E90/E91/E92/E93 (2006 - 2013)
A/C Odor
Hello,
We bought a CPO E93 and recently noticed odor from the HVAC system. BMW service said they can use a chemical cleaner that costs over $350. Not covered under CPO. Does anyone know where they spray the chemical? Where Is the HVAC drain hose on the E93? I'm planning to use a different treatment, but requires to be injected through the HVAC drain hose while A/C is set to high. Thank you, Mark |
I use Ozium when I start smelling the foul odor, which seems to be every six months going back and forth from using A/C in the summer and heat in the winter. I found it at WalMart a couple years ago. I spray it on the fresh air intakes with or without the cabin air filter installed, and I let the car sit for a few hours. I'll cycle to the different HVAC modes (ie. A/C on and off, recirculate on and off, etc..) after spraying.
Here's the Amazon link: http://www.amazon.com/Glycol-Ized-Pr.../dp/B000FEPW40 |
I only get this odor when I set the air to be recycled in the car. Any thoughts? It pretty much smells like mildew.
Sent from my ADR6300 using Bimmer App |
Ok, so far, I've read to spray into the fresh air duct under the micro filter. But I am also reading to spray it in the center air vents.
Does anyone know where the HVAC evaporator core is located? I'm looking for a diagram. Thanks, Mark |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
