E36 (1991 - 1999)
Old 05-10-2012, 07:37 PM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
T-stat housing gasket
So im planning on doing a cooling system overhaul this weekend and had a revelation... the kit i got had an aluminum t-stat housing with a gasket in the roughly rectangular part but there was no gasket around the circular part that covers the t-stat itself. is this normal? do i not need a gasket? or should i go to the dealer tomorrow and try and pick one up?
To be clear the kit DID include this gasket
but did NOT include a gasket that looks like this
BTW i have the M52 engine.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 05-10-2012, 07:45 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
That housing gasket is very weird (the one not included). It doesn't fit flush when the t-stat o-ring is in. So I haven't used it for the last two t-stat housing replacements I've done. No leaks whatsoever. I guess it's not necessary.
-CJ
Old 05-10-2012, 07:47 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
You do not need the second gasket you linked to. That was for an earlier design. The "rectangular" gasket and the large o-ring which comes with the t-stat are all you need. I'd also recommend dabbing a little 02 sensor save t-stat RTV sealant around the "rectangular" gasket. Just barely enough to get a little bit of squeeze out (but just a tad).
1998 BMW 328is
1966 Pontiac GTO
Old 05-10-2012, 07:48 PM
cj.surr's Avatar
some kid
Ah, that's it. It's for the non-vanos engines. Makes sense since it was in the non-vanos headgasket kit that I got.
-CJ
Old 05-10-2012, 08:18 PM
veteran011's Avatar
Mein Auto: 97 328is
cj your first answer made me feel better. then your second one confused me... i have vanos. do you not?
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 05-10-2012, 08:19 PM
cj.surr's Avatar
some kid
Yeah, I have vanos. I'm saying that the paper housing gasket is for non-vanos engines. That's why you don't need it.
-CJ
Old 05-10-2012, 08:31 PM
veteran011's Avatar
Mein Auto: 97 328is
ahh. got it. thanks for the quick replies! thats why i love youse guys. i'll take Ze's advice on the RTV. any other places that could use that when doing the whole cooling system?
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
