E46 (1999 - 2006)
Old 05-09-2012, 03:26 PM
toybits78 toybits78 is offline
Mein Auto: 2004 330ci
I need help please 330ci crank but wont start
Hello guy I'm new here and I dire in need of help. I got a 2004 330ci and this is the only time it happened to me. After driving back from San Diego to Lemoore Ca. I park my car on base. The next day when I started it started sluggish where it starts then slowly dies down, after I start it again and kinda rev the engine thinking it my stay on it did. Then the afternoon I tried to start it, wont start but it cranks. I checked all possible faults, like fuel smell coming out of the exhaust, burnt fuse and I also change the battery and still crank but wont start. To make it worst is the red battery light was on, but now hoping its not something crazy that I have to change, but if I have to then let me know. I need some advices from everybody on what to do next, the fuel pump runs good by the way. Please help me or show me to the right direction on solving this problem.
Old 05-09-2012, 03:49 PM
mvd mvd is offline
Mein Auto: 325 Ci 2004
there smarter people than me on here... but here's a start based on symptoms:
- fuel filter could be clogged
- fuel pump (I know you said it works, but sometimes it will make a sound but still be bad)
- sucking jet transfer pump (if less than 1/2 tank add some fuel and see is that works
do a search on these for more troubleshooting details
like I said, there are smarter folks on here, but it's a decent chance it's one of these
didn't quite get the battery light description. did you you kill your battery trying to start it AND NOW after putting a new battery in you're getting a red battery light???
Old 05-09-2012, 05:14 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
How did you determine this?
Old 05-09-2012, 06:27 PM
I need help on where to find the fuel filter? But the pump I can hear it working so I put that out. I got a bit over 1/4 right now coz i cant move the car due to it wont start. And about the transfer pump where can I find that in my car?
@smolk I based it on all the forums that I check all over the net, and also I been reading a couple of you post here and hoping you can help me out on my problem. As you can see that i tried almost everything but I want to get your opinion on my problem to my car. The pump well I kinda base it to a couple of the forums info, like is you hear it buzzing or whinning that means it works. But what do you think, I want to get your opinion or should I say your help. But also the starter is working since its cranking do you think? Well please I need your help and also please ask around too. Thank you in advance.
Old 05-09-2012, 06:34 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
Go get some 5 gallon gas cans and put some gas in it....the transfer pump is on the driver side, fuel pump is on the passenger side- both under back seat. DO a search as there is a lot of info on it. As stated above, if it is the transfer pump it will start when you get above half a tank full.
Battery light means there is something wrong with your alternator...but if it cranks it should start. Get a voltmeter and check volatge...battery should be at 12.4 to 12.6 volts static, at least 13.6 volts after you get is started
Old 05-09-2012, 06:46 PM
@QAfred: Would there a way to check the voltage using the test on the dashboard? Or I really need a voltmeter, I just put in a new battery. But I will try to put more gas in it and wish that works. But still I'll try to keep researching if that works. But thanks for the help, I will let you know if that works. But also would the spark plugs may cause it?
Old 05-09-2012, 06:54 PM
Your battery light will be on until you get it started....once started, if it does not go out, get a voltmeter and check for 13.6 volts at the battery...your dash will not be accurate enough.
Spark plugs would not cause a car not to start...they last forever on our cars...NGK's are the way to go IMO...but not your issue.
Fuel filter is under the car, right under Dirvers seat....you need to buy a Bentley's Manual for this simple info.
BTW...are you in the Navy? Thanks for serving...I did a 4 year hitch in a submarine patrol squadron...VP-6 out of Barbers Point Hawaii...tough duty ...LOL
Old 05-09-2012, 07:01 PM
smolck's Avatar
ROLL TIDE!
If you are hearing the pump prime that is a good sign. So you removed the back seat and checked that way?
Old 05-09-2012, 07:03 PM
@QAfred Cool I'm on my 13 years and almost done because high year tenure unless I make it to the next rank, and thank you by the way. So still have to check the volts on my battery eventhough its brand new? Is the fuel filter hard to change is its the culprit? Bust asl long as its not the starter or alternator I would be fine and im not gonna cough up alot for this repair.
Old 05-09-2012, 07:08 PM
If you have a battery light after it starts it is most likely the alternator...new battery has nothing to do with fixing the alternator which charges the battery.
fuel filter is not hard to change...just don't smoke or use a drop light etc...do it outdoors, flashlight only if you need light...get a manual or U-tube it.
Engine would not crank if it was a bad starter, bad alternator would not prevent a car from starting as long as the battery currently has 12.4 volts as it sits now.
get some gas and good luck!
Old 05-09-2012, 07:09 PM
@smolk I didnt removed the back seat but I can hear the buzzing sound from the front, but like what you said its priming. But I wish its nothing major and also if thats the case of the pump I will do it but I'll try to put some more gas in the to try it.
Old 05-09-2012, 07:56 PM
Does this site have an online store coz maybe if ever I can buy my stuff here and cheap.
Old 05-09-2012, 09:01 PM
Anybody know if there is a thread here with a store that I can buy what I need for this repair in case I need a part?
"Pinoy Power" "Powered by Rice and Balut"
Old 05-10-2012, 09:13 PM
ok guys i just put some gas in my car and still not starting up. but i will try to get someone to help me out to check is my fuel pump is not working im hoping that is the problem. but i got a question by the way other that humming or buzzing sound how do you know if the fuel pump is working.
Old 05-10-2012, 09:19 PM
By the way my still not starting up what else would be the problem if I rule out the pump and other parts?
Old 05-11-2012, 02:28 AM
Well guys Im gonna change the pump instead coz I think its the pump this time coz dont hear it.
Old 05-11-2012, 03:17 AM
Ok since im gonna change the fuel pump anybody can direct me to on how to remove the rear seat for a 2004 330ci. Please let me know, thank you
Old 05-11-2012, 04:32 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
To remove the rear seat, simply pull up on the front lower edge of the cushion, then pull forward. It comes right out.
There is no on-line store here, however, we have several site sponsors listed on the sponsor page. Many of them have great prices and fast shipping. Lately, a lot of us have been recommending www.oembimmerparts.com for their prices, fast shipping, and very knowledgeable staff.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 05-12-2012, 05:00 PM
@jonathan2263 thanks for the info.
By the way guys I found a pump for a cheaper price its 94.85 and free shipping thats cool. Hoping that it will come in soon so that I can fix my car so that I wont carpool at work. But well its cool carpooling coz it saves me money hehehehe lol. Thanks again guys.
Old 05-15-2012, 12:12 PM
RayC1 RayC1 is offline
Mein Auto: 325CiC, MDX, RAV4, GTI
Maybe your cheaper price is for the pump alone and not the assembly. The assembly can be dropped right in; not sure how difficult it is to change the pump alone. A new gasket is advised also.
Smolck asks the right questions again! Awesome.
Old 05-15-2012, 01:15 PM
@RayC1 I just bought from PartsGeek.com that's why its cheep and it says pump module assembly. Hoping I did it right since this is the first time my car got this problem.
