E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
FWIW...Testing o2 sensor
With a 4-wire oxygen sensor, the output signal works in a constant
loop, essentially, the fuel injection computer sends a signal to the sensor, and the sensor then sends the signal back to the computer. This is achieved by having one wire carry the signal to the sensor, and then another wire carries the signal back to the fuel injection computer. You also have a wire carrying 12 volts to the heating element, and the last wire is the ground for the heating element. With a 4-wire sensor, you will need to measure the voltage fluctuations between the two signal wires. To do this, start the car and let it warm up. Next, disconnect the oxygen sensor and measure the voltage between the wires. Now take off the oil filler cap to simulate a rich running condition. Watch the voltage, if it begins to fluctuate rapidly, then the sensor is good and your done. If it stays the same, o2 sensor probably kaput. Low voltage means there is oxygen in the exhaust (oxygen on both sides of the sensor) and the engine is lean. High voltage means there is no oxygen in the exhaust and the engine is rich. An old worn sensor has a low output which causes the computer to enrich the fuel. Last edited by Helmet Ludendor; 05-08-2012 at 01:10 PM. |
thats great. but most these run 3 wire.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
3 wire sensor is probed the same. Find the signal wire. Probe for voltage. You can very easily probe the signal with a sharp Multi Meter probe without disconnecting if you desire. Harbor Freight cheapish at $3.00 or free with coupon, grind the tip to sharp point works for me. Throw one in DD trunk tools every car. Saved pain and anguish with 25 y.o. machines.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
