BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#376
I got about 32 mpg hwy but before the software update i used to get
35-36 mpg. Oh well. |
#377
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
#378
I cannot say just "Oh Well." We all paid a premium for a car that is to get world class fuel economy. By taking MPG away, the d may end up with a higher long term total cost of ownership than a 335i. The car has proven it's ability to deliver over 40 MPG. I need a good explanation from BMW why they are preventing it from doing so now.
#379
Dropped the car off on Fri. Still needs to have programming done. Should be done on Mon. Hoping the MPG doesn't drop.
FS: 19" HRE 840R's/Tires/TPMS http://www.bimmerfest.com/forums/sho...94#post7186394
#380
--Aaron |
#381
So the 335d should do better than EPA numbers except perhaps if we all have heavy right feet. This can also be possible if there is too much throttle "tip-in" programmed into our cars, a common trick used to make cars feel more powerful than they are in my experience. It may very well be programming or emissions. PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck Last edited by Pierre Louis; 08-06-2012 at 02:48 AM. |
#382
Snipe, you are not getting the rated MPG. I almost always get better than rated in any car becasue I typcially drive very conservately.
#383
I thought you said you can't sue over it because you are getting what it is rated at. As far as me, I never have gotten what it is rated at and always got below the rating but unlike you I never have cared enough to demand reasons from BMW.
--Aaron |
#384
whats all the fuss Im lucky if i can get 23 mpg City here in Puerto Rico and i live in the Metro area, I only good mpg whenever I go to the rest of the Island on weekends.
#385
I dropped the car off this morning for the "belt squeal" issue and mentioned this to the SA, so we'll shall see. I think they screwed something up with this update IMO.
#386
July 2011 build. Had my car in for it's annual oil change today. They checked the key and did not do any recall work. I wonder if I have different programming than earlier builds?
Entertaining America Since 1975 ![]() European Delivery July 26th 2011 ED Video: https://vimeo.com/60051914 ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294 335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns BMWCCA #448878 |
#387
total mileage update, including post-emissions fix
16636 miles, 585.697 gallons, average MPG 28.5 +/- 2.599 8626 miles with JDB, 308.262 gallons, average MPG 28.3 +/- 2.914 5607 miles minus JBD, 204.650 gallons, average MPG 27.4 +/- 1.307 4374 miles post emissions fix, 159.616 gallons, average MPG 27.4 +/- 0.953 The first 24,000 miles, including JBD, included several extended road trips with tanks having average MPG of >40.0, including one of nearly 42 MPG, which probably explains both the higher averages and the higher standard deviation figures. Thus for my D, my mileage has been remarkably consistent, with our without JBD, and pre and post-emissions glitch. |
#388
I had a long roadtrip for a vacation to Colorado and back. Total miles driven was 2601 with an average mpg of ~36.5 by using 71 gallons of diesel. The trip there was a lower mileage (around 33.5 mpg) as I was going about 80 and the A/C was running continuous due to Texas heat. After we got to Salida, CO we drove around over several mountain passes and going to different hiking trails and the average mpg doing this was around 36. The D climbed the hell out of the mountain passes. It got good mileage in the process was the surprize. I had a few jaunts up to 120-125 too but not on the twisties up high on the passes. On the way back driving around 77 to 78 using cruise control, I got about 37.5 mpg with the A/C running.
I think on the long trip that my car learned how I drive again after the new valve and reprogram. I had observed a decreased mileage on hwy but actually an increase in city driving. I still am a little baffled why the front leg of the tip was lower unless the D was still learning. Each leg of the trip was about 1000 miles. Before reprogram, my car would get about 38 mpg if going 75 (with cruise on) and operating A/C. If I go 65 with cruise and no A/C, I can still get 41 mpg. On more thought is the the car was loaded pretty well with all of our luggage and hiking/climbing gear during the going there and coming home legs. I figure about 250 lbs total payload not including 2 tall adults. The extra payload (except the 31 lb spare tire) was not in the car during our driving around in CO. |
#389
I also complained about the mpg decrease since having the emissions recall performed (egr replacement and repgoram) to my dealer this week while the car was in the shop. My SA who was very sympathetic stated the tech checkd everything and it appeared to be operating within in spec, but that they will document the problem and that perhaps BMW will investigate if they receive enough complaints - so for everyone else if you are seeing similar results since having the EGR work performed COMPLAIN. It sucks that I am now getting high teens city MPG! My SA said it is likely due to the reprogram and possibly some glitch which is causing the unexpected mpg decline - although he was just guessing.
