E30 (1982 - 1993)
Old 05-06-2012, 05:31 AM
BTR BTR is offline
Mein Auto: 323i
E30 325 diff
I found a e30 325 in the junk yard the engine is gone but the trans and diff is still their.. I read the trans are the same but the diffs are different, is this true? Along with that said, would it be worth getting this diff and can it be used with the m20m20 motor and trans. I will be doing a swap next year
Old 05-06-2012, 04:13 PM
downhiller's Avatar
livin large
diffs have different gearing. so depending on what you have, which should be something like the 4.10. now you can go higher, but will slow youre accel but gain top speed. other then that you either have open or lsd. all info is on google just gotta dig a bit
