Closed Thread
Old 06-01-2012, 01:00 PM
clutchlee clutchlee is offline
Mein Auto: BMW
If anyone is interested, I have a Coding Cable that works for the f10 $50 shipped (USA only). I tested it and everything. PM me if you're interested.
  #1302
Old 06-01-2012, 01:03 PM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
Folks
Let us not use this thread for classifieds...thats not the purpose of thsi thread....No offense to any one!.
  #1303
Old 06-01-2012, 01:45 PM
svache's Avatar
svache svache is offline
Mein Auto: 2012 F30 328i
'12 F30 328i w/ A17, LCLY, ZLL/7S2, ZCW, ZDA, ZPK, ZPP, ZPS, ZTP, 205, 2VL, 302, 3DZ, 415, 417, 522, 524, 5AC, 5AP, 5DP, 615, 6AA, 6AB, 6NF, 6NL, 6NR, 6UH, 6VA, 6WA, 8S4, 8TH (yes, that's all lol)
Retired: '09 E70 X5, '04 E46 M3
  #1304
Old 06-01-2012, 01:50 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by yreiser View Post
Ok, but what do you mean exactly with CODE (Not FDL), since, till now, I only know about how to code FDL?
The Code button is just to the left of the Code FDL button.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
  #1305
Old 06-01-2012, 01:53 PM
@clutchlee;
Why are you selling your cable? Do you have another one? With people making their own or getting them from Sean for $15, it will be hard to move in here for $50.
  #1306
Old 06-01-2012, 02:10 PM
@dmunz;
For opening, what do your current Dash Button(s) and Fob Buttons 3 & 4 open?
  #1307
Old 06-01-2012, 02:12 PM
@ISTBimmer;
For both USE_FBD4 and OPEN_RSCR_WITH_PUBU_A_PILLAR listed, you wrote aktiv / Werte=00.
Are you sure this isn't Werte=01?
  #1308
Old 06-01-2012, 04:20 PM
dmunz dmunz is offline
Mein Auto: 535i GT
Originally Posted by shawnsheridan View Post
@dmunz;
I don't have any dash buttons. I have a hatch button on the floor panel (near whe the OBD port is). It opens the big hatch.
Fob 3 opens the big hatch. .
Fob 4 opens the small lid (this is described in the manual.)
Nothing closes the hatch as far as I know.
FWIW
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
  #1309
Old 06-01-2012, 04:21 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
I had a friend who installed LED reverse lights for whatever reason I dont know why! lol Anyway he is getting bulb errors for the reverse lights. I tried to look in the FRM module to try and code out the warm and cold checks for the reverse lights but for the life of me I could not find it...Does anyone know what I need to do to remove that specific bulb error. I tried to look for a similar line to the E90s but I could not find anything kaltueberwachung_rl (warm check reverse light) Anyone can help I would appreciate it!
  #1310
Old 06-01-2012, 04:57 PM
ello888 ello888 is offline
Mein Auto: BMW
thanks shawn
I believe I have the exact same settine as 1stBimmer posted, that is 00 where it shoud be or 01 where it should be. I will repost here but if incorrect, please let me know? sorry, bad eye
REAR_SCREEN_IS_PRIMARY -- nicht_aktiv/Werte=00 (Original aktiv/Werte=01)
OPEN_RSCR_WITH_REMOTE_KEY_SPFN -- aktiv/Werte=01 (Original nicht_aktiv/Werte=00)
OPEN_RSCR_WITH_PUBU_A_PILLAR -- nicht_aktiv/Werte=00 (Original aktiv/Werte=01)
SCH_TOEHKI -- aktiv/Werte=01 (Original nicht_aktiv/Werte=00)
TASTER_FBD -- aktiv/Werte=01 (Original nicht_aktiv/Werte=00)
USE_FBD4 -- nicht_aktiv/Werte=00 (ORIGINAL aktiv/Werte=01)
SCH_FBD -- aktiv/Werte=01 (Original aktiv/Werte=01)
REMOTE_KEY_SPECIAL_FCT -- aktiv/Werte=01 (Original aktiv/Werte=01)
I am also glad that 1stBimmer now see what I mean with the loaner!
someone asked was my car coded by factory with fob to open the big and small hatch, answer is YES, my car did come coded that way. My problem was that the button inside the car, factory coding was to open small hatch which is pointless.
After the above changes put in, I now have:
1) inside car button open the big hatch (used to be open small hatch)
2) 3rd button on fob open the big hatch (used to be open small hatch)
3) 4th button on fob open the small hatch (used to be open small hatch)
4) 4th button on fob close the big hatch (same as before)
I would like to have a (5) which is inside car button CLOSE the big hatch. If I can swap the fob close so that 3rd button close the big hatch instead of the 4th, I will be more happier but as-is is just as good.
shawn, got your point about coding one at a time but I was on battery at the time and didn't want the car on battery too long. Couldn't find a plut to plug me charger in at the time...
@ello888;
First, the Trunk / Hatch close takes a while before it begins working. Did you leave the vehicle off for an hour or so before testing the Close functionality?
1STBimmer had both USE_FBD4 and OPEN_RSCR_WITH_PUBU_A_PILLAR listed, and now you do too, as aktiv / Werte=00. Are you sure this isn't Werte=01?
Did you change all 4 (or 6 depending on the above aktiv / Werte=00 setting) of these parameters at once? It is best to change one at a time, and then test, to gauge the actual impact.
