Old 05-13-2012, 08:06 PM
Axialflow Axialflow is offline
Mein Auto: 5series 3series
Let me introduce myself
Hello everyone I just registered, figured i would say hi and share some of my experiances with this car.
Here she is
This forum has been really helpful in bringing the car back to a fully operational status. The second day I owned the car I fixed both seats tilt function. After that I went ahead and ordered new cup holders and new CCV from Bavauto (old CCV wasnt bad but was on the list of things to do). Next on the list was various oil leaks, I had one on the oil line that goes to the vanos and some larger ones coming from the VC and the gasket between the vanos unit on the head so figuered while I was at it i could do the vanos seals from beisan systems.
Here is what the valve train looked like
A closer look at the vanos
I had alot of coking on it but I guess it's to be expected after 150K
Im assuming theres not much oil flow in this area
Here is the final install, I tryed to clean it as much as i could
VCG was hard as a rock and Leaking oil on the headers bad. The smell was horible.
After all that work i dove into the next leak on the oil filer housing
old too new
Then I read up on the trans fluid hooplaa about life time fluid and promply ordered a service kit from http://www.ecstuning.com/BMW-E39-525...ion/ES2523327/
from the lookes of it it had never been changed (as per BMW rec.) but after it seems to be shifting a little more smoothly, possibly just placebo.
Old 05-13-2012, 08:10 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
welcome to the forum, taking care of the important things first good man
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 05-13-2012, 09:28 PM
Silver540i6 Silver540i6 is offline
Mein Auto: BMW 540i/6
Welcome, looks like you have already been very busy with your car.
1998 BMW 540i/6 Sport...18" Staggered M Pars, Angel Eye Upgrade, Muffler/Resonator delete, iPod integration kit
1970 Dodge Challenger R/T SE...440 six pack, slap shift...blows away all e39s
Old 05-14-2012, 08:12 AM
nsogiba nsogiba is offline
Mein Auto: 2001 540i/6
Fantastic looking car and anyone who does their own work gets a thumbs up from me! Welcome!
6.0L LSx/T56 Swap
2001 BMW 540i/6 Sport, under the knife
Old 05-14-2012, 08:36 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
Welcome aboard. Now you have most of them out of the way, inspect the cooling system for an overhaul.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 05-14-2012, 06:21 PM
Thanks for the welcome. Its been pretty enjoyable getting this stuff done and if it wasnt for this forum i would have been oblivious to some of these issues
I still need to fix one of the rear window regulators and look into some induction systems.
I have the maintenance records from the previous owner starting from 64k and she had the radiator, hoses, and pump done at 130k. Are there any other parts is the cooling system that may need to be addressed?
Old 05-14-2012, 07:03 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Welcome.
From the looks of your engine internals I would guess the oil wasn't changed until the light came on, 15K or more miles.
Change it every 7.5 K or less and it will keep the inside much cleaner.
Take the secondary air valve off and clean the carbon out of it so it will seal. this will keep the exhaust out of the secondary air pump.
I've changed my oil every 7.5K since new, here's what the inside looks like at 136K.
2000 540/6 Slightly tweeked...everywhere
Old 05-14-2012, 09:04 PM
These are what came to my mind: expantion tank, fan and fan clutch, thermostat.
Old 05-15-2012, 01:51 PM
Originally Posted by JimLev View Post
Welcome.
Im the third owner, so im somewhat in the dark when it comes to the oil chage intervals. As soon as I got the car I did and oil change and found sand size pieces of carbon in the filter, I was concered to say the lest. After I got the VC off I was relived not to see large amouts of sludge in the valve train. The varnish and coking didnt seem like a deal breaker since I got the car for 5k.
I think im going to stick to a 3K oil change schedule mobile 1 0w 40
Sounds reasonable.
Whats the deal with repalceing the fan?
Old 05-15-2012, 01:55 PM
Sounds reasonable.
The plastic becomes brittle and cracks, and when it is subjected to high centrifugal loads (spinning up to speed), a blade will violently detach and blow through the hood. You’re then left with an unbalanced fan and probably tons of damaged parts from all the shrapnel.
6.0L LSx/T56 Swap
Old 05-15-2012, 02:11 PM
Damn, maybe electric is a better option
