Old 05-10-2012, 03:21 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
First set of M Performance Parts Brakes installed on TMS's 335i
Turner Motorsport installs BMW M Performance Parts Brakes on F30 335i
Turner Motorsport picked up one of the first F30 N55 power 335i in Alpine White this February and has had the pedal to the metal modifying their project F30. It started with a set of H&R sport springs, then came the 20" Forgelines and now they've installed the first set of BMW M Performance Parts Brakes.
BMW M Performance Parts is BMW's answer to a growing demand for factory warrantied parts that increase the performance of the car beyond stock. Part offering from BMW for the F30 3 Series includes brakes, carbon fiber interior trim, black kidney grills and more. Read about the entire line of M Performance Parts in our recent article.
Over at Turner Motorsport their factory trained technicians have bolted on the first set of brakes in the country. The brakes are made for BMW by Brembo and sport 4 piston fixed aluminum calipers riding on 370mm rotors up front and two piston fixed aluminum calipers over 345mm rear rotors.
The new brakes draw attention to the wheels with the bright yellow peaking out behind the matte gray Forgelines. The rotors are both slotted and drilled drawing attention to their size. Aesthetically the brakes clean up the car considerably over the dull gray of the stock 335i calipers. If you have a 328i the visual improvement is significant over the ugly floating calipers and tiny rotors.
On the road the F30 335i brake performance is improved with a more confident pedal feel and a perceived reduction in stopping distance. The brakes increased size shines in repetitive heavy braking where their resistance to fade is much greater then stock. The brake improvement on the F30 328i will be even greater as the stock brake system is almost undersized and the pedal feel leaves something to be desired.
The complete kit sells for $2,460.85 on TurnerMotorsport.com and TMS's service department can install them for you. If you're a DIYer we're told the installation is very easy, almost plug and play. The rotors install just like the stocks (but are more massive) and the kit comes with all the bolts, sensor, etc. that you need to install the brakes with out a hitch. It is recommend that you have your ECU flashed to update the DSC with the increased stopping power information.
BMW M Performance Brake Kit for BMW F30 3 series
ID:	324458   Click image for larger version
ID:	324459   Click image for larger version
ID:	324460   Click image for larger version
ID:	324461   Click image for larger version
ID:	324463   Click image for larger version
ID:	324464   Click image for larger version
Old 05-10-2012, 04:30 PM
pix335i's Avatar
pix335i pix335i is offline
Enthusiast
Mein Auto: E92 335i Coupe
The brake kit looks pretty good under those wheels!
2007 Montego Blue 335i Coupe | 2014 X1 xDrive28i
Old 05-10-2012, 08:51 PM
westwest888's Avatar
westwest888 westwest888 is offline
Banned
Mein Auto: 2010 Audi S4
Like. Is that $2500 for fronts only, or for all 4 corners? It's a good deal even at fronts only. If you're going to track this you'll need to spend another $350 per axle for some Pagid Yellow RS29. Don't even think about going on track with street pads. You'll ruin your expensive rotors.
Old 05-10-2012, 10:46 PM
ybbiz34 ybbiz34 is offline
Mein Auto: '13 C63 AMG Sedan
I looked up the F30 M Sport Brake Kit on BMW's website and it would appear that the ~$2,400 price is for front/rear.
[SIGPIC][/SIGPIC]
'13 Iridium Silver C63 AMG Sedan (540 hp; 500 lb-ft)
Old 05-11-2012, 02:08 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Why the ///M sticker is inverted depending on the caliper?
Old 05-11-2012, 06:12 AM
pix335i's Avatar
Enthusiast
The M Performance brake kit is all four corners....a pretty good price!
Old 05-11-2012, 07:06 AM
White05X3's Avatar
White05X3 White05X3 is offline
Mein Auto: 12 328i ED & 11 328i ED
Does anybody know if these are typical Brembo top-loading calipers? In other words, two pins holding the pads in with pads being loaded from the top of the caliper? On my Evo which has Brembos, I knock out two pins, lift the pad out, slide a new one in, tap the pins back in, and carry-on. It can be done in under two minutes per corner while at the track. This is one thing I will really miss about the Evo...
