E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Anti theft system problem
hello,
I tried to install an aftermarket radio into my 1993 BMW 325i today but once I reconnected the battery, with the new radio installed, the hazard lights came on and would not turn off. I have tried everything I can think of taking off the battery, driving it forwards and backwards, etc. I'm really annoyed now because I can't drive my car anywhere now. |
Sorry that this sounds like I'm being silly, but did you try pushing the hazard flasher button below the shifter? If it doesn't turn off on the first push, do it again.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Yes it just makes the hazard lights go faster. That's how I knew that it wasn't the hazard light button.
+1 to what Ken said. I've had this happen a couple times on my car when I've reconnected the battery. One time it took two or three cycles of depressing the hazard light button to get things back in sync.
So sounds like you've eliminated the hazards out of sync with the control. Nex question is have you tried disconnecting the aftermarket radio?
I took the aftermarket one out and put the original one back in.
Looking at the wiring diagrams in the Bently manual the only connections outside the sound system are two power connections and one to the interior light system. For a '93 the Bentley shows a power connection that's switched by the ignition switch that runs through fuse 44 and a hot all the time power connection through fuse 9. The interior light connection is a grey and red wire that comes off pin 13 of the radio connector.
I would check both the fuses I listed first to ensure they're both good then check the interior light connection. You stated you put the old radio back in, have you tried with no radio installed?
If the symptoms changed when you took the radio out, that's not an "it did nothing" result. Even though it didn't fix the problem when you do something and the symptoms change, it's a clue as to what might be happening.
Does your car have an aftermarket alarm system installed?
I'm not sure, I just bought the car recently, but it does look like it has some sort of a horn under the hood,+ when I lock either of the tow fron doors, it locks all the doors on the car but I don't know if that is aftermarket or not...
The way to know for certain it's a factory alarm is to look at the alarm module behind the glove box. For now let's assume that it is the factory alarm. I found this on another forum where they were needing to reset their alarm system. You'll need to disconnect the battery first and then do this:
Try turning on the ignition switch before you connect the battery (leave it in the run position- same as you would while driving). Then connect the battery and it should be fine after about 3 seconds.
Yes when you lock either door it will lock the other with out any alarm...
Still have no fix yet for this problem I looked around it might be the LCM but it's expansive to replace just to check and see if that's it... |
still looking for anyone that knows what might be wrong...
There's supposed to be a reset button under an access door on the top of the security alarm module. Resetting the alarm is the next thing I can think of to try. I'm attaching a PDF from my remote locking system that has directions on how to remove the glove box and get access to the area where the alarm module is located.
I believe if needed you can just disconnect the alarm module and that effectively disables the alarm system.
If it's disconnected now try starting the car. If it starts (and I think it will) you have your answer.
. But for now it is all working, thanks for all the help!
