Cooling system????HELP e39. - Bimmerfest - BMW Forums
Old 05-14-2012, 10:41 AM
Sethlaidlaw Sethlaidlaw is offline
Mein Auto: 528i
Hello ,.so i was sitting in my freinds driveway waiting for him then all this sudden my temperature gauge eenr to hot , so i shut my car off . Then smoke starts coming out of my grill i open the hood to find out my radiator cracked. Do i need to replace the cooling system or whattt????? Please help
Sent from my MB860 using Bimmer App
Old 05-14-2012, 10:43 AM
Mein Auto: 528i
Idk what happened i wasnt driving.i.wasnt beating on it
Old 05-14-2012, 11:01 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
My guess is that it is original and you have more than 100Kmi on it. Replace it and inspect other cooling components. They are not far behind.
Cooling is a "hot" topic for e39. There are plenty of threads to keep you covered.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 05-14-2012, 11:41 AM
BadBrad BadBrad is offline
BadBrad
Mein Auto: 2003 540iA M-Sport
I hear that sound again....tic tic tic tic.... sounds like a bomb ready to go off!!
Seriously, replace as much of it as you finances will allow. I thought I had done enough. Replaced the water pump, thermostat, expansion tank, heater valve and dealer replaced the radiator when I bought it with 77k on the meter. Car is now at 103k and otherwise runs great. Now, from everything I read, cooling system hoses are good for roughly 150k. Then last month another major failure, a hose, but it wasn't the upper radiator hose but the plastic fitting that connected it to the radiator. So, I replaced all hoses that were still original. I thought it was all buttoned up tight. Nothing more to go wrong with the cooling system. Within a week's time started seeing fluid collecting on the drivers side below the radiator. D@#*! What could it possibly be this time? Oh No, not the radiator again? Sure enough the seal on the plastic end cap was weeping. Bought a new Behr replacement from Bavauto and had it installed in two days. I couldn't believe that a new radiator would only last for 25k but once a inspected the replaced radiator I understood why it didn't last. It was a used one that the dealer bought from junk yard. I know because there are major differences between it and the new one I installed.
Sorry to ramble on but once one part of the cooling system starts to go, you're better off replacing as much as you can.
Old 05-14-2012, 02:14 PM
Fudman's Avatar
Fudman Fudman is offline
Age and mileage, compounded by environmental factors, cause cooling system failures. If you have over 100K miles, replace eveything mentioned previously, including belts and pulleys. The total parts cost is less than $750 for everything, but the reliability and peace of mind is priceless.
Old 05-15-2012, 07:32 AM
glaz1281's Avatar
glaz1281 glaz1281 is offline
Mein Auto: bmw 530i
Agreed, Change as much of it as you can. It'll still be cheaper that an engine.. Fairly simple and will give you some peace of mind.
O2 530i Titangrau metallic/Grey interior.
Old 05-15-2012, 07:53 AM
cn90 cn90 is offline
You are late to the "cooling system fiasco blowup party"...
But it is not too late yet.
STOP driving the car further, a new engine is expensive.
Search forum for:
- "cooling overhaul"
- "aioros"
- "Fudman"
- "bluebee"
- "cn90"
The bottom line: do a cooling overhaul.
Take your time to read through the forum.
PS: Reservoir: Dealer only
Fan Blade: dealer only.
Fan Clutch Sachs.
It is a complex topic re: which brand name for which part, so take your time to read through the forum.
Old 05-15-2012, 09:47 AM
dunne44 dunne44 is offline
Banned
Mein Auto: 540i6
Wow it think 2 days ago I warned you about the explosive cooling systems in these cars. I guess you learned the hard way even though there was really no time for you to do anything.
Old 05-15-2012, 10:52 AM
Mein Auto: 528i
no it didnt blow my cooling system i was just
curious