TIA
2010 Evo X - track/kiddie carpool beast [sold]
2013 328i - Wife's Car
2012 328i ED (June 12)
Old 05-11-2012, 07:09 AM
tim330i's Avatar
TIA
It looks like it but I'll confirm with TMS for you.
Tim
Old 05-11-2012, 07:12 AM
Banned
TIA
That is critical. Implies good design and makes the labor easier than taking off the wheel.
Old 05-11-2012, 07:19 AM
White05X3's Avatar
Thanks Tim!
One unfortunate thing about being an instructor with BMW CCA is that we get less time to setup at the track. With the normal BMW calipers, there really isn't time to do brake pad swaps day of event. That means driving around for a while on track pads, which is never nice. To me, the ability to top load a caliper is crucial (again...ahem...not that I will ever be taking my F30 to the track, just making a general product statement).
Old 05-11-2012, 07:28 AM
tim330i's Avatar
The M logos are on each caliper in such a way that the M is always up and the stripes are always down.
TIA
The calipers are top loading! Take out the pin and you can swap pads without removing the caliper
Tim
Old 05-11-2012, 09:13 AM
White05X3's Avatar
Cool Tim! Thank you very much!!!
Old 05-11-2012, 12:44 PM
Alecop Alecop is offline
Mein Auto: 535xi M Sport
And why can't we get these on the 5 series F10? Come on BMW, WTF!
Old 05-11-2012, 01:11 PM
jusmills's Avatar
jusmills jusmills is offline
Send a message via AIM to jusmills Send a message via Yahoo to jusmills
Mein Auto: '04 330Ci
I wonder if this kit could fit an E46 or E90. Does anyone know how similar the F30 brakes are to the E46 or E90?
Old 05-11-2012, 05:10 PM
Elk Elk is offline
Mein Auto: ~
Even better, take off the cute drilled/slotted rotors and put them on display somewhere; they are only included for looks.
Replace them with solid rotors if you want better performance (more swept area, better heat dissipation, etc.) They are also cheaper.
Then add some simple ducting to direct cool air to the brakes.
Also keep in mind that there are/will be oodles of brake kit options (Brembo, Wilwood, etc.) many of which will be cheaper but with equivalent or better performance.
Old 05-11-2012, 05:35 PM
Banned
Well, these are dimpled/slotted right? Slotted is perfectly OK. In the largest sizes (over 360mm or approaching 15") there aren't really solid rotors to be found - they are always at least slotted.
Old 05-11-2012, 06:43 PM
Elk Elk is offline
Mein Auto: ~
Slotted is "OK," solid is better.
Odd. I have never had an issue obtaining solid face rotors of many sizes. I've got a big box of them (cheaper by the dozen) so I have not been shopping for a bit.
(P.S. "Vented" vane rotors are something different; open in the middle between rotor faces.)
More important is getting lots of cold air to the brakes. The stock brakes will do fine if well vented. Of course, this doesn't do anything for looks so most will not be interested.
Old 05-11-2012, 11:45 PM
sleedawg sleedawg is offline
Mein Auto: Mini Cooper S
Some kits are really just marketing and bling and actually are no better than staying with a stock factory setup.
Rule of thumb with brakes is follow the ABCs for quality.
Alcons (best)
AP
Brembo
Stoptech
Wildwood (last)
I've had an opportunity to try all the brands and seen long term issues when they're sent for rebuilds. You get what you pay for and brakes are not something you want to save money on.
Personally I would never suggest Wilwoods. I'd tell people to stay stock and save their money.
Old 05-12-2012, 06:38 AM
Elk Elk is offline
Mein Auto: ~
There are oodles of brake options, most good, some overpriced.
Pros primarily use AP Racing and Brembo, AP Racing is the best in the eyes of most. Alcon fell a good deal behind in quality and design some years ago, but is certainly still very good.
StopTech is good. Then there is Stillen (very good), Performance Friction (makes a good racing monoblock, their street series is fine), Stasis, Rotora, Coleman, . . .
This is all academic for a street driven F30 however. You are not going to be held back by the stock brakes. Change your tires and then pads if you want better braking response, Buy the brake kit if you want looks and bragging rights
Old 05-12-2012, 08:31 AM
The kit will not work on an E90 for the fact that the F30 rotors are not interchangeable with the E90.
