Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 05-10-2012, 07:52 PM
Gyros Gyros is offline
Mein Auto: 650i
Speed sensors
So....im trying to figure out how many speed sensors the car has......i found the one in the front driver side but cant find the others......any and all help would be appreciated. Thanks!!
Old 05-10-2012, 10:56 PM
Yorgi's Avatar
Yorgi Yorgi is offline
There is one at each wheel. The car needs one for each wheel for ABS and anti-spin stability control. They go for about $65 each, which is not bad.
You can see them if you drill-down on the "front axle" and "rear axle" diagrams here.
You might be thinking of the brake pad wear sensor if you only saw it on the front driver's side. There is a front left and rear right brake pad sensor (2 total) but 4 speed sensors.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
speed sensor
