The X5 SAV Forum
Old 05-14-2012, 09:47 AM
pghguy517 pghguy517 is offline
Mein Auto: 2005 X5
2005 X5 4.4 coolant expansion tank leak
Car has 81k miles, and the expansion tank has a pin hole. Is this normal? Seems like it should last many more years than that.
Old 05-14-2012, 05:04 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Normal. Anything beyond 60-70k miles is borrowed time.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 05-17-2012, 12:35 PM
JRLBMW16 JRLBMW16 is offline
Mein Auto: M5
expansion tank
Expansion tank is a weak link in that system, normal at that mileage,also consider a new CAP if the tank was overheated several times, they distort.
Old 06-20-2012, 10:55 PM
KiaKaha KiaKaha is offline
Mein Auto: X5, 4.4,
the pipes that run to it - the narrow ones become very brittle and will crack. If you do it yourself, they can break in your hand when unclipping them from the tank. Trust me I know. So I brought big fat hot water rubber pipes and fitted them instead, with 2 circle clamps - all good now.
Old 06-21-2012, 09:14 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is online now
Mein Auto: 01 525i, 01 X5, 91 Z32TT
It's not the age, rather the usage.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 06-21-2012, 02:02 PM
X_5_bandido X_5_bandido is offline
Mein Auto: 2002 X5 3.0i
I thought mine was faulty too. Turns out it was a blown head gasket. Coolant was all over the driver's side engine compartment. Good luck.
Two things in life are certain. Death and BMW repairs.
Winning an argument on the internet is like winning the special olympics. You're still retarded.
Old 06-21-2012, 02:29 PM
Mein Auto: X5, 4.4,
Another area to check is the valley pan gasket. To remove, its a massive job, as you have to lift off both sets of rocker heads. You will get to see if oil is getting in around the coils here as well. Youtube it to see what I mean. Some jobs are just a bit too big, so I sent my truck to an indy to fix. Not bad at NZD$1300, around a grand USD.
Old 06-23-2012, 07:23 PM
musa musa is offline
Mein Auto: 528ia, X5 4.4 sports
Same thing happened to my X5 2005 4.4 sports at 85k miles around 6 months ago. Replaced it but in process broke connection to radiator. Be careful as you do the replacement.
Old 05-04-2013, 02:39 AM
flyace20 flyace20 is offline
Yippikayaaaay
Mein Auto: 2002 X5 4.4
oh go on... I'll do those miles in two years. You sayin thats all a car is good for? Two years
'02 BMW X5 LOVE THAT CAR
