Old 09-14-2014, 08:35 AM
Bluehorse Bluehorse is offline
Mein Auto: 2014 X5 F15 35i
Xenon HID bulb color shifted
Hi, all,
2004 E60 525i, with 90K miles. It has Xenon HID light and adaptive light control.
Yesterday I noticed the driver side Xenon HID bulb's color changed to pink/purple. The sequence is:
1. the two HID bulbs immediately at time of turned on have the same normal white color.
2. Then in ~2 seconds the color on the driver side starts to change gradually to pinkish, and will stabilize at the pink/purple shown in the attached photo after ~7 seconds.
Questions need your help:
a. Is the blast on the driver side the problem, or we know for sure it is the driver side HID bulb?
b. If it is the bulb failure, is it as simple as just replace it or something has to be done/checked at the blast?
c. Researched at O'Reilly site, which showed two different brands both have "part number" as D2S. How do I verify this old failed bulb is D2S and the O'Reilly part will work?
c. Amazon.com shows all kinds of D2S HID bulb (no referenc eof Xenon, not sure why), prices range from $5 to over $100 each. What the heck - why are they that different? Since this is a DIY, I don't mind to a pair of cheap bulbs and replace both. Just want to make sure they will light up and will not cause error codes. thought?
Thanks all!
Name:	Xenon Light.jpg
Old 09-14-2014, 12:37 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Open up the back cover and check what type of bulb is in there. If they both light up it's probably just the bulb.
Change them both out together and you should be good. I replaced mine with Osram xenarc 4300K. This photo is to show the difference between the types of bulbs your car may come with. I'm pretty sure it's D2S, but you have to check to make sure.
