Old 05-08-2012, 03:04 PM
bkdave2atl bkdave2atl is offline
Send a message via AIM to bkdave2atl
Mein Auto: 745i
Jumps forward after put in park and turned off
My 7 family, just started having an issue with my car jumping forward after I put in park and turn the it off... Has anyone experienced this? All info and help is appreciated an welcome.
Old 05-08-2012, 03:39 PM
N62B44 SGM's Avatar
N62B44 SGM N62B44 SGM is offline
Mein Auto: '05 E66
Are you releasing your brake as your pressing the park button? I know if I let go too fast it moves forward a bit. As long as I have brake pressed throughout, no problem.
www.fquick.com/N62B44_SGM
2005 BMW 745Li E66 Sterling Grey Metallic / 35% Tint (windows) / 20% Tint (tails) / ACS Roof Spoiler / Interior & Exterior LED's / MTEC V3's / 6000K D2S /
DDM Tuning HID 6000K Fogs / BIMMERFEST license plate cover
Old 05-08-2012, 03:55 PM
Mein Auto: 745i
I always press the brake then put in park whether it's on a hill or not. I thought it jumped forward cause I was on a decline but it did the same thing when I was on level ground.
Old 05-08-2012, 06:07 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
i have the same thing. just hold the brake longer 2-3 sec after u turned the car off.
Old 05-08-2012, 08:01 PM
bobbrum bobbrum is offline
Mein Auto: 2003 745Li
Yes, that is normal. The 7 is anxious to do more driving after it is parked
Old 05-09-2012, 07:41 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
That "jump" is the car locking into the transmission. It should do it on level ground or any decline/incline.
HID Guide
LED Guide
Old 05-09-2012, 08:32 AM
Mein Auto: 745i
i dont know bro, i will try a make a quick vid, i was thinking its about time to change the guibo and seals on the drive shaft because i also sometimes hear a "ping" when i put it into drive.
Old 05-09-2012, 08:39 AM
canuckdon canuckdon is offline
Mein Auto: 2008 750Li
My understanding is the parking brake works on all 4 wheels when the engine is running, and when you shut the ignition off, only the rear brakes are held, so if there is any loading on the suspension, then when the front brakes are released, a small movement may occur.
Old 05-09-2012, 08:47 AM
Mein Auto: 745i
that makes sense, ive never really put the car in park without the pressing the brake button, i'll try it out.
Old 05-09-2012, 09:39 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
The car should not be jumping forward in any way whether you are on an incline or flat. At most you should feel some slight movement when the parking brake is applied and you take your foot of the brake as the suspension relaxes.
The fact that you are feeling something different that you didnt experience before means that something is wrong. Does the car jump forward when coming to a stop with the engine on? or does it only happen after you are parked and you turn off the car and release the brake.
Old 05-09-2012, 09:47 AM
Mein Auto: 745i
it only happens when i turn the car off, while the car is on nothing. i'll try to load a vid so you guys can see.
Old 05-09-2012, 11:52 AM
politby's Avatar
politby politby is offline
Mein Auto: 2005 750i
Same symptom here. I am thinking maybe it is something with the control arm bushings.
Old 05-09-2012, 01:24 PM
both my 03 and my 08 did/do it, I think it's normal operation.
Old 05-09-2012, 01:45 PM
mj745's Avatar
mj745 mj745 is offline
Mein Auto: 2002 BMW 745Li
I've never had this issue and mine was a problematic 7. No, it's not normal.
<a href=http://imageshack.us/photo/my-images/850/bmw745lipics066.jpg/ target=_blank><img src=http://img850.imageshack.us/img850/6987/bmw745lipics066.jpg border=0 alt= /></a>[/URL]
Old 05-09-2012, 02:52 PM
do you always engage your parkinig brake? try stopping, then with foot brake on, but still in drive, engage the parking brake, then put in park, release foot brake, and then stop engine, usually about 2-3 seaconds after engine stops, the car will move, sometimes almost imperceptibly, other times quite obvious. Hoping this is normal, but maybe there is something up.??
Old 05-09-2012, 04:05 PM
DFEL750I's Avatar
Mein Auto: 750I
That's a weird coincidence because mine does not do this. Maybe both of your cars had the same issue or you are doing something weird when shutting the card down. The car shouldn't be jumping.
Old 05-09-2012, 04:36 PM
mj745's Avatar
This is a "common" problem with BMW, but that doesn't mean it's "normal". Just like many other "common" problems our 7's have that aren't normal.
Anyone who has this issue and thinks it is or was told by dealer it is normal are in denial. A car, especially of this status, should not "jerk" or "move" suddenly forward when turning the car off. That's just ridiulous. If you happen to park close to a wall or a car in front of you then that sudden jerk might just smash your 7's front. Have it looked over by a good Indy or the Sdealer. I remember when my car was having jerking reactions in low gear I was told by Toronto dealer that it was "normal" - what a douche*!
Old 05-09-2012, 06:07 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
mine doesnt jump anywhere!
'03 745i - modded - GONE -
Old 05-09-2012, 06:19 PM
pelonx1st's Avatar
pelonx1st pelonx1st is offline
()_:_:_))_C_A_M_E_L_)
Send a message via Yahoo to pelonx1st
Mein Auto: BMW 745LI
The only thing that my car jumps is other cars wonk wonk wonk*
ONLY E66 IN THE WORLD RESPECTED IN THE STANCE COMMUNITY -STANCE APPROVED-
Old 05-09-2012, 09:25 PM
TUF-FKR TUF-FKR is offline
Mein Auto: 2002 BMW 745i
My car does the same exact thing. It moves about 2" after I completely shut down (Put in P, Parking brake on, shut engine down). Slight jerk. Dont know?! Mine has always done that. No other transmission issues to report. Just emissions right now...
Old 05-10-2012, 11:34 AM
Mein Auto: 745i
exactly, no trans problems as well
Old 05-10-2012, 12:15 PM
DFEL750I's Avatar
Mein Auto: 750I
If you guys want to convince yourself that this is normal because it is a common problem then by all means go ahead. I didnt know that I had an issue with my logic 7 amp until I heard one that worked right because most of them out there are broken.
Also seems like people are decribing different things. It is normal for the car to move slightly when the suspension relaxes but not lurch forward in any way. Most people out there with older 7 maybe have issues with the driveshaft flex disk or other components with the suspension with worn bushing extra that can cause things like this.
Old 05-10-2012, 01:16 PM
My car doesn't 'lurch' forward, and its probably never more than a 1/2 inch, but it does move. I'll mention it to the stealer next time it is in.
Old 12-06-2012, 10:34 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Sorry to bring up an old thread but I was told when you apply the parking brake while the car is ON it applies with brake fluid like normal brakes. When you shut the car off and get that jerk it's because it is engaging the mechanical parking break and releasing the "actual brakes".
Old 12-07-2012, 12:01 AM
CJ745NZ CJ745NZ is offline
Mein Auto: 2002 745i
Correct. When the engine is running the hydraulic system activates all 4 brakes as if you are sitting with your foot on the brake. When you shut the engine off the hydraulics stop working and the mechanical park brake grips only the rear brakes. You will get a slight 'kick' as the park brake takes over.
