E34 (1989 - 1995)
Old 05-08-2012, 05:39 PM
flip_232 flip_232 is offline
Mein Auto: 525i
Question Engine cut out when warm on acceleration?
Hey I have been using this site for info for years, but now I need help. I have a 1992 525i inline six cylinder, the issue is the engine cuts out and back in while accelerating and dies sometimes the check engine light comes on because the motor is cutting out but doesnt leave any codes. This only happens after it gets to normal temp and gets worse till you almost cant drive anymore. I had it in a repudible shop( didnt charge me a cent) for three weeks chasing dead ends all the normal stuff checks out. I cleaned the ignition control valve to no joy. the fuel pump checks out good too, I would love any input or advise on where and what to check next, directions would be good too as I am mechanically inclinded but not a heavy bmw guy. (I am not a profesional speller either )
Old 05-08-2012, 06:06 PM
nwilson44 nwilson44 is offline
Mein Auto: 2002 BMW 540i/6
Are you using premium fuel? Dumb question but it makes a difference
Old 05-08-2012, 06:38 PM
Mein Auto: 525i
Yes, i am running premium fuel and I seafoamed it to clean out bulid up.
Old 05-08-2012, 07:22 PM
Mein Auto: 525i
I do see there are alot of similar issues on here but I would like a logical list of checks or fixes to start with. Thank you all again... in advance.
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Check the crankshaft position sensor. The instructions are clearly spelled out in the Bentley manual .... however ..... the resistance reading posted in the manual is incorrect. The manual lists 1280 +/- 10%. It should be 540 +/- 10%. Usually, the car will just stop running when the CPS goes out, however, sometimes they do create problems like yours.
However, the camshaft position sensor should be 1280 +/- 10%. It too can cause engine running problems like yours. They are not as common of a fail item though, but still, worth checking.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-09-2012, 12:16 AM
Banned
Mein Auto: car
Clean out your throttle position sensor. It is located right next to your throttle body. Contact cleaner and soft rubbing would suffice, on both the tps and its connector. Then take your car for another test drive.
Please change out your crankshaft position sensor if you haven't already done so in the past 5 years. The sensor will fail on your car leading to no start situations. While I have not heard of buggy crank sensors causing problems as you've described, the sensor's resistance changes as the temperature increases, and if its slightly weak, the resistance may indeed increase to above a usable range once the engine (and the sensor) is hot. Furthermore, check the sensor's wires...there might be a break somewhere and it may be shorting to ground etc when the car is in motion.
Start your engine and bring it up to operating temp. Then, leaving it at neutral, rev your engine and see if it cuts out like it does when you are driving. If it doesn't, its likely some worn wiring/insulation that gets juddered about when the car is in motion.
Old 05-09-2012, 08:50 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
This has absolutely nothing to do with TPS and don't touch your CPS; if CPS fails your car would never start if you are using OEM part.
  1. Fuel delivery problems due to bad fuel pump/filter/injectors
  2. MAF or POST MAF air leak
Focus on those.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 05-09-2012, 08:55 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Focus on those.
i agree with poor fuel delivery.
Pull injectors, have them cleaned if (probably dirty).
Replace fuel filter
Check spark plugs for wear, running rich/lean whatever. they could provide the answer.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 05-09-2012, 01:49 PM
Mein Auto: 525i
I have cleaned the MAF and I cant find any air leaks, The engine is just shutting off for a second then comes back on and the check engine light fashes as it shuts off and on rapidly if you let off the throttle it comes back on and if you apply the throttle lightly you can continue going, but sometimes it just flips on and off till you have to stop and then it dies, but it will start right back up like nothing is wrong. It is not storing a code so this is very hard to diagnose. I will check the injectors and check the pump again. Thank you all for being helpfull This car is getting more love(in the last few weeks) than it has gotten in a long time...lol
oh I will check the plugs too.
Old 05-09-2012, 02:42 PM
1995i540's Avatar
Founder @ Maintenr
Check your fuel delivery.
