Motorsports, Racing & Track
From Formula One to Auto-X, discuss everything related to going fast here... |
Tire pressure for E30 at the track?
I'll be at BeaveRun next weekend with my new to me 325i. What pressures are people using for track work? The car has new Toyo ?T1-S? (not sure of the order of numbers/letters, but they are new...
Car has SA koni's, RD sways, HR springs,+ other items that won't be adjusted at the track. TIA, PeteinMD '00 M coupe '90 325i |
Hm. When I track the coupe, I use 38 in the front, 36 in the rear, cold. They expand by 4 lbs uniformly after a track session, so I'm at 44/40.
Do you believe that an E30 would require more pressure, cold? I'm thinking that it's lighter than the coupe & may not need even the same pressures. Again, I don't know, just thinking out loud. Thanx for your input. Best, PeteinMD '00 M coupe '90 325i |
But probably smaller tires also? The pressure is a combo of tire air volume, tire construction, and weight of vehicle.
And like I said, most people seem to be running tire pressures lower than optimal.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
