Closed Thread
Old 05-28-2012, 06:14 PM
mjgood mjgood is offline
Mein Auto: 2011 550i M-Sport
@Sharbotcom... when I added 6NF I initially used the "code FDL" button but it didn't take until I used the "code" button... that is where the instructions get a bit ambiguous...
2011 550i M-Sport
2011 Countryman S
Bell 407
  #1077
Old 05-28-2012, 06:44 PM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
Hans,
Are you using the Country code 3 and Unit code 4?
  #1078
Old 05-28-2012, 06:52 PM
hans_gregor hans_gregor is offline
Mein Auto: Cars
Originally Posted by DreamCar View Post
Hans,
in KAFAS
3010 -> COUNTRY CODING DISPLAY = wert_3
3010 -> UNIT DISPLAy = wert_4
3020 -> COUNTRY_VARIATION = wert_4
  #1079
Old 05-28-2012, 06:59 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Hans
are you referring to Country_code_display in 3010
These are my setting with 30-40% luck
3010 -> Country_code_display = wert_3
3020 -> COUNTRY_VARIATION = wert_3
  #1080
Old 05-28-2012, 07:04 PM
Mein Auto: Cars
Hans
yes, I corrected.
  #1081
Old 05-28-2012, 07:18 PM
svache's Avatar
svache svache is offline
Mein Auto: 2012 F30 328i
@Hans: I was able to test the cameras today and see what the speeds do (I didn't code or anything this time, just looked at how it worked). It's kind of funny... at low speeds both the TV and RV cameras will shut down after about 0.2 mile, so I'm guessing that's about 255 meters. However, at high speeds (on the freeway), the TV camera stayed on for several miles, it didn't seem to care how long it was on. The RV camera just shut down after 0.2 mile again, even with high speeds. Kind of odd the TV camera didn't do this at that point.
@Shawn: I tried to compare HP and KW when I was out and, to be honest, I don't trust either of them right now. It's probably a gimmick for entertainment purposes or something but nothing too serious. Thing is, both KW and HP gave me the same maximum setting: 240. For HP this would be correct for my 328i but for KW it is way too much, KW shouldn't be higher than about 180 (about 25% of the max HP). So, either the value is totally wrong when it is on KW and it is already showing HP, or it is just not to be trusted at all.
Anyways, I am only shortly at home, I'm about to go out again but I figured I would let you guys know about these findings first
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol)
Retired: '09 E70 X5, '04 E46 M3
  #1082
Old 05-28-2012, 07:23 PM
Sharbotcom Sharbotcom is offline
Mein Auto: F10 535xi MSport
Hans
I'm currently set to country_variation = wert_4 and I get a message that it is not supported in this country. I'll change it to 3 to see what it does.
As far unit_display go is wert_4 KM or MLS?
BTW I at least have it coming up now.
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, M Sport Package, 316, 322, 3AG, 5AD, 5AG, 5DL, 609, 620, 655, 677, 6FL delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
  #1083
Old 05-28-2012, 07:26 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Shartbot
You will get message if you are in generation 1 for sli generation change it to 2
  #1084
mj
I re-read everything and had to reset some values that clobbered but everything is in and sticking. The display comes up but does not read 1 darn sign. I also get the message that it is not supported in this country.
Bill
  #1085
Old 05-28-2012, 07:27 PM
Mein Auto: Cars
mine it shows km
and change it to sli_gen2 (in KOMBI 3000 SPEED LIMIT GENERATION)
  #1086
Old 05-28-2012, 07:28 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Shartbot you have to change the sli generation
  #1087
Shartbot
Ok...which area do I find the generation settings?
TIA
  #1088
Old 05-28-2012, 07:29 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Werte 4 will take the value from cic so it Will be werte 4 for everybody
  #1089
Old 05-28-2012, 07:32 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Hans
Did you change the country variation 3020? or is it 4 by default?
  #1090
Old 05-28-2012, 07:33 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Sharbot it should be in Kombox if not in HUCIC search for SLI
  #1091
Hans
That was the default
  #1092
Old 05-28-2012, 07:35 PM
Mein Auto: Cars
do you think that I remember what was by default?
  #1093
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Ok i think i asked wrong question so Hans changed it from 4 to 3
  #1094
Old 05-28-2012, 08:16 PM
1STBimmer 1STBimmer is offline
Mein Auto: 550i GT/X5 35d
Just found how to default the High Beam Assistant to Automatic on.
FRM ecu.
Under 3050 FRM_AUSSENLICHT_PARAMETER, 30 - Set FLA_AUTO_AKTIV to 'automatisch' (set to manual by default).
Now when the headlights turn on at night the auto headlights is automatically turned on as well, still can be disabled via left stalk button if needed.
  #1095
Old 05-28-2012, 08:20 PM
Ok, now I have the 3 dashes all the time. When I had it set to generation 1 I got the white square. Now with generation 2 I only get the dashes. Took the machine out for a quick test run and passed 27 speed signs. Alas, only dashes
  #1096
Old 05-28-2012, 08:28 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
Sharbot,
We both are at similar level it's only Hans who has high percentage .,,
Give it a day or so .,,it will pick when you least expect it.
I am assuming you changed all the parameters in hu CIC and kombi
  #1097
Mein Auto: Cars
svache,
can you change kafas2 -> 3010 -> COUNTRY_CODING_DISPLAY from country_specific to US_white, and let us know the results?
  #1098
Old 05-28-2012, 08:34 PM
wdimagineer's Avatar
wdimagineer wdimagineer is offline
Mein Auto: 2013 M5
Anybody with SLI from the factory care to chime in on this? Just curious what HU_CIC -> 3001 -> KOMBI_CIC is set to. Mine is set to kombi_mid. But there is a high option. Just wondering...
Current: 2014 X5 xDrive50i ZMM - Alpine White/Mocha (Mods In Progress!)
Past: 2014 Jeep SRT - 2013 Tesla Model S P85+ - Bimmerpost Featured 2013 F10 M5 - 2012 550 xDrive - 2011 M3 ZCP
  #1099
Old 05-28-2012, 08:36 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
WD ,
I checked it with Svache he has sli from factory and it is in mid
  #1100
Old 05-28-2012, 08:38 PM
Mein Auto: 2013 M5
Thanks, Dream. I'm just going through modules, trying to dig. @hans/svache: Is that KAFAS2 option a specific module in his car? When I go to that same setting in mine I don't get options like "US_white".
Hopefully we can break this thread up into subforums to make it a bit easier to keep track. I'm still very much game for this.
Closed Thread