Old 05-09-2012, 02:53 PM
Mein Auto: 525i
What do you mean by fuel delivery? does this mean fuel lines or something else Im not sure it is a fuel problem how does the engine being warm affect a pump in the rear of the car? If the injectors where dirty wouldnt the problem happen all the time and not just when it was warm I need some more info please.
Old 05-09-2012, 03:21 PM
BMR_LVR's Avatar
Humble E34 lover
As 1995i540 suggested, check your fuel pressure when warm.
Hmm ... problems with driveability when warm. One possibility is a bad O2 sensor.
This is a remote possibility, but the DME may be failing. It sounds as if the engine just loses signal to run.
Don't suppose you know of anyone who has a DME you could borrow do you? If so, you could swap it out to see if that is the problem. I certainly would not advocate buying another one without finding some way to define that as the problem for sure. Fortunately, they are relatively inexpensive used ($50 and up depending on where you find one).
Good luck and keep us posted.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-09-2012, 06:55 PM
1995i540's Avatar
Founder @ Maintenr
Fuel pressure and PSI retention along with flow check.
Old 05-09-2012, 10:19 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I'm leaning toward fuel pump.But it could also be the White main engine relay wearing out,or the Blue fuel pump relay acting up .loose battery connections, low battery voltage, loose power or ground connections in engine bay. you will have to test and swap out many things to test and identify the culprit. I would preform the stomp test for possiable injector codes. And how old are your coils?.
Old 05-10-2012, 10:10 AM
Mein Auto: 525i
I have done the stomp test many times and it doesnt show any codes, I am not sure of the coils age but the shop I had it in said they checked out good. Does the Fuel pump fail this way where it will randomly cut out as described above only when the engine is warm? I have no issues when the car is cold.
Old 05-17-2012, 09:41 PM
luckydog's Avatar
try changing the fuel filter ,that solved my hesitation issues on acceleration.
Old 05-17-2012, 09:52 PM
Mein Auto: 1989 525i M20B25
^+1
This is the simplest thing to start with. Do it.
Besides, you probably aren't going to check your fuel pressure with an actual gauge anyway.
The fact that it runs poorly at a higher temp may just mean nothing except the fuel filter.
The fact is, the fuel filter is a good place to start. You don't know when it was replaced(you are supposed to replace it, part of maint. interval), so how do you know its not starving your engine of fuel at higher temps while accelerating when the ecu calls for more fuel?
JUST CHANGE IT!
1.relive fuel pressure by going to the fusebox and pulling the fuel pump fuse while the engine is running.
2.let it die, takes several seconds.
3. get your hose clamp socket and remove the probably factory hose clamps from the fuel filter.
4.remove lines and clean up spilled fuel, replace filter noting the direction of original filter. Dontforgretdontforgetdontforget.
5.reverse it up
a nice write-up:
http://www.bmwe34.net/E34main/Mainte...ce/Filters.htm
Old 05-16-2014, 04:10 AM
Schlander Schlander is offline
Mein Auto: E30 325i 4d. M-tech II
Did you find the problem?
Freude am Fahren!
Old 05-16-2014, 05:40 AM
capricornbmw capricornbmw is offline
Banned
Mein Auto: E36
Focus on those.
This is completely wrong.
The tps is the No1 culprit when it comes to engine cut outs while driving. It has been known to happen before and it is ****ing dangerous. A new oem (hella, bosch, valeo, bmw) replacement only cost $45 shipped and 5 minutes to swop out. I advise everyone purchasing an E34 to change this out to new as a form of insurance.
The diagnosis of this itself is simple. Just unplug the tps. The problem will disappear.
Obviously, every sensor on the car has its function. When the sensor goes bad or is disconnected, the dme substitutes default safe factory values in its place, which are never going to be as precise as live data. Thus, once a bad sensor is identified, it should be replaced. However, the default factory values have been tested to avoid problems as well. This is a general principle. When it comes to the tps, we're talking about basic safety....the first time the sensor tells you that it is busted is when it cuts your engine (and thus your power steering and to some extent your brakes) while travelling at speed on the highway. So we don't wait for that when it comes to the tps.
