E30 (1982 - 1993)
Old 05-12-2012, 05:47 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Zf 4 hp22
Hey guys, so i'm picking up the 86 325 next weekend but the tranny has a gigantic leak (main seal i think). the guy I'm buying it from said that he has a getrag 260 off a '91 but i was told that the later 260s dont have a CPS port that is necessary on the 86.
So then my next idea was just to take the transmission out, have a shop replace the seals and throw it back in and use it like that.
Now i'm thinking, I can probably find a good running usable transmission to just swap in and trash the leaky old one or trade it for pudding cup or something. A replacement would be much cheaper than having a shop replace seals and I could do it all same-day. (If any of you guys have one that'd be sweet t*tties)
I dont have the time or funds at the moment for the manual swap, but when I do the motor swap, i'll do the manual conversion then.
Now heres the question. Does any model year ZF4 HP22 transmission fit the car?
Or is it the same issue as the manual box on the 86. Will i need an 86 auto tranny?
My reasoning is that if the CPS is at the flywheel, both the autos and manuals will need that port, that wouldnt be found in later year transmissions.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 05-12-2012, 11:22 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Are you sure it doesn't have the holes in it or are you just planning ahead? First I would take a peek before any elaborate planning to circumvent or modify the electronics to have a front crank sensor and energizer instead. Another thing is the shifter mounts may or may not be correct if you get a really early g260. I think I remember FF having mentioned something about some 260's not having crank sensor and cam sensor holes.
So to recap any E30 eta manual should work post 86 and I bet the ones in the 528e e28's are the same too.
Old 05-12-2012, 01:20 PM
Monsignor's Avatar
Mein Auto: Sig
Ok.
1) im looking to simply replace the automatic with a non leaky one. does it have to be an 86? or would any one fit. I've heard about CPSs being at the flywheel so would i need to find one with the proper CPS port.
2) i'm not looking to modify or relocate the CPS in any way. I want a stock daily until I can do the motor swap.
I want to put the same exact trans in it thats in it now. Its an auto now with a main seal leak. Would any year work? or must it be an 86 auto? I appreciate the help!!
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 05-12-2012, 04:57 PM
On Top
Ok.
No you should be fine with any 4HP22 from an e28 or e30 as long as it's an ETA, can even be an 88 super eta and will be just fine bro.
Protip- When pulling trans use a pry bar to seperate the torque converter from the flywheel after you unbolt the 3 bolts if it doesn't just come apart.
DO NOT LET THE CONVERTER COME OFF THE TRANNY! IT WILL NEVER WORK RIGHT AGAIN!
Old 05-13-2012, 09:26 AM
Monsignor's Avatar
Mein Auto: Sig
Excellent. Much obliged. Should I find a replacement tranny with a torque converter in it?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 05-14-2012, 04:19 AM
On Top
well ya, like I said if they come apart source another one and try to keep it from dumping out. I have heard you can stick the converters in a 5 gal bucket and get all the air out of it and it will work, but I have only reinstalled an auto tranny on E46's and e36's. On E30's we just 24V swap at the same time and get it ova wit.
So yes, if the tranny doesn't have a converter on it, walk away.
Old 05-14-2012, 12:22 PM
Monsignor's Avatar
Mein Auto: Sig
the main seals need replacing. It's pouring fluid out. Should i just remove the trans, bring it to a shop and have them fix the seals and reinstall torque converter and i'll just bolt it back up?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-14-2012, 07:06 AM
SamReyes91 SamReyes91 is offline
Mein Auto: BMW 325i with iS Con
if you dont mind getting dirty, just do it yourself, itll be cheaper then taking it to a shop. 14-20 bucks for the seal at Oriellys or around 4.50 on pelican parts sorry no link but yea check it i had the same problem on my e30
Old 11-14-2012, 04:05 PM
BMWFatherFigure's Avatar
Old School
Just change the seal(s) and ask a trans shop about the torque converter installation (buy trans fluid from them to sweeten them up). You've done the hard work, grab the glory.
Current:
E38 Parts Car
Previous:
