Old 05-12-2012, 11:15 AM
scdaytona scdaytona is offline
Mein Auto: 2008 BMW 328XI
Just swapped my battery and now have dash warnings
I followed the DIY article on replacing the battery and upon start up, I get a 4X4 error on the dash. The brake light is also on, but not bright. If you pull the Ebrake it lights up bright. I had a outside light error before I did this and it is still there. I will have access to the factory software on Monday evening, but until then I was wondering what could have happened.
Old 05-12-2012, 11:30 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
The 4x4 error went away on mine.(known bug )
The 4x4 error went away on mine, by the time I drove to the end of the block.
This is a known error that self corrects when you drive the car a little after unplugging the battery .
I suspect the other is to , but drive carefully until you know the brakes work.
Also lost the trip computer data and time of day nothing else that I noticed.
It also should reset the adaption values which will mean the car will feel a little
different if you have an automatic for awhile.
Old 05-12-2012, 12:24 PM
Yes, I took it out just after I posted this and it cleared immediately. I checked for control errors and it was no longer there. Also from another post, I found one of the dual brake bulbs in the left rear lamp assembly bad and replaced that. Now all errors are gone and I'm happy again.
Old 05-12-2012, 12:50 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
Could it have to do with the registration now "needed" when putting in a new battery? N4S
Old 05-12-2012, 01:20 PM
No
No
