red / Cinnamon - Premium - Luxury - Winter 2004 X3 E83 2.5i Auto (SOLD) 1996 318ti E36 Hatchback 4-cyl 5SP Manual (SOLD) |
#235
I had the recall done last Tuesday. I had noticed some roughness in the engine while the car warmed up prior to the update. I have a fairly steep hill if I take a right out of my nieghborhood and the car wouldn't miss or anything, but it was sort of surging. I don't think it always did this, but it's gone since the recall. The car seems faster, too, with about a 3% drop in indicated MPG. Worth it, in my opinion.
#237
Yes, they are adaptive like a lot of newer cars these days. What I do not know offhand though is if they constantly are adapting or only adapt after a reset. For example if i remember correctly my truck only adapts for a short while after a reset then never again.
--Aaron |
#238
There's a fantastic pdf document referenced around here (http://www.bimmerfest.com/forums/sho...50&postcount=4) that goes into the adaptations the computer does. Lots and lots of adaptations... |
#239
Ok amigos I took my car to BMW yesterday, I sat with the INCOHERENT/IGNORANT and Incompetent SA, I described the recall he didnt knwo either the AC issue either, I showed him a picture of the error codes and he TRIED to give me a lecture, I shut him up on this cause I told him this thing lights up today and tomorrow its gone. Anyway, he said that Puerto Rican laws protected him of giving me a vehicle I told him I was late for my appointment that i would address this later. I called him at 3:30 and he told the car had NOT been thru DIAGNOSTICs i said WTF 6 hours later and NOTHING done!!! I blew my fuse professinally and he said he still could not give a car i told him I will bite the bullet today but I better have A CAR tomorrow he said he warned me I blew a bigger fuse and went a little OFF on him and told him Id bet there in 20 minutes to p/u my house keys. Needless to say he calls me half way my trip to inform me that the EGR is DEFECTIVE and to p/u my car since they have to order the parts. I got there and he WAS NOWHERE in site. Im planning in speaking to the general manager and have me voiced out. Luckily he is a friend of my mechanic otherwise I still would be out of a car toady!!!!
#240
They changed out the DEF mixer and SCR Catalyst on my car. The EGR was replaced a few months back with the newer designed unit on the last round in the shop due to carbon buildup.
I've noticed a very strong burning smell (worse than DPF burn off) since they changed out the SCR catalyst. I'm thinking its due to the new part being "burned in" so will give it some time before taking it in to be looked at. During the week the car was at the dealership (not all parts were on hand) they gave me a 2012 335i coupe. It felt a little sluggish in normal driving compared to the D. You simply can't beat the torque of the D.
2009 BMW 335D 2005 Chevy Silverado Duramax Diesel 2008 Polaris RZR |
#241
I have a feeling I might get lucky enough to have all three replaced. But thus far I have had two failed attempts on my part to try and drop off the car. If I keep this up then it might need rear brakes by the time I get there.
--Aaron |
#242
Anyway they gave us 2011 328xi as a loaner. Man that thing was so sluggish compared to the X5 diesel and my M3. Basically at 2000 rpm you press the accelerator without changing the gears and literally nothing happens! You have to press the pedal harder to get some crazy downshifting to get the rpm to 4-5k to feel any push of acceleration. The lack of torque is so obvious! Don't even wanna talk about the fuel economy. For 30 miles city driving I re-topped the tank with 2.5 gallons gas!!! Thank you but am stuck with diesels and M3 cars
2011 X5 xdrive35D - The Ultimate Oil Burner - Alpine White / Oyster - Premium - Technology - Winter - Comfort Access - Rear Climate - 3rd Row - Roof Rails - Running Boards - Ipod/USB Adapter 2004 E46 ///M3 6SP Manual - Imola Red / Cinnamon - Premium - Luxury - Winter 2004 X3 E83 2.5i Auto (SOLD) 1996 318ti E36 Hatchback 4-cyl 5SP Manual (SOLD) Last edited by tol4o; 06-08-2012 at 07:32 AM. |
#243
The 328's 6cyl non-turbo is only able to muster up 200lb of torque at 2700 RPM
#244
![]() ![]() Of course this was all in Espanol!![]() ![]()
#245
I almost went SPANGLISH on his ASS! Thats how mad he got me, I sent an email to the General Manager earlier today will keep you all posted.
#246
Hola amigo ! Keep us updated! BTW, I learn a new phase from you :"I blew my fuse professinally" which is what you do when you are dealing with German. Most of the time, you need to blow a bigger fuse with boricuas. Just saying...
#247
@Bayoucity eso es ceirto!! Here is the emai I sent the general manger and he as of yet has not responded:
CAMPAIGN NUMBER: 11E-A03 y SIB 64 08 11 regarding the belt Dear Mr. Rosa, I write to you this email since I understand you are a very busy man managing AUTOGERMANA of Puerto Rico. I had the unpleasant experience yesterday to leave my car at your shop facilities in Guaynabo. I had made and appointment for which it was to my belief that the above campaign numbers were being addressed and parts were on hand. Needless to say, I had Mr. Carmona attend me and from the beginning we did not see eye to eye on this matter. I would be more than glad to speak to you about this encounter at any given time, which by the way was very distasteful for me and makes me wonder where has Customer Service gone? Fortunately, I happened to befriend Buru (for many years) whom happened to speak to you earlier yesterday. I am a proud owner of a 335d and previous owner of an 02 MCS for which Buru made many fixes. So I can gladly say I have been a BMW owner for over 10 years, and make no mistake in upcoming years also! Situations like this can detract many clients and include myself. I hope we can convey in the future and settle this in an appropriate manner. A whole lot of people in some BMW forums are watching this Campaign issue closely and would eventually be detrimental for future buyers of regular or Diesel BMWs. Any questions feel free to respond to either this email and/or at axelhernandez61@yahoo.com or my cellular numero 787-459-4518. Gracias!! |
#248
Maybe the emissions recall is a good thing..
http://www.reuters.com/article/2012/...8HCL3I20120612 |
#249
I saw that this morning. Life would be easer if we just got a list of the things that do NOT cause cancer. I'd imagine I would be a really short list.
--Aaron |
#250
I guess we are screwed on this, anoher thing to Blame cancer on, WTF!!
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
