Old 05-09-2012, 06:47 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Power steering fluid (Which to use?)
Should I use "Red Line D4 Synthetic Power Steering Fluid" for my PS flush on a 03' 540i? If so should i get 1 or 2 quarts?
Just want to be 100%, as Bavauto says to check prior.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 05-09-2012, 07:00 PM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
How much volume of power steering fluid do we have in the E39?
Old 05-09-2012, 11:20 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
No, get two quarts of synthetic ATF, not power steering fluid.
Old 05-10-2012, 05:04 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
+1 on the ATF, look at the cap, it should say ATF on it.
To help you flush the system quickly remove the drain plug on the bottom of the PS pump.
That will drain most of the fluid out of the system. You can refill and drive it around the block a few times then drain and refill again with your second quart.
While you have the system drained you could remove the resevoir, unscrew the filter screen inside and flush it out with gas or some other solvent. When you drain the system you will see a small torx screw at the bottom. The screen pic is before cleaning, not too bad, but worth the 15 min to remove and clean.
2000 540/6 Slightly tweeked...everywhere
Old 05-10-2012, 06:31 AM
Dking078's Avatar
Member Supremo
Any reccomended brand I should get?
Old 05-10-2012, 06:52 AM
10-34 10-34 is offline
Mein Auto: 540i
Hey JIMLEV those underdrive pulleys?
Old 05-10-2012, 07:29 AM
VAC underdrive pulleys for the PS pump and waterpump.
IIRC they slow both down by 12%, must be worth all of 3-4 HP. I'll take it.
Old 05-10-2012, 10:01 AM
I used Mobil 1, but any top shelf synthetic will work.
BTW, Jim, you must wash your engine weekly!
Old 05-10-2012, 01:33 PM
Dr._Zoidberg's Avatar
Dr._Zoidberg Dr._Zoidberg is offline
Send a message via AIM to Dr._Zoidberg
Mein Auto: 2003 540iA Sport
Wow JimLev I don't know how you keep all that so clean, especially a 540i.
The problem with Mobil 1 is that nobody seems to be stocking it anymore and I have to order it from NAPA, so just go with any universal synthetic ATF since this system isn't too picky with fluids.
Old 05-10-2012, 06:25 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
REDLINE D4 ATF has my vote. I've been using these for all my cars and so far no complain whatsoever!
Old 05-10-2012, 07:55 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Redline, Amsoil, or Mobil 1 ATF's are all very good IMO.
You can also use Castrol Multi-vehicle Import ATF for ~$5 a quart, and Valvoline Dexron VI (full synthetic) found at Autozone.
Old 05-10-2012, 10:16 PM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
My $.02
Drain it, DO NOT USE solvent to clean it. Atf has much much higher viscosity and will pour out in the coldest of winters. Plus it has Many Many more detergents in it than OIL that is how BMW in the beginning got away with the 'lifetime' fill of our Auto Trannies. That said due to its position in the circuit the torx drain plug is the lowest point and there isn't a pan to drain, So I'd just get it to operating temp pull the cap off the reservoir and then pull the plug it will drain out completely. ATF also has seal conditioners in it that are good for your seals and solvents would eat at it, plus any left over solvents would NOT be good for your pump.
Then go to Autozone or Advance and get some good tranny fluid...no real need to go crazy here. This is a lubricant and pump agent, which ANY good quality ATF will do. This like our tranny fluid should be changed every couple of years,
Again my $.02 GL
I think the lesson here is what I learned from Oil, Clean is far more important than BRAND. IF you keep it clean it will last a good long time...
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 05-11-2012, 03:52 AM
I said to clean the resevoir and screen with gas or solvent when it is disconnected, not the whole system.
Dr Z, edjack, it stays clean because it never sees winter and generally isn't driven in any bad weather. Got 3 cars so it's easy to keep this one clean.
Old 05-11-2012, 08:09 AM
Dking078's Avatar
Member Supremo
Thanks for the input, the parts come in alot faster than expected from AutoHausAZ, so i'll be replacing it today. Wish me luck!
The fluid is so old and brown, the PO's must have never changed it..ever..
As a side question: What size hose clamps should I buy?
Old 05-11-2012, 09:22 AM
George16 George16 is offline
Mein Auto: 2003 530iA
Go to home depot and buy the stainless steel hose clamps instead of the regular zinc-plated ones. Its a lot stronger. Get a 22-47mm and you'll be set.
Old 05-11-2012, 10:28 AM
Go to the dealer and get OEM screw-type hose clamps.
They are best, and designed to work with the OEM hoses.
You can also get the hose clamps from AutoHausAZ and EAC.
http://www.autohausaz.com/search/pro...3@Hose%20Clamp
Jason
Old 05-11-2012, 03:28 PM
Dking078's Avatar
Member Supremo
Got most of the parts ready, choose valvoline..
The clamps..well i just went with some normal ones that i've seen in DIYs.