Harold at HP Autowerk has put a set of these same design Brembo calipers on an E90 and has been out logging miles on the street and track.
This is all academic for a street driven F30 however. Buy the brake kit if you want looks and bragging rights
The BMW M Performance kit represents an extremely capable BBK at a very reasonable price point. The calipers have been widely tested on many applications for many year (Audi S4, Jaguar Rs, etc). Nobody is arguing that for street driven cars that these are overkill. But the people these are marketed to are looking for the potential either for bragging rights or for the actual use.
In terms of BMW applications, the oodles you mentioned don't manufacturer for BMW and are for the most part rebranded Alcons, Brembos, etc. We all hope you're right that there will be a cheaper with equivalent or better performance potentials but I'm very doubtful. The cheaper alternatives that you've listed in your oodles are for the most part marketing and will not hold up to repeated light track and street application. Those purchasers are better off staying stock.
Old 05-12-2012, 09:52 AM
Elk Elk is offline
Mein Auto: ~
I was referencing your post which claimed Alcon is the top within your "ABCs" of brakes. It is not. Combining two of my separate posts into one quote is, at best, confusing.
As to your point, there will be cheaper, equivalent or better options than the pre-packaged "M" brakes. Of course, you don't get the showy "M" however. Just start with sourcing the Brembo calipers and more performance oriented rotors.
Of course, if you want actual performance you buy a better product, but those truly in the market for actual track performance already know this.
Old 05-12-2012, 05:36 PM
It said rule of thumb for ABC. Rotora in my opinion is the worst... but doesn't start w. Z. I'm not going to argue with you about who is the best. I'm not sure why you don't think Alcons aren't and what data you have to support it, but I'll say... go have it. You're absolutely right. Everyone is entitled to their opinion especially on the internet. They're not the best and I'm surprised that so many winning professional race teams in various race series still use them.
In terms of cheaper alternatives of sourcing the calipers, etc. That's exactly what I'm doing. I'm currently sourcing f30 335i brake calipers which are the same caliper designs from Brembo without the paint. It's not as easy as just purchasing a kit which is what we were originally talking about, but it definitely is a cheaper alternative and I can choose individual components such as pads and rotors. Once everything comes in, maybe I'll take photos and do a write up on it. Or not. My original plan was just to buy new brake carriers from the euro market f30 328i that accomodate larger rotors, but decided the difference in price for a better caliper design was worth it. This being for a street car and not my track car, why go overkill.
Old 05-12-2012, 06:28 PM
Elk Elk is offline
Mein Auto: ~
Sure you are; you just did.
I did not write that Alcon brakes are bad, merely they are not the best. Alcon has had quality issues (particularly hats and rotor problems, and quality control issues) starting roughly five years ago that turned many away from them. At the prices they charge they should be perfect ($1,000 rotor). Alcon has made some very nice bits however, especially for armored vehicles and the like. I am confident you will find many more teams running AP Racing however.
I also did not write Rotora are top-tier, merely mentioning them as one of many options for someone who wants pretty brakes. In fact, I would recommend against Rotora for performance driving.
Strawmen are easy to knock down, yes?
Good thinking, especially as I suggested it.
As I am sure you know, you can spec just about any manufacturer's product to fit the car. There is nothing exotic about BMW brakes and design.
Old 05-12-2012, 06:59 PM
You're always right. I follow you anywhere as my mentor in the bench racing world. Cheers!
Old 05-12-2012, 07:25 PM
Elk Elk is offline
Mein Auto: ~
I'm sorry I offended you. There is no need to be insulting.
I am surprised however as I merely disagreed; neither ridiculing your opinions, nor disparaging your experience.
In any event, I feel comfortable you do not want any further exposition as to why I personally would not put Alcon brakes on any of my track cars over a number of other options.
Good luck swapping your calipers. Please post the specifics of your project if you complete it.
bmw forum, bmw m performance, brembo, brembo brakes, f30 335i, f30 335i brakes, f30 bmw, f30 brake upgrade, f30 brembo brakes, f30 forum, m performance parts, tms, turner motorsport
