F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
550i motor
Why does the motor in the new 550i fall on its face after 5500 RPM's? Good tourqe before that, but why?
The main reason is restricted airflow due to an air intake that is essentially a baffle. Supposedly Dinan has an intake in the works.
2011 Nissan GTR Red/black - HP Logic tune/midpipe - "Lightning" 2012 BMW X5 50i M-sport Dinan S1 Space gray/black - "Thunder" 2012 BMW 550i M-sport Jet black/black - "Black Cloud" Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
I feel certain its all a balancing act to get the power, economy and drive-ability characteristics they wanted. All engines fall on their face at some RPM, what's the difference where it is if the car has the performance the manufacturer is shooting for? Also, if you understand the relationship between torque and horsepower, you know that there are usually tradeoffs. In this case, with 450 lb ft of toque, to get the peak horsepower and RPM's up higher it is very likely that they would be dealing with cylinder pressures that could create problems. The car has an unusually high combination of turbo boost and compression ratio that helps give it more responsive acceleration and the 450 lb ft of torque.
2012 Acura TL SH-AWD---Wife's car 2013 BMW 1600 GT---2011 Kawasaki Ninja 1000---2012 Ducati Panigale |
Having two big turbos on top of the engine is prone to making a lot of noise. Not what most BMW customers want...
2011 535i Sophisto Grau / Oyster - Black Nappa, Anthracite Wood ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP Mods - M5 Grilles, BMWPedals Black Anodized Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss. Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians |
It's just not very BMW like to me. Drove an E60 M5 yesterday and probably going to buy it Monday. As the motor spins faster, the more and more power you get. A seriously awesome engine. Also has more low end than you would think.
The E60 M5's V10 essentially a Formula One motor in a sedan. The more you rev it the more power it produces. But it has little power around town and off the line and I often used to smoke that car in my E60 550 up to about 40 miles an hour from a Stoplight
Dearly departed BMWs: 2009 550i M Sport in Carbon Black Metallic and 2003 540i M Sport in Titanium Silver |
I'm not saying BMW put on an intake "that was not right for the car." I'm saying that BMW purposely limited airflow for a couple of reasons... 1. To restrict max power so that the horsepower isn't close to the M engine. They are the same basic engine design after all. If you look at the dyno graphs, the power is very close until 4500 rpm when the 50i flattens of and the M keeps going up. 2. To decrease intake and turbo noise. This is supposed to be the more refined version, so less noise would be the goal. If you understand the relationship between horsepower and torque, you will understand that horsepower is a function of torque. As revs go up, horsepower increases linearly with revs as long as torque is a constant...which it pretty much is in a turbo engine like this. The only way to prevent power from continuing to rise is through limiting airflow, which they did. The engine is tuned for good low-end power, but that's normal with a turbo engine. Torque peak always comes early when the turbos spool up. The boost levels on a stock N63 are actually quite low for a modern turbo engine...only around 9.8 psi (with a compression ratio of 10, which also isn't high). The M motor makes around 17 psi stock with only a slightly lower compression ratio (around 9.3, if I recall).
2011 Nissan GTR Red/black - HP Logic tune/midpipe - "Lightning" 2012 BMW X5 50i M-sport Dinan S1 Space gray/black - "Thunder" 2012 BMW 550i M-sport Jet black/black - "Black Cloud" Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... Last edited by TahoeM3; 05-13-2012 at 10:18 AM. |
Good points.
The Dinan Stage 2 doesn't have the same drop-off. It's a more natural linear curve with a higher drop off.
That said, the engine has so much power I rarely see the need to rev it that high. That's what I love about this car is you can shift at 3500-4000 rpm and get superb acceleration without stressing the engine.
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
The E60 M5 has a soul though that's what i liked. For the same price I could get a 2012 550i, but the engine not only has no soul, it falls on its face at around 5500. The F1 derived V10 is simply amazing. I admire the low end torque, just not at the expense of a soul and the anti-BMW flat top end.
Of course I understand the relationship of hp and torque - that was my point. The more you increase the RPM's to make more horsepower, the more you have to contend with the cylinder pressures of a turbocharged engine with a 10-1 compression ratio. I get everything you are saying, and you no doubt know something about engines. But to say the intake is the limiting factor doesn't really make sense. My point was that they designed the engine to meet the parameters they were looking for in the car and there are many ways to give or take power. The car runs the 1/4 mile in the very low 13's at up around 109mph. That's the part that counts - not how many RPM's it turns. Those are all tradeoffs to get the end result they were looking for. As to the M engine, you know damn well that they also had to spend a lot of money to put components in the engine (and the rest of the drivetrain) that can hold up to the durability testing that nearly 600 hp (or whatever it really has) requires.
2012 Acura TL SH-AWD---Wife's car 2013 BMW 1600 GT---2011 Kawasaki Ninja 1000---2012 Ducati Panigale Last edited by jjsC6; 05-13-2012 at 11:58 AM. |
I will keep my 550, with a dinan stage 2, there are few on the road that can keep up and can still get decent gas milage on long trips.
As far as the high rpm performance fall-off I believe it is a combination of the air-intake and the single size turbos. This is where the straight sixes with the dual and tri-turbo designs have an advantage.
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link 2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret) ![]() ![]() ![]()
Maybe the new M5 is better with regards to high RPM pull.
Yeah but open up the ten throttle bodies and damn lol the surge and sound is incomparable.
Sent from my PH44100 using Bimmer App |
The sound is indeed great. Will say this in defense of the 550i: lower in the RPM range, and in everyday traffic, the 550i feels considerably faster. But the M wasn't really built for everyday traffic, so you could almost forgive it this shortcoming. Per Top Gear, the E60 M5 will do 204 mph - it pulls effortlessly at higher speeds, but is a little less impressive at everyday speeds. Still love it, though. It's a great deal of fun to drive - even though it sounds like a diesel when it starts up!
Yeah until you drive the M like its a manual transmission with a clutch, that happens to be computer controlled, then its jerky. But once you learn it It's great. Idk. I liked the new 550i until I hit it at 80 MPH. don't get me wrong it wasn't slow it just didn't pull like other BMW'S I've driven. Nice car though.
TahoeM3
I want to follow up to our earlier discussions. As I thought about this later in the day, I do think I took your original response out of context. I think what you were saying is that the intake manifold is the best source of easy hp and I took what you said to mean that the intake was the problem on the car. I apologize if you and I were looking at it from two different angles.
#25
With all do respect lol the new 550i is nice, however the precious M5 will kill that car in a drag race. It may start out close but the faster you go the bigger the gap will get. I don't even think the new M will hit 204 MPH. Could be wrong but the 550i won't. Got nothing against the new car, it just simply doesn't pull in the higher RPM range like the previous M5. The previous generation 550i and M5 had power bands that were very linear, the power just builds until redline. The new one hits you with a lot of torque throughout the range until, I think 5500, and then falls off dramatically enough to tell. With that said, there is no doubt that the new car is a better daily driver. I just like the soul, power delivery, and high RPM nature of the old one. Am I crazy or does someone hear where I'm coming from?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