#390
I also complained witb my dealer, and SA is a friend of mine. He has received complaints of decrease in mpg with this software update.
He asked me to bring the car back as my hwy mpg dropped by 4-5 mpg when driving from San Antonio to Houston and back. I used to get like 35-37mpg driving under similar conditions. My city mpg also has dropped 4-5 mpg. The highest shop foreman got was 32mpg on hwy, SA asked me to bring the car back and see what they can do. I must hit small pothole and my headlights got out of alignment- weird, but the dealer tried adjusting but cannot seem to, so they want to look at it again. They need to go out further by like 5-8 feet and the beam pattern is messed up also. will report what the findings are for mpg. I also left a message to BMW Corporate and they have not returned my phone call. |
#391
Althought BMW does not return calls for messages left. If they get enough of them, maybe that will 'encourage them' to acknowledge the issue. Of course higher fuel consumption = higher DEF consumption. I got the 999 miles to no start warning with 2100 miles to go till the next service. Added 1/2 gallon (bottle from VW $10.50) and that should hopefully just make it. Last edited by KeithS; 08-09-2012 at 07:47 AM. |
#392
It's speculation, but my guess is the recall/reprogramming ties to either (or both) the California emissions investigation that several board members were contacted about earlier this year and the carbon buildup that several others reported earlier this year. Either way, BMW ain't gonna say anything about it. If anyone has any proof one way or the other I'm open to revising or withdrawing my hypothesis. My mileage has dropped about 3 MPG since 2010 (same route driven to and from work every day). The revised mapping lowers mileage but improves emissions and/or eliminates carbon buildup.
2010 E90 335d European Delivery: 12 April 2010 Platinbronze | Oyster/Black | Sport | Premium | iDrive | Logic7 | iPod | Comfort Access | Shades | Folding Seats
#393
After the emissions fix I took a long road trip and got 39+ mpg, which was about the same highway mileage as I got before the emissions fix. My city mileage seems to be better after than before the emissions fix.
#394
My mileage has dropped by 4-5 mpg both city and hwy after
the last recall. I am upset as i bought this car which had great fuel economy And performance. I think bmw will have a class action lawsuit aa bmw corporate Has not returned my phone calls. Dealer is aware of the complaints and does not know What to do. |
#395
If I actually drive the car like I used to drive my 2005 E320 CDI, which had low rolling resistance non-low profile tires, one instead of two turbo's, a whole lot less power (but was plenty fast anyway) and perhaps less emissions restricting equipment, I get about the same mpg's but with a slightly less aerodynamic car (the 335d) albeit lighter one.
To get better fuel economy, the Mercedes was much more aerodynamic (CD of .26), had lighter body parts (more aluminum - something more like the F30) low rolling resistance tires, and a luxury suspension. I drive the 335d like a sports car and get worse economy when I do. Took it to the dealer and got it tested specifically for mpg's: they did have a procedure for this. Will need to get the report to post, but in effect, they got their mpg's to be "within stated EPA parameters" or something like that. It appears that my heavy foot, which is what the BMW may lend itself to, contributes more of the poor mpg's than anything else. The only thing else that may contribute with the recall would be the transmission programming. It may be back to square one needing to re-learn the shift pattern for one's specific driving. This may account for some of the loss of mpg's perhaps. PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else. Cosmo Castorini: Thank you, Rose. - Moonstruck Last edited by Pierre Louis; 08-11-2012 at 09:03 PM. |
#396
My mpg's have never been worse than they are now after the recall! When I first purchased my car and the dme had not learned my driving style I was still getting in the low 20's city. Now I am in the high teens!!! This sucks the BIG one and I am PISSED about it. Not to mention think about what it will do to the resale value - I mean what the **** is the point of buying a diesel over the gasoline 335 if the mileage is the same?! The answer sure is not "for the exhaust soundm"
#397
CRAZY leases on Volts '13 and '12 (if there are any still available) as some dealers want to be #1 Volt dealer in the country...I got the recall on the X5d but not the 335d; no decrease in mpg's noted.
#398
I agree that I bought the 335d for fuel efficiency and performance. Now my mpg has dropped 4-5 mpg for both city and hwy.
Someone had posted a tel# at BMW Corporate and I lost that tel #, but I did leave a message and they have not returned my phone call. I think BMW needs to resolve this problem or else there may be a class action lawsuit. |
#399
2012 BMW X5 35d 2011 BMW 335d MSport [Pilot Supersports / no runcraps] 2008 BMW E93 M3 |
#400
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
