F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
F30 rear differential?
hi, anyone know whether the F30 is equiped with anything other than an open rear differential for the RWD? Is there an electronically controlled limited slip like on the 135?
Does the E9X 335is have a differnt differential? |
Nope. Limited slip rear differentials are disappearing - except for dedicated track cars. They are substantially less valued than they used to be. The ability of modern cars like a BMW to use the DSC to control the geometry and dynamics is the reason. For example, most sophisticated new cars lightly apply the inside rear brake under hard cornering. Limited slip differentials have a number of disadvantages - including additional complexity and reliability issues. The new Mclaren MP4-12C does not have limited slip.
I don't think they're less valued than they used to be at all. It's true that if you are competitive in a 911 GT3 you're going to need to replace the clutches in the diff every other season. It's no news to anyone that going to the track is an expensive hobby and high end cars require a lot of maintenance to stay on track. Ask a Ferrari owner and he'll tell you it costs about $10 a mile just to drive the thing. For differential technology look at the latest offerings from Porsche and Audi. On Porsche the option is called PTV (Porsche Torque Vectoring) and Audi calls it a sports rear differential. The uses magnets to disengage the inside half shaft and send all of the power to the outside wheel. It eliminates understeer without the need to dial in an insane amount of (tire destroying) negative camber on the front wheels. Porsche/Audi may have the patent on this technology. I assume that if they were licensing it from someone BMW and Mercedes would be using this also, to be competitive. |
I was thinking that slowing the inside wheel doesnt do anything for acceleration out of corners. It'lljust keep the car from spinning.
Doesn't the 135 have sort of electronic limited slip? I surprised the M Spt doesnt include some type of LSD. How about X-Drive? How does it handle slip control? |
Electronic braking, although the X6 utilizes torque vectoring made by GKN Driveline. Neat system.
My Honda S2000 with it's Torsen differential totally spanks my 335is in the corners. It's amazing the way the back end on the Honda helps steer you around a corner. |
2011 Audi S4 2003 Mercedes Benz E500 2001 Mercedes Benz S430 2001 Mercedes Benz C320 2000 Audi A4 1.8T Quattro 1997 BMW 540i 1991 Nissan 240SX 1990 Nissan Maxima |
X-Drive still has open diff in the rear, but it also has a center differential that sends power the front. It's not a fixed ratio but a varying 40-60 or 60-40 or 50-50, as power is needed. The front on the audi and the bmw x-drive have open front differentials. |
how are people getting around this deficiency? What are the after market options and how expensive.
Was removing LSD a cost cutting measure? Which BMW still have LSD in the traditiona sense? |
Only the M cars have LSDs, and they're electronically controlled so that it works with the DSC. The center diff of the xDrive system, as mentioned, is electronically controlled to apportion torque front/rear. It uses a small motor to drive the clutch pack. Last edited by floydarogers; 05-14-2012 at 10:50 AM. |
2013 Ford Mustang added LSD as an option on all models (it was already on the Boss 302 & GT500) 2013 Subaru BRZ has standard LSD 2013 Cadillac ATS has optional LSD Porsche added an LSD option to Boxster/Cayman in 2009 (I think)
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression |
On the M cars with DCT off, the limited slip doesn't work? but I guess there's a track mode. |
The 3 series are very well balanced with medium hp so it's not really necessary most of the time. Obviously the M3 is a different story. |
I think BMW doesn't use LSDs in the regular cars cause it's safer - driver's who mash the gas in a corner or wet/snow will just have one-wheel spin with minimal oversteer. If you know what you're doing, an LSD is safer cause it's more predictable, but that doesn't apply to most BMW owners.
Why not just get an aftermarket one then?
Cause it's like $3500. I'm kicking myself for not doing it to my E46 when I bought it 6 years ago. Would seem kinda silly now.
what makes you think I need to practice my application of the throttle. It's about putting as much power down out of corners to lower lap times.
BMw has never been big on LSD's - neither has Mercedes. They can be useful for dedicated track cars but other than that they are really not seen as a good idea.
The C63 AMG has gotten very serious. You can get the LSD as always, but now you can also get ceramic brakes and a full AMG engine package with light crank shafts from the SLS roadster. Also, the RS5 and RS4 will have ceramic rotors option, in addition to a very special center differential. They're behind rear LSD and focusing on higher level performance.
Can anyone confirm this is true? A passive differential in the center is all I've ever heard of. On the sedans for sure. SUV tech I have no idea about. Link?
Nonsense, are BMW M convertibles dedicated track cars? Cause they have mechanical LSDs.
#25
And, BTW, there has been a bunch of talk about the weakness of the little plastic gears on the X3 forums - they wear out easily. Last edited by floydarogers; 05-15-2012 at 08:04 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
