Old 05-07-2017, 11:47 PM
fyerman01 fyerman01 is offline
Mein Auto: 2006 525i
E60 525i Backup Lamp Malfunction
Both backup lamps were burned out and replaced them with new LED bulbs yesterday. Lamps are working fine now but I still have these control center messages:
Right backup lamp malfunction!
Left backup lamp malfunction!
Any ideas on what I need to do to get rid of the messages? If it helps I have a K+DCAN cable but I admittedly have no experience using it or where to even start . Any help getting rid of these messages would be greatly appreciated!!!
UPDATE: I also had one of the four brake lamps out. Changed that bulb at the same time and the control center message for it went away. Now I'm staring to wonder, could replacing the backup lamps with LEDs be causing the messages to remain? Bulbs are cheap so I might try going back to regular bulbs if nobody has any better ideas...
Old 05-08-2017, 03:41 AM
nicknice91303 nicknice91303 is online now
Mein Auto: 07 525xi E60 N52 automati
That is exactly why you have the error message. led uses less voltage so when the car runs it's test it sees low voltage and thinks the light is out. Only way to get rid of the message is turning off the test but have to be done threw coding.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 05-08-2017, 04:07 AM
DustinGroff DustinGroff is online now
Mein Auto: 2008 528xi
You can install load resistors to mimic regular incandescent lights. I just put these in my car last weekend. So far so good. 4Pcs Aaron 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal Blink Error Code https://www.amazon.com/dp/B00L4V9ECY..._Tefezb4TXF4WG
Sent from my Pixel XL using Tapatalk
Old 05-08-2017, 05:49 AM
Wal-Mart also sells load resistors if you don't feel like waiting for shipping. I forgot you can put the resistors on it.
Old 05-08-2017, 06:01 AM
38Fitter's Avatar
38Fitter 38Fitter is offline
Mein Auto: 550i, 745i
+1
This is common practice amongst led users. Any higher end kit you buy should come with them to prevent error messages.
I installed led halos with resistors and they run error free .
Sent from my iPhone using Bimmerfest mobile app
Old 05-08-2017, 07:25 PM
Originally Posted by 38Fitter View Post
+1
Awesome, I'll give the resistors a try. Thanks guys!
