E30 (1982 - 1993)
Old 05-13-2012, 03:04 AM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
Steering wheel shakes at 65mph
I have a 1990 325ic. When driving at around 63-68 my steering wheel shakes a little. If I'm going slower or faster then that range of speed it drives fine. Anyone know what's wrong?
Old 05-13-2012, 05:20 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
its either your steering it out of alignment and/or your brake rotors are warped. this is the answer to the problem on every car known to man
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 05-13-2012, 05:22 AM
Littlereddevil Littlereddevil is offline
Devilish
Mein Auto: BMW 325e 1987
Wheel May need to be balanced. You could have lost a weight.
Old 05-13-2012, 05:33 AM
i dont know why i said steering out of alignment.. i meant to say unbalanced wheels. must be time to go to sleep, usually am for two hours by this time of night lol.
E30 above Sold
Old 05-13-2012, 07:35 AM
E30 hobby car E30 hobby car is offline
Mein Auto: 1986 325e 4 door auto
I had a warn sway barn link that caused slight shaking.
also warn tie rods can cause that. usually gets worse as your speed increase. unbalanced wheel seems about right, look for a clean spot on the rim..
Old 05-13-2012, 01:03 PM
downhiller's Avatar
livin large
unbalanced wheels, warped rotors, bad strut are your 3 main reasons of a wobble at a certain speed.
Old 05-14-2012, 01:18 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
Is this a regular thing or just once? Yeah id start with a balance
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 05-14-2012, 08:09 AM
dlmpsy's Avatar
dlmpsy dlmpsy is offline
Mein Auto: 1990 325is
Worn suspension parts, most commonly bad wheel balance or warped rotors. Sometimes a tire will get worn strange and cause this as well.
Old 05-14-2012, 11:56 AM
This is a regular thing happens everytime Im driving from 63-68 mph. Doesn't happen when I push the brakes only when driving. I checked my rims an all of them of a weight on them.
Old 05-14-2012, 11:57 AM
It's a completely bone stock car nothing has ever been changed on it
Old 05-14-2012, 02:39 PM
shima14 shima14 is offline
Mein Auto: 86 325e
Even if all the weights seem to be on the. Wheels can still be off balance... And as for certain speed if rotors are a bit warped they can still make car vibrate at a certain speed
Old 05-14-2012, 02:41 PM
Cool thanks for all the help everyone. I'll see if getting the tires balanced solves the problem.
Old 05-28-2012, 05:45 PM
It ended up just needing to be balanced. Thanks everyone car is driving smooth.
