Old 05-15-2012, 12:38 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Vacuum pump leaks oil
My vac pump is leaking oil from the bottom bolts. The dealer says that I need to change the whole pump? Is this true? It looks like I can take it apart and change the gasket. Anyone have any experience with this thing?
Sent Via iPhone using BimmerApp
Old 05-15-2012, 03:21 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
Hi ! I think there is a diy thread for this, maybe on the 5 series forum, I had a leak from the new pipe running down the back so looked like it could have been from the bolt, so replaced the clip and tightened, cured the issue. hope this helps a little !
Always said I would go back to a 6 series
Old 05-15-2012, 08:57 AM
Nitrogen's Avatar
I'll look thanks
Old 05-15-2012, 06:47 PM
Nitrogen's Avatar
Can't find anything.
Old 05-15-2012, 06:57 PM
HerbP HerbP is offline
There is an o-ring that can be replaced fairly easy. Other things to do in that area, would be to change the oil pressure switch. Both of these job should take no longer than an hour, & around 20 bucks at the most.
Here is the link for the repair.
http://tis.spaghetticoder.org/s/view.pl?1/07/45/33
Old 05-15-2012, 07:06 PM
Nitrogen's Avatar
I know about the o ring but mine is leaking mainly when the car is not running. I witnessed with a mirror that it seems to be coming from the bottom 2 bolts in between them? Could the o ring do this?
Old 05-17-2012, 07:45 PM
I did a Google, & found this. This should help you out!
http://www.bimmerforums.co.uk/forum/...repair-t89903/
Old 05-18-2012, 12:38 AM
Nitrogen's Avatar
Great thanks I knew it could be done. I will try to DIY mine for others to use as a tool.
Thanks for finding the thread for me!! I will report back soon.
Old 05-18-2012, 04:37 AM
telecop38 telecop38 is offline
Mein Auto: 645Ci
Thanks I'm going to do mine now!!!
Old 05-18-2012, 05:58 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Nice find Herb, that is a solid DIY.
Old 05-18-2012, 08:07 AM
I know that their is one on this Forum somewhere, but I just found the 1st one I came to.
Old 01-24-2013, 12:20 AM
slimbaby slimbaby is offline
Mein Auto: BMW 650I
I recently followed the instructions from this thread. Same as above follow the directions and you will have no problem. Also the two hoses on front of the vacuum pump have one nut each holding them in place. remove the two nuts, be careful and move both hoses so you have access to the pump. On the pump you have three torx screws holding in place, two on top and one on the right hand bottom side. Please make sure you get a replacement vacuum pump gasket and a oil pressure switch both totaling $20 together. Change them all to prevent from doing it twice.
Old 01-24-2013, 02:50 AM
Medicus Medicus is offline
Marine
Mein Auto: 2005 BMW 645Ci
Make sure that you buy the gaskets from this site
http://www.bmpdesign.com/product-exe...arch_model/154
It will save you time. I replaced the o-ring on the timing cover (which is the only one that you can get from the dealership) only to find out that it was the outside cover leaking . I ended up having to buy these o-rings and do the job again. Do it right the first time especially while its all out.
Old 10-31-2016, 06:43 AM
mbaugh mbaugh is offline
Mein Auto: 645Ci
I did the same thing. Another important point: the dealer no longer sells the inside seal. BMW will sell you a $650 pump but not the $20 seal. Buy the seals (both o-ring and inside seal) from bmpdesigns.com.
Old 10-31-2016, 07:15 PM
Biochem Biochem is offline
Mein Auto: 2009 650i
I just replaced my oil switch and both gaskets in the vacuum pump... Hardest part was re-aligning the vacuum pump back into the crankshaft sprocket. It was about a 4 out of 10 on the 1-10 scale of difficulty.
Old 10-31-2016, 07:31 PM
The camshaft needs to be rotated with the notch straight & down. The vacuum pump blade will slide in without binding. With out rotating the crankshaft, it makes it hard to install.
Old 11-10-2016, 08:47 AM
BulldogsSlob BulldogsSlob is offline
Mein Auto: 2005 645ci & 2007 335i
Pump
From what I hear from BMW the pump gaskets can't be replaced. I did some research and found some kits that you could repair the pump. Check to make sure that your oil sensor below is not leaking. Mine was misdiagnosed from my dealership as a pump, which I changed out to find out I still had a leak. The sensor is 20 bucks compared to oem pump at 850, and off brand at $600. The install on the pump is super easy, 4 bolts just on the pump, in and out.
Old 11-10-2016, 06:49 PM
The vacuum pump has 2 o-rings. One is the o-ring that seals at the camshaft/engine where it bolts to the head. If it leaks, it will pour oil. There is a similar o-ring/rubber seal than can be purchased online at several places. The 2 o-rings are around 18.00 for both.
Old 11-11-2016, 06:45 AM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
I did mine. Very Very easy.
And after doing mine the first time I could do it again in 10 minutes.
2006 BMW 650i Sport/Premium Package
+ Various Mods & Upgrades
Old 11-11-2016, 11:01 PM
6 Five-O 6 Five-O is online now
Mein Auto: '07 650i, '98 M3
I was getting ready to do this but it seems like BMP designs no longer sells parts to the public. Does anyone know where else to source these o-rings?
Old 11-12-2016, 06:57 AM
mcdave71 mcdave71 is offline
Mein Auto: 2008 BMW 650i Convertible
http://www.ebay.com/itm/262704447974?
Old 11-12-2016, 05:01 PM
Originally Posted by mcdave71 View Post
The internal seal is not exactly like the BMW seal, but it works. Change your oil pressure switch while you have the vacuum pump out!
Old 11-13-2016, 11:15 AM
Ha should have figured ebay. Thanks guys!
Hey Herb, sent you a PM, please check. Thanks.
