E34 (1989 - 1995)
Old 05-08-2012, 06:08 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
should I replace rotors?
Going to replace my frontpads after about 100,000 miles on the front with akebono Euro Ceramics. My Rayestos QS ceramics finally wore out. Brembo stock style rotors have only about 58,000 miles. No apparent wear/groves and no vibration.
Any need to replace? Do not even want to turn as usually does not work well on a BMW as they warp.
1995 525i auto, 1/95 build, EAT chip, abt 228K miles, EC mirror, HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 208K
Old 05-08-2012, 06:27 AM
supertech777's Avatar
supertech777 supertech777 is online now
IMO I would have them check if your rotors are still up to spec . Then go from there . Just my 2 cents Russell .
Sent from my Desire HD using Bimmer App
Old 05-08-2012, 09:31 AM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
If there are no groves you should be fine. Rotors on 525iA with 50,000 on them should be 'fresh' if you did not drive with worn out pads.
///////////////////////////////////////////// E34 Addicts
Old 05-08-2012, 09:45 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
The crieria I use is; Are they worn beyond min thickness? Do they run true, no lateral runout? Badly grooved? Large ridge on edge?
If all the criteria are met I scuff them with an orbital sander* and grind off an offensive ridge that will tear up the outer edge of the new pads and tear into a fresh wear sensor long before pad life is gone.
Typically, a BMW rotor will last through two sets of soft-ish pads for me and my driving style.
* Scuffing the surface, I use a moderately coarse 80 grit, allows the new pads to bed in. Putting new pads on a glazed rotor makes break in take forever and also makes for a scary pedal feel.
Take my advice, I'm not using it.
Old 05-08-2012, 09:57 AM
rdc rdc is offline
Russell
thanks all.
Old 05-08-2012, 03:53 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Seems to be very sound advice. Thanks for the info.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-08-2012, 05:18 PM
nwilson44 nwilson44 is online now
Mein Auto: 1995 BMW 540i
Yes go ahead and change them. If you don't and needed to your going to want to change the pads again because pads do better once fitted to one rotor. And to me its worth spending the extra $250-$300 to get the rotors on one axle because the pads are $115. So better to spend that $115 once than twice.
Old 05-08-2012, 07:05 PM
rdc rdc is offline
Russell
Akebono euro front pads were $91 shipped from Tire Rack. Brembo stock style front rotors are 102 shipped (free shipping) from Amazon. Best price i found. Have not purchased the rotors Yet!
Old 05-08-2012, 08:20 PM
Well either way you probably don't want to buy anything twice. Just be careful and i think you'll be fine.
