F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#226
@DreamCar; Sorry, I didn't test either color lines/color switch or comfort opening.
The Siemens VDO and Mobileye N.V. based Lane Departure Warning System (LDWS) consists of a high dynamic range digital CMOS camera in the mirror housing and a high performance electronic control unit. The same camera is also used for the Speed Limit Info System (SLIS), and the Automatic High Beams System (AHBS). What's unclear though is if it uses the same ECU for all 3 systems, or multiple ECU's, which if it is the latter, just having LDWS by itself won't get you SLIS and /or AHBS. As far as I know, the SLIS is only available in the 7-Series, the 5-Series GT, the Active 5 Hybrid, the M5, and the F30, and even then I do not believe so for stateside versions. I am inclined to think this would be something that maybe could be retrofitted, but I doubt simply coded to work.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#227
I have completed the torrent download and will seed. Keep up the good work.
By the way, is there any store where I could buy the OBDII plug ? I am from Malaysia but will travel to California end of this month. I would like to pick up the required cable or OBDII connectors while there. I just need to build the cable, and then after that can give some feedback on Asian production cars and Right Hand Drive models using the E-sys. Thanks |
#228
Ok this is confusing and puzzling!
Alex_c and Shawn see if this makes any sense. My car already show gears in D/S mode i thought it is default I checked the "KOMBI--3000 Anzeige Konfiguration--SPA_SPORT_ENABLE" and it is not aktiv But i have activated "KOMBI--3003 FZG_Ausstattung--SPA_ENABLE" Yesterday may be this option gives gear recomendation for manual and show gears for Auto i just activated "KOMBI--3000 Anzeige Konfiguration--SPA_SPORT_ENABLE" and test drove to see any additional info details are diaplsyed but no luck. Last edited by DreamCar; 05-15-2012 at 07:43 PM. |
#229
Shawn,
I have LDWS and AHBS... not sure if it makes it easier |
#230
Update:
EFF_DYN_SYS_CID is already aktiv in my car i have eco pro mode and i see histograms and it allows me to select the eco pro tips when i am in eco pro mode! in eco pro mode i see icons on the cluster to move to D mode if i am in D/S mode and it also indicates to ease on accelerator (These are part of tips). |
#231
I've downloaded the file that hans_gregor posted and I'm currently in the process of downloading via the torrent that rlsolomon posted (I plan on seeding once the download is complete). What is the difference between these two downloads? I noticed that one is 150MB and the other one (torrent) is over 10GB.
#232
Can someone confirm this to work with just changing the values with E-sys and not what the cheat cheat states NETTODAT files???
#233
@cn555ic; Yes, with E-Sys only. The NETTODAT files do not need editing.
#234
@bigken620; The 150 Mb one should be E-Sys only, and the 10Gb should be the v. 46.1 psdzdata from ISTA/P, which may also include the E-Sys program. You need both E-Sys and the psdzdata to code.
#235
@DreamCar; The only time I get a Gear Indication is in M1-M8. In DS Mode I get nothing, but that may be because I do not have the Extended Black Panel Display. Since I already enabled KOMBI / 3003 FZG_Ausstattung / SPA_ENABLE, I will try also enabling KOMBI /3000 Anzeige Konfiguration / SPA_SPORT_ENABLE and see if anything happens. FWIW, Ausstattung = Equipment and Anzeige = Display.
For EFF_DYN_SYS_CID, I take it then you are also getting the Efficient Dynamics screen with the Climate and Battery animations?
#236
Thanks Shawn, then the spreadsheet which is the holy Grail needs to be edited!
#237
@cn555ic; I submitted an updated version to DreamCar earlier this evening. He will put it up after he incorporates any of his findings or notes.
#238
Shawn
Yes i have climate animation but not sure about battery animation. We need to look why we have spa-enable and spa_sport_enable.,, Last edited by DreamCar; 05-15-2012 at 08:58 PM. |
#239
Shawn - I was fooling around with various modules (mostly KOMBI) and enabled a bunch of options for SPEEDLIMIT (just searched and enabled). I ended up having the red circle appear in the BC area of my cluster with --- as the read out. I have the DA package and requisite cameras, and am aware they all share the same function. Do you have any idea which module is the camera itself? I haven't really had the time to read coding from everything.
As for the sport displays, still nothing. I've been hunting around, searching in both english and german to see if I can find anything. I suspect it has to do with ECO PRO. Searching on Google revealed that some other cars support this (non-F10) so I suspect it's just a matter of enabling something else.
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
#240
@alex_c: The "Spirit of Ecstasy" won't display. It just adds an option to extend or retract the figure on the front of a properly equipped Rolls. BMW's iDrive system (with different branding) is used in those cars.
#241
I know... I just thought it was funny that they would leave that in the configuration options for the F10
It's a curious option, but leads me to believe that there's a lot of flexibility in this system that we haven't explored yet.
#243
I wanted to increase the Ambilight and activated HELLIGKEIT_AMBILIGHT. I got a new entry in the Light Menu, but I could not adjust it.
#244
Mobelium
I think you have activated the switch ..now you have to find the system (if exists ) and activate that too which h responds to this switch ...just my assumption Also if adjusting scroller will adjust the reading here? Last edited by DreamCar; 05-16-2012 at 03:17 AM. |
#245
Wdimagineer ,
That's the feeling I had initially but until unless we get some sort of kmowldege transfer/hardware support we keep on hitting dead ends! Hope you will figure out the speed limit info I so want it ! |
#246
Who was it (from Boston?) who was swearing up and down this was how his car worked and we all thought he was crazy? Now we know he wasn't! LOL.
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
#247
Updated post # 1 with new cheat sheet and some additional docs!
#248
WDImagineer,
Did you also enebale speed limit generation in Kombi-3000? |
#249
How in the world did you get Modular3fox to allow his PDF to be printed and not locked!!!!...I asked numerous times for this to happen and thus why I got banned from BMWcoding forum!!! LMAO This is awesome and thanks for the updated cheatsheet!
#250
KOMBI 3008 PIA Drehmoment Leistung I know itīs for KOMBI, but.... |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