Fuel starvation issues do not manifest as engine cutouts, they come across as severe underpoweredness due to a simple lack of fuel. They are not usually temperature related (when due to a clogged filter especially).
The other possibility and this is far out, is a bad dme, a bad main relay, intermittent relay contact for the fuel and main relays, and a bad dizzy cap/rotor assembly. Ignition problems resulting in engine cutouts are practically unheard off for coil-on-plug systems....you'll get misfiring, bad idle, underpowerdness, rough engine, but no cut out, if a plug or coil suddenly goes.
To the Schlander, these are the things you should do (I'm assuming you have the same problem) :
1. Do the stomp test and see if there are useful error codes. The problem might already be flagged there although at least 1/3 of the time, the ecu keeps failing sensors online, the E34-era fault code reporting system was not very sensitive as yet. Take note, fuel trim codes have alot to do with poor fuel delivery.
2. Unplug the tps. Its to the right of your throttle body. Please check the bentley manual and google if need be.
3. If the problem disappears, then you've found your culprit. Get the tps immediately., If it doesn't, get a new oem tps and replace it within 30 days anyway.
4. Take out your fuel filter and immerse it in a bath of fresh water. Drain out from both ends. Do this 5 times until only clear water comes out. Shake dry from both ends and reinstall (in the correct direction). Key2 for 60 seconds to repressurise the filter and rail, then start the engine.
5. If the fuel filter is just too old, replace it with a new one its only $15. Service it once a year to keep it in good shape, and change it at 3 times the recommended interval. If not you'll have to stick to the recommended interval (50k I believe).
6. Fuel pressure - one temporary, semi-accurate way you can check if low fuel pressure is an issue (or at least take it out of the equation), is to remove the vacuum hose from the fuel pressure regulator and stop the hose up to prevent a vacuum leak. Removing the vacuum hose increases rail pressure. Of course, your fuel consumption is going to suffer but treat this as a simple diagnostic procedure.
7. Check the engine, intake, valve cover, and ccv system, and intake hoses etc for cracks and vacuum leaks. Google for more info about how to do this effectively. Very severe vacuum leaks can cause engine cut outs but then during idle the engine runs very rough so that's probably not the case here.
Carry out some of the suggestions I've made here and report back with your observations.
Old 05-16-2014, 07:05 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
:r ofl::rof l:
Oh, Roberto
Take my advice, I'm not using it.
Old 05-17-2014, 06:00 AM
Mamij Mamij is offline
Banned
Mein Auto: BMW 320i M52 1996
Originally Posted by ross1 View Post
:r ofl::rof l:
Oh, Roberto
Not everyone fails to read the archives and fails to learn from our giants, Ross. BTW we are still waiting on you to explain how pressurised steam removes hard carbon from piston tops, or provide some scientific literature to suggest that it may be possible.
Of course asking you to get off your butt and do some actual research may be a stretch for someone who cites his shade tree mechanic rep as a good enough answer for everything.
FYI all non chemical particulate filters can be washed or rinsed out, just like a coffee sock. Oil filters however are too impractical and messy for this and they are cheap. Fuel and air filters are easy to refresh by contrast. Your foolishness does not change science, it only adds to your ill reputation.
Old 05-17-2014, 07:35 AM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, '95 525it
I love it when Capricorn and Mamij post in tandem. It reminds me of the old Shari Lewis show. Remember Lamb Chop?
Ah, it was good to be a Boomer child.
Old 05-17-2014, 10:26 AM
Banned
Mein Auto: E36
And when you and Ross1 post, its like the laurel and hardy show. But there was a semblance of intelligence there. So maybe its more apropos to compare you guys to two of the 3 stooges ?
accelartion studder, cut out, electircal problem, engine bucks
