Motorsports, Racing & Track
From Formula One to Auto-X, discuss everything related to going fast here... |
#51
Clyde, did you ever look into removing that speaker grill on the rear deck? Maybe there is access from the top side....
#52
OH NOES!!!!!1 MY CAR HAS T3H UND3R5T33R5555!!!!!!1oneone!!!!11 Team WTF?! What are you gonna do?
#53
yeah, I was thinking the same thing
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present . |
#54
) to find out how everything was supposed to come apart.OTOH, I took out the passenger side trunk trim again and poked around in some holes with flashlights and fingers. Long story short...there's plenty of room around the adjustor tab on that side. I can get A finger on it with the shock in place. You can't see the holes in the image above (they are higher than the pic goes), but they are big enough that I *might* be able to get some needlenose pliers (or similar) on it, but I don't think I would be able to turn it much before the angle made further adjustment possible. I'm sure there is a tool out there that would work, but I don't know my tools well enough to know what it might be. From a packaging and fittment standpoint, though, my gear idea should work pretty well. There is a LOT of room up there. Whether they could transmit enough force is another question.
#55
Sounds like you need to wander around the tool dept. in Sears.
What does the adjustment knob look like? Could you get a ratchet and socket on it? Or one of those ratchet wrenches? |
#56
![]() it's a lot thinner than it is wide, kind of like a paper match. I might be able to get a socket on it, but I don't think the angle is right to get a ratchet to mate with it (and I don't think that a ratchet and socket arrangement would work to adjust it anyway). You need to grab onto the tab in one way or another.
#57
I thought maybe the adjustment tab would be square and a socket would fit over it. I had the idea to use a ratchet because I figure space is at a minimum to fit pliers and still be able to turn them. I assumed, perhaps incorrectly that the openings you found were next to the top of the shock. If you have (or can get) extras of that adjustment knob tool I'm sure we could figure something out....like some sort of extension pole with that knob on the end.
#58
#59
You could just attach the knob to the shock and then bolt it all in place. Maybe secure a nut to the knob that you can get a wrench on. Or cut the knob down to accept the wrench. Of course the relationship of the opening to the knob would be critical.....
#60
You don't have much experience with the Koni knobs, do you? They don't work well enough for that to be a possibility.
#61
It's late and I'm bored....don't mind me
#62
I can't offer anything but my sympathies and what little brainpower I have at the next event to try to solve the problem.
Still, I can't help but think that once you get them adjusted how you like them you probably won't touch them anymore.
#63
#64
Every once in a while us gov't employees need to wake up our brains with over complicated solutions to simple problems
#65
#66
well my gut feeling is that 50% rebound setting will be a good compromise setting, as you go higher the rear ride quality will take a dump
since you use the same size tire front/rear on both street and race tires the race settings should still provide excellent handling with your street tires
#67
OK, if you can get to the top of the shock, you can use one of those ratchets that turn by turning a T handle at the end of the normal handle. Like this:
http://amos2.catalogcity.com/amos/cc...7122/ccsyn/260 You would need to either have a special socket made to fit the Koni blade (try Ron Stygar on teh Z forum here), or have a nut attached to the Koni adjuster.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
#68
post a picture of it, that's one of those retarded "cookies mustbe enabled" sites
#70
You turn the T- handle on the end and the ratchet turns. So you don't have to have space to swing the rathchet..
#71
Well, testing is the only way to find out if it will help.
My gut feeling (and past experience) says more rear rebound will *increase* trailing-throttle oversteer. But then again, that was for a mid-engined car.
If you're in control, you're not driving fast enough -- Parnelli Jones |
#72
having experienced the chassis dynamics firsthand I can assure you this isn't the case
#73
I don't doubt it... just relaying my *very* limited shock experiments on a mid-engined car.
![]() I'm too busy now trying to figure out all the much lower-tech, but seemingly as limitless adjustments of my shifter kart.
#74
John |
#75
yep, in certain situations but not in all turns, this is a case where adding rebound up to a point will actually keep the rear end planted better, IMO it felt like the the rear suspension was going toe-out when it jacked up like that and when you got into quick side-side transitions such as the slaloms is where would get pretty freaky, that's why I keep harping on you guys about tuning for the application at hand rather than using some general chart out of a book
![]() still overall one of the best handling Stock cars I've ever driven, the styling was leaving me cold on those but now after driving it I've completely warmed up to it; the interior, seats, etc. are all nicely done, Mazda does know how to build a driving machine
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present . Last edited by TeamZ4; 06-07-2004 at 06:49 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
