E36 (1991 - 1999)
Old 05-07-2012, 04:15 PM
djtwisted djtwisted is offline
Mein Auto: 97 318is
Unhappy E36 Clutch pedel problem
Hello BMW owners. Newbie here.
Today I had my clutch pedal lock right up on me. I couldn't push it in at all. I had no warning signs of this to come. The car was running fine and all of a sudden at a stop light, I couldn't put it into gear. Where should I start looking? Slave cylinder, bearing, or a whole new clutch? I have a 97 318is with 180k. Any suggestions? Thanks to all in advance.
OK I just removed my Slave cylinder and the pedal is still stuck. I released the bleeder and the pedal went down, once I tightened the bleeder I was back to a stuck pedel???????
Old 04-26-2014, 08:14 AM
jjwall jjwall is offline
Mein Auto: 323is
What was the problem with your clutch ? I have the same problem now but not sure where to start.
Old 04-26-2014, 09:34 AM
Mein Auto: 97 318is
Problem solved
Hi. It was the throw out bearing. It exploded and the pieces bound up the clutch. Since I had to take it all apart to fix it i went with a new clutch, bearings, and slave cylinder. I noticed that it was pretty easy to get to the starter once the clutch was removed so i changed that also ain e mine was acting up.
Good luck!!!!
Old 04-26-2014, 10:48 AM
hornhospital's Avatar
D'oh, You Kids!
jj, welcome to the fest, and thanks for searching first!
dj, thanks for replying! Stuff like this helps so much when someone else has a similar problem.
Well done, guys!
Quotes to live by:
Old 04-27-2014, 06:11 PM
Mein Auto: 323is
thanks guys. I was going to replace the master clutch cylinder and master cylinder / brake booster but I'll swap a new clutch in first and see what happens
clutch, pedel, slave cylinder, throwout bearing
