'97 540i rough idle - Bimmerfest - BMW Forums
Old 05-15-2012, 08:31 PM
Agape17 Agape17 is offline
Mein Auto: BMW 1997 540i
'97 540i rough idle
had a P1175 code and installed new bosch plugs and boots plus fuel regulator sensor. ran fine then about 900 miles later the '97 540i idles rough not sure what to do next.
Old 05-15-2012, 09:07 PM
Jared@EAC Jared@EAC is offline
Past Sponsor
Mein Auto: 00 540i/6
Do you still have codes?
Old 05-15-2012, 09:14 PM
the engine light is still on so will check with my mechanic to see the code. do places like autozone also check for codes?
Old 05-15-2012, 09:47 PM
Mike_Junior's Avatar
Mike_Junior Mike_Junior is offline
540i Guy
Mein Auto: 98 540i/6
does the engine light blinks?, it might be a bad MAF
Old 05-15-2012, 09:57 PM
Past Sponsor
Yes. Autozone or advanced will check them.
Blinking light normally means a misfire is happening at that time.
Old 05-16-2012, 04:38 AM
the engine light did blink a few times and the just stayed on.
Old 05-16-2012, 07:03 AM
Past Sponsor
Yep. That's the way it is supposed to work. It blinks during the misfire and then sets itself until cleared.
Old 05-16-2012, 07:30 AM
thanks so much for your help! what do you suggest should be my next steps?
Old 05-16-2012, 07:55 AM
do you think i should try to clean the MAF first or build a new or rebuilt one? not sure what to do, this is the first BMW i have owned.
Old 05-16-2012, 07:56 AM
that is "buy" not "build" a new one.
Old 05-16-2012, 08:18 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
There is a relatively easy way to check the MAF-unplug it, restart the car and see if the idle improves. If it does, a good cleaning would be my first suggestion. If the idle is still bad, you have another problem.
The right way to approach this problem is to have the fault codes read. Guessing does not work. Please read your fault codes and report back!
Old 05-16-2012, 08:25 AM
will do, thank you so much!
