E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Factory or performance clutch?
The time has come to put a new clutch in my '02 330 - 147k on the odo. I'm thinking of Autocrossing with the car this summer - any thoughts on whether I should upgrade the clutch? I don't want to sacrifice too much around-town ease-of-use, but wasn't sure if the factory clutch would suffice for some casual weekend autocrossing.
My stock clutch has 110k miles on it... and about 300 full clutch dump autocross launches. It's starting to feel a bit soft, and when it starts slipping, I will replace it with another factory clutch.
Something like THIS is a smokin` deal:
http://www.ebay.com/itm/F1-STAGE-1-C...item2318d979be
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
I can't speak for the first 139k miles on my car, but at 150k miles it still has the OE clutch and for the 11k miles I have had it, I haven't been "easy" on it.
Good to know you're experiences with the OEM clutches have been as good as mine. I'll keep looking but from what I've read high-performance clutches and lightweight flywheels etc aren't really worth it unless you're getting into some more serious racing, in which case I'd probably NOT be in a 330.
Any mods you have done that are good for autocrossing - like brakes, suspension, etc?
Suspension, absolutely. See the link in my signature to my web page to see my modifications. All that said, if you are new to autocrossing, it is absolutely easiest to learn with a stock car. |
sorry for hijacking this thread
my clutch is expected to run out any time soon, is it a reason why gears are not shifting smoothly, and the second gear is making that "kikh" sound when i'm up-shifting to it while high revving first ?if i'm driving slowly and shifting from 1st to 2nd, it's all good. will replacing my clutch solve my issues ?
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Drive at 35 mph in 4th gear. Nail the throttle. Does the car start picking up speed immediately, or do the RPMs jump up quickly, without much increase in speed ? If the latter, your clutch is just about fried....
So my gearing issues are not clutch related?
Congratulations, sounds like your mechanic just did in your flywheel (or at least tried his best). It may not be toast right now, but bad things happen when you rev the piss out of the clutch after it has glazed. At least it seems to be holding now, but that little trick may have induced some hot spots on the flywheel, which will eventually ruin the friction mating surface.
Very recent experience with this stuff on the e39. But, you can attempt to deglaze it, and get some more life out of it. Search the internet for "deglazing clutch" and study the method about getting up to speed, then holding your clutch just at engagement point for a few seconds. Doing that a couple of times, then letting the clutch cool without further abuse (as in, a couple of hours parked) has worked reasonably well for me.
![]() #232
Thanks guys, will look into it!
I'll comment on this since I have an aftermarket clutch. The F1 racing stage 2 clutch by gripforce is absolutely amazing. It grips HARD and it's pretty darn stiff. It's either in or it's out, there is no halfway lazy shifting it. It is not ideal for daily driving though.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
| Bookmarks |
| Tags |
| 330, autocross, clutch, clutch replacement |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