So if I understand correctly, now the Big Hatch Opens with Fob Button 3 and Closes with Fob Button 4, which is opposite as it was, and the Dash Button opens the Big Hatch, also opposite as it was, and Fob Button 4 Closes the Big hatch.
Before these changes, did either the Dash Button or Buttons 3 or 4 on the Fob close anything?
  #1311
Old 06-01-2012, 06:03 PM
ello888;
In Ref:
I think you meant (used to be open big hatch), correct?
Are you positive you have HKFM / 3010 HKL_BEDIENUNG / SCH_FBD enabled, as that should work the interior button for closing?
As for the car charge issue....I code my car in my driveway with the Engine Running.
  #1312
Old 06-01-2012, 06:17 PM
Mein Auto: BMW
Thanks shawn. much appreciated for following up
Yes, I meant:
3) 4th button on fob open the small hatch (used to be open/close BIG hatch)
SCH_FBD should be active 01. see attached
ello888;
In Ref:
  #1313
Old 06-01-2012, 06:19 PM
Mein Auto: BMW
i was afraid that having the car ignation on, and have module coding which involve reseting and rebooting module, will lead to system error.
i guess you proved it won't!
ello888;
In Ref:
  #1314
Old 06-01-2012, 06:24 PM
1STBimmer 1STBimmer is offline
Mein Auto: 550i GT/X5 35d
ello888,
The button inside my car opens AND closes the big hatch, we'll find a way to get it to work like that on yours.
Also...my 3rd button on the fob opens and closes the big hatch as well. Button #4 only opens the small hatch (and is also now the panic button, btw).
EVERYTHING in the loaner (and presumably yours too) works opposite of mine. On mine, the button in the middle of the trunk lid opens the big hatch, the one to the right opens the boot lid...On the loaner it works the exact opposite, which means everything is programmable.
I already read the cafs' on the loaner but havent had time to sit down and look at them side by side with mine...Probably will get some clarity once I can do that. (I already coded the digital speed on the loaner because it doesn't have a hud )
  #1315
Old 06-01-2012, 06:26 PM
@shawn:
Glad to know that I'm not the only one!! The GT not so much, but the X5 will start throwing the 'low battery' error after being hooked up for maybe 10 minutes so I resorted to keeping it running while I code it.
ello888;
  #1316
Old 06-01-2012, 07:02 PM
Mein Auto: bmw
Has anyone messed around with bulb error checks. I would explore this if I had the car but I was only able to have access with it for 1/2 hour. On a side note I was Able to code rear trunk opening and closing with keyfob. I bugged out as the first time I attempted to code it, when it finished the coding fdl it gave me two errors. I was nervous. I went back into the module and for some reason the codes didn't take effect, so I did it again and this time after pressing code FDL it finished without errors. Went immediately to try it out And it worked! I was so relieved. I have no idea why the first time around it didn't work.
  #1317
Old 06-01-2012, 07:03 PM
Mein Auto: BMW
I usually keep mine with CTEK with supply mode. Assume that is enough juice to code and not having to use battery
I also just charged my battery last keek so my 20 mins of coding last night hopefully won't cause issue.
Can the CAF be exported to an excel so that a formula can be used to vlookup and compare?
Doing by the eye is a pain.
  #1318
Old 06-01-2012, 07:07 PM
Mein Auto: BMW
Coding with error was probably car went back to off mode, I.e. not turned on. I had a number of this issue and realise while cluster lights was on, the yellow engine light was off hence car weren't turned on this not coded
  #1319
Old 06-01-2012, 07:30 PM
Mein Auto: BMW
1stBimmer, wow just noted one more difference then. On mine, the button on the right of the trunk open the big hatch. The middle button open the small hatch.
Frankly, I am fine with all the buttons. In fact changing them would make me forget which is which. So if I can reverse the key fob to original, I will be happy.
All I want now is close on the inside button.
So 1stbimmer, can I confirm you have all that you needed and liked in your trunk operation? Big/small trunk, inside/key fob switch?
  #1320
Old 06-01-2012, 07:31 PM
@ISTBimmer,
What is your CAS / 3002 CLM / OPEN_BTL_RSCR_MUTEX set to?
I should have a look at @dmunz's GT this Sunday, so that will give us some more F07 data to stew over.
I assume you have an E70. What are you coding your X5 with? NCS Expert?
  #1321
Old 06-01-2012, 07:35 PM
Please...no more damn F07 Hatch buttons!
  #1322
Old 06-01-2012, 07:39 PM
DreamCar's Avatar
Moderator
Mein Auto: F10 M5
I was thinking to create separate hatch button thread.
  #1323
Old 06-01-2012, 08:14 PM
Mein Auto: bmw
Hmm maybe this is what it was then. I am just glad I did not brick the HKFM module, but the funny thing is I always check to see if ignition is on before I hit the final Code FDL button. This is one of my biggest fears when coding that the car goes into off mode when its in middle of coding. I was quite nervous when I seen the last screen with red writing instead of the green "0" error message.
  #1324
Old 06-01-2012, 08:20 PM
Mein Auto: bmw
Wait a minute! SHawn.....your telling me that we can code with the engine running? Really because that would be perfect because I was dying in the heat the other day coding this F10 and if I can have the car running and the AC working I will be nice and cozy! lol
  #1325
Old 06-01-2012, 08:21 PM
Besides the battery drain, going into off mode is another reason I code with the car running, and AC.
Closed Thread
