Old 05-15-2012, 04:21 PM
Captain Roundel's Avatar
Captain Roundel Captain Roundel is offline
Underachiever
Mein Auto: 328,Z3, X3
Z3 Hydraulic top oil tank looks empty.
I checked the oil tank and it looks empty. I hope this is an easy DIY. Did a quick search and didnt see much.
Has anyone done this??
Old 05-15-2012, 11:45 PM
Underachiever
Anyone???
Old 05-16-2012, 05:07 PM
aldena007 aldena007 is offline
Mein Auto: 2005 Z4 3.0i
"Hydraulic Tank"
Not sure what you are describing here. If the "tank" is white plastic I can only think of two things which would be the brake fluid reservoir or the windshield washer fluid reservoir. My 2005 Z4 has electrically assisted power steering so I don't have a reservoir for the power steering. If the "tank" is a reservoir of some sort and it is empty now something is going to quit working soon. A little more information would be helpful to get some more specific guidance for the DIY types. If this is a reservoir of the type I mentioned above the Z should be giving some warnings on the instrument cluster.
Old 05-16-2012, 05:12 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
Yes the top's oil tank can be filled as DYI.
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 05-17-2012, 05:42 AM
wrench13's Avatar
wrench13 wrench13 is offline
Mein Auto: Y2K 2.3 blk; 01 3.0 Cp
If your convertable top hydraulic motor's oil reserve is empty, there is a reason - called a leak. Better find out where that is before you go adding more, you'll only make the mess where the old fluid went that much bigger. You can disable the hydraulic unit by turning the T handle on the top of the unit, and can then open and close the top manually.
Pull the left trunk carpet up and see if you have a puddle of hydro fluid under it, first place to check. If not there, follow the hyrdo lines and look at the connections and look for cracked or cracking hoses. If nothing there, look around where the hydro cylinder connects to the top. The fluid went somewhere!
Y2K Roadstar, w/60K ( motorcycle)
Y2K Z3, 2.3, w/66K, now 92K in 2-1/2 years
2001 Z3 Coupe, 3.0 w/55K - new for me - WHooHoo
Astro 1990 w/290K
Suck, Bang, Blow, that's what it's all about.
Old 05-17-2012, 12:02 PM
Hydraulic Tank
I missed the word top and Z3 on my response. Sorry about that.
Old 05-17-2012, 05:11 PM
Underachiever
Thanks, all. I shined a flashlight thru the convertible top reservoir and it looked empty, but, its kind of hard to tell.
I found no puddles of fluid or signs of leakage so I could be wrong. The motor still spins so thats a good sign.
I will try again. If anyone knows the exact procedure to add hydraulic fluid please share.
Old 05-17-2012, 05:49 PM
East Ridge Z East Ridge Z is offline
Mein Auto: 2003 BMW Z4 3.0i
Where is this found?
2003 BMW Z4 3.0i Merlot/Tan
Old 05-17-2012, 06:40 PM
Underachiever
The motor? On a Z3 its the left side of the trunk, behind the carpeting. Not sure about a Z4.
Old 02-18-2013, 12:22 PM
Floridafun Floridafun is offline
Mein Auto: Z3
where is the resivior?
Old 02-18-2013, 12:26 PM
Mein Auto: Z3
what kind of fluid does it take?
Old 08-03-2014, 04:52 PM
HidyHarve HidyHarve is offline
Mein Auto: 99 Z3
Question Adding convertible top hydraulic fluid
My 99 Z3 has 112k miles and I have owned it since it was 2 yrs old. Never heard of needing hydraulic fluid, but it has become unable to raise or lower top without physical help. After reading this post, I looked and saw that there is only a tiny amount of fluid in the reservoir. But I don't see where you add fluid, nor do I know what kind of fluid I should use. Any help on how to add fluid greatly appreciated. Do you have to move the motor to add fluid?
Old 08-03-2014, 05:02 PM
AB1945 AB1945 is offline
Mein Auto: '01 Z3 & '02 325i Wagon
Part# 54 34 0 394 395
http://www.bavauto.com/fland.asp?par...00%20394%20395
Old 08-03-2014, 06:34 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by HidyHarve View Post
... unable to raise or lower top without physical help... there is only a tiny amount of fluid in the reservoir... Any help on how to add fluid greatly appreciated. Do you have to move the motor to add fluid?
See Step 23a at http://www.tophydraulicsinc.com/bmwz3removalguide.pdf
