X5 E53 (1999 - 2006)
The X5 SAV Forum |
Yes | No A/C Cooling Fan not working
Hi all,
I'm having an issue with my cooling fan, it will not start. AC blows cold when car is running but when it stops, it is kind of blowing hot air. I was told not to use the AC while in idle, it could damage the ac compressor since fan is not working. Now, how can I check if fan is bad or just a relay? Thanks, Zelimir |
Easy.
Turn car on. Turn AC on. Unplug AC fan wire(located on main fan shield, passenger side) and than plug in. If fan will move a bit- relay is good, fan- blown. Sent from my PC36100 using Bimmer App |
final stage relay
had a similar problem which eventually lead to a dead battery, replace th efinal stage relay (resistor) battery problem solved and ACand fan works properly
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
