Old 05-04-2012, 03:48 PM
5seriesHB's Avatar
5seriesHB 5seriesHB is offline
2 Bimmers R better than 1
Mein Auto: 12 MSPT 535 & MSPT X5 5.0
Bmwpedals.com performance pedals
7 Series guys.....WELL I FINALLY PULLED THE TRIGGER ON THE BEST PEDALS ON THE MARKET INMO!
I TRIED A FEW OTHER COMPANIES IE: BIMMIAN PEDALS BUT THEY DID NOT FIT EXACTLY.
SO I GOT IN TOUCH WITH THE OWNER BRIAN OF BMWPEDALS.COM
WENT DOWN TO HIS FACILITY IN ANAHEIM CA AND WAS BLOWN AWAY WITH THE QUALITY OF THESE GORGEOUS PEDALS.
BRIAN IS AND ACTUAL FABRICATOR AND MADE THE ORIGINAL PROTOTYPE HIMSELF AND HAS PEDALS SPECIFIC TO MOST BMW'S. REALLY IMPRESSED WITH THE ASSORTMENT HE HAD ON HAND.
FOR THE F10'S HE HAD SILVER THAT HE CALLS CLEAR AND BLACK.
IVE ATTACHED PICS OF BOTH.
I WENT WITH THE CLEAR WITH THE "M" LOGO KICK PLATE WICH DRILLS EASILY ENOUGH TO THE MATT NOT THE FLOORBOARD
THE GAS PEDAL SCREWS ARE SELF TAPPING SO THERES NO NEED TO TAKE THE PEDAL OFF AND NO NUT TO SCREW ON IN BACK WHICH IS SO HARD TO DO.
THE BRAKE PEDAL ONLY NEEDED TWO SCREWS AND A NUT TO BE TIGHTENED IN BACK
FOUR WOULD BE OVERKILL AND UNNECESSARY. THE DEAD PEDAL WAS ATTACHED WITH HEAVY ADHESIVE TAPE AND THERE IS NO NEED TO PULL THE EXISTING ONE OFF. IT GOES RIGHT OVER AND FITS LIKE A GLOVE.
THE KICK PLATE TOOK THIS TO A WHOLE NOTHER LEVEL!
I PAID $114 FOR THE 3 PEDALS AND $99 FOR THE KICK PLATE
But the guys on the 5series forum have a cool group buy going now for cheaper!
http://www.bimmerfest.com/forums/sho...d.php?t=618522
HE SAID HE IS ALSO GOING TO BE AT BIMMERFEST
Contact Brian@bmwpedals.com
Really a great guy!
CHECK THIS OUT
NJOY
ROB
ID:	323626   Click image for larger version
ID:	323627   Click image for larger version
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Msport X5 +Prem Sound+Cold Weather+Top/Side Cameras+Soft Close Doors+BMW Apps
