18" wheels owners, what tires pressure? - Bimmerfest - BMW Forums
Old 05-13-2012, 03:12 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
To all the 18" wheels owners out there ,what tires pressure are you guys running? The door jam saids 35 front and 39 rear, is anyone running higher or lower tires pressure? Also, do you think the front tires will wear differently from the back since there is 4 PSI difference.
Old 05-13-2012, 03:28 PM
markl53's Avatar
markl53 markl53 is online now
bimmerfest Supporting Member
Mein Auto: 2014 535i
Check the manual, there is more detailed inflation pressure info there. I run 34 front/36 rear if I recall. The numbers on the door jamb are for maximum load, more pressure than you need for normal conditions. Note that one set of numbers, the over 100 mph section, the front and rear are reversed in the English measure, they are correct in metric (should be 35 front/38 rear).
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 05-13-2012, 04:39 PM
I just check the manual and it calls for the same pressure as the door jam sticker, 35 front and 39 rear.
