E30 (1982 - 1993)
Old 05-12-2012, 09:06 AM
91318is 91318is is offline
Mein Auto: BMW
E30 1984 318i Temperature Gauge
When I put the key in the on position, everything jumps except the fuel gauge. It just makes a small giggle and stops below cold. Ironically, the only problem left on my engine is the idle control valve. Any idea how the temp. gauge can be fixed?
Old 05-15-2012, 12:50 PM
Mein Auto: BMW
I jumped the gauge and it shot up and works, however I am not sure if I need to replace the water temp sensor or what. I already replaced the Engine Coolant Temp Sensor, so the only thing I can think of is the Water Temp Sensor. Any ideas?
Old 05-21-2012, 02:54 PM
garagistic's Avatar
garagistic garagistic is offline
Mein Auto: e30
Have you cleaned the ground on the back of the gauge? Its very common that the ground nut on the back of the gauge makes the gauge have the symptoms you describe. Clean it and tighten it back up and see if that works. A bad ground connection can drive you crazy.
