Old 05-14-2012, 02:43 AM
DeviousD DeviousD is offline
Mein Auto: BMW E39 520i & E46 330Ci
Starting problem with error code P1619
Hi,
This morning I had a problem starting the E39 which was stationary over the weekend other than moving it forwards about 3 yards to make parking space for another car.
Now I am not familiar with the technical language used, so here goes;
Upon turning the key, instead of the car making the "e, e, e, e" sound, it was more like free "eeeeeee" sound. <<
Now does this sound like the cambelt is broken? how can I verify?
Thanks,
D.
Old 05-14-2012, 03:45 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Sounds like the starter may not be engaging with the flywheel and you are hearing the starter motor spinning.
Do you know if the engine was actually turning over?
You have a chain that turns the cam, if it was broken the pistons would hit the valves.
That would sound very $$$$ expensive.
Your code is for a bad t-stat, nothing to do with it not starting.
2000 540/6 Slightly tweeked...everywhere
Old 05-15-2012, 05:46 AM
Unhappy
How can I verify?
No, it definately was not turning over
I think sound is the key word here. And there were no knocks or grinds coming from the vehichle before or after the problem.
So I will ignore that for now.
Someone suggested I replace the plugs as they have become flooded. Now I don't beleive this would be an issue, I am considering it. The car has full history from new, and it was serviced only 3 months ago.
Please help as I cannot afford to go with out a car.
Thanks,
D.
Old 05-15-2012, 02:05 PM
Your starter is under the intake manifold way down low, probably can't see it.
If you turn the key and you hear the starter motor turning and the engine isn't turning over the starter is bad.
There are two parts to the starter, the starter motor and the solenoid that pushes the starter motor gear (we call it a Bendix) into the flywheel to turn the engine over.
Sounds like the solenoid part isn't working.
Old 05-15-2012, 02:23 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
IIRC, on my E12, the Bendix was engaged via the centrifugal force of the spinning motor shaft, not the solenoid. The latter was just to switch the high battery current. I believe certain GM starters work that way; in fact, the pre-war Chevies had a starter pedal that engaged the pinion gear, and closed a high-current switch, mounted on the starter. The old Buick straight 8 required you to floor the accelerator to start.
The Bendix has an overunning clutch, so, when the engine catches, the ring gear spins the Bendix to disengage it.
Just nit-picking.
Old 05-15-2012, 06:03 PM
Showing your age there edjack, pre-war Chevies and straight 8's.
Old 05-16-2012, 02:06 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Oppen the hood and watch the fan, is it moving when you start the car? If not, the starter is bad or the teeth are broken.
Old 05-16-2012, 02:40 AM
Old 05-16-2012, 05:23 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Yes, your car is flooded.
You can try to start again but this time put the pedal to the metal while cranking the engine.
If the above doesn't work.
Remove plugs and let the gas dry out, clean and dry the plugs.
