Old 07-06-2012, 09:07 AM
335D-er 335D-er is offline
Mein Auto: 2014 535d
335D Recall 11E-A03 Campaign
So I dutifully bring my 2009 335D in for the recall. They conduct the service. Immediately I realize a loss in fuel efficiency. My commute is very deterministic relative to fuel consumption.
Before the recall:
Fuel efficiency: 35.5 mpg
60 mph - interstate hwy - sixth gear (auto) - engine turns at 1250 rpm.
After the recall:
Fuel efficiency: 30.1 mpg (15% reduction)
Engine now turns 1500 rpm at same speed and gear.
Dealership says others are reporting the same thing. I called BMWUSA and they are looking into it. Claim they have not heard of this situation...
Old 07-06-2012, 10:53 AM
Puyo Puyo is offline
Mein Auto: Z4 sDrive 35i
Originally Posted by 335D-er View Post
Before the recall:
After the recall:
How is that even mechanically possible?
Old 07-06-2012, 11:04 AM
AzNMpower32's Avatar
Tar Heel Faithful
The recall doesn't change gear ratios.......no way would revs change at a given speed.
Old 07-06-2012, 11:41 AM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
You could change revs by unlocking the torque converter, or by keeping it in 5th instead of shifting to 6th. Doubt either is happening on purpose.
1,250 seems awefully low, I know my X5d doesn't run that slow, can any 335's verify this, would be a quick check for the poster.
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 07-06-2012, 02:37 PM
This just makes no sense so I calculated the expected RPM based on some info I found on 335d.
6th gear ratio .69
Final drive ratio 2.81
Tire 225/45-17
RPM at 60 MPH = 1567
Old 07-09-2012, 03:41 PM
AndyX5d AndyX5d is offline
Mein Auto: 2010 X5 3.5d
had this done today. I dropped it off at 8am and fully expected (based on comments in this thread) to not get it back until tomorrow. I get a call at 3pm saying come pick up your car. I had the oil service done, they had replace a fuse for my console 12v plug, lubed up my creaking sun roof, and did the recall all within a 7 hr period. On my service sheet is says recall 18-05-12 my X is a 2010 I believe it was built at the very end of 09 or the first of 10 and was put into service in 5/10. It states that the Mixer flap , EGR - Valve, O - ring, and a rubber seal were replaced and programmed with CAS update. Couldn't be happier with the service provided at my dealer.
Old 07-09-2012, 04:01 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Let us know if you see a change in mileage...
Old 07-09-2012, 06:15 PM
I will keep an eye on it, I hadn't seen the latest post about poor mileage. I'm about to have to fill up so I will track it closely after I fill up.
Old 07-09-2012, 06:42 PM
finnbmw's Avatar
I am interested in your experience as my X5 was built around the same time as yours (early 2010).
Old 07-10-2012, 05:10 PM
Ok so I did quite a bit of driving today. After filling up I did about 55 miles of state highway driving at an average speed of 58mph and my computed mileage was right at 30 mpg (very good for me) On the way home I drove 57 miles of mixed interstate, average speed about 68 mph, and local stop and go 45-50mph between scattered stop lights. I reset the computer before I left and got a reading of 27 mpg. This is exactly what I'm used to seeing. So as far as my first quarter tank of fuel post recall, I am seeing no drastic change in fuel consumption. All in all my car seems to be the same as before I took it in, and that is 100%.
Old 07-10-2012, 05:51 PM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
AndyX5d - good to hear your mpg did not drop . . . what is your tire size and type . . . also do you have the third row option? Thanks
My mpg dropped about 2 mpg . . . . I am keeping a close eye on other folks' mpg experience . . . I will have mine addressed during my next service visit . . . will report on the outcome . . . around November
Old 07-11-2012, 08:14 PM
I have the 18" rims with the factory dueler run flats and no I do not have a third row. Also I made the same 100+ mile trip today and my computer average is staying rock steady on about 27 mph.
Old 07-11-2012, 09:51 PM
Thanks.
As reference - prior to this recall I was averaging 23+ mpg. Post recall work mpg dropped ~21+ mpg.
Even before the recall my mpg had started to drop. Post recall work mpg briefly increased to ~22+ mpg and then dropped back to 21+ mpg.
Driving patter remained the same - 60-70% city and 30-40% hwy. On the highway I typically do about 75-80 mph. I purchase diesel from the same Chevron station.
I have the Bridgestone Dueler (Option 214) and the 3rd row seat.
Old 07-15-2012, 11:36 AM
Puyo - Thanks for taking the time to run the calculations. And the tire sizes you used are what I am running. I can't explain it. They reloaded the software as part of the recall and I noticed a bunch of strange things never seen before as a result. For example: Radio was reset and had to recover settings from the fob, and current readings for MPG were reset. Without knowing the details, I wondered if there was a software parameter setting which would result in a higher engine rev. My 2009 750Li, when switched from "Normal" or "Comfort" (ride) to "Sport" results in a much higher engine rev with lower mileage.
Old 07-26-2012, 12:23 AM
cablue's Avatar
cablue cablue is offline
Mein Auto: '10 X5 diesel
I've had an increase in mpg. Before I consistently got 24 mpg., doing 75% driving on the hwy and 25% city. Now I'm around 25.8. This may still lower as I drive more, but I've put quite a bit on already. My commute is 50 miles round trip a day. In addition, when I was bringing in my X5 for the recall, my light went on about excessive battery drain. The dealer said it would cost $1,500 (crazy) to fix - I'm out of warranty now. I have around 54,000 miles so far. But they got approval from corporate to cover the cost 100%. No hassle whatsoever. Very happy about that. They put in a new battery, neg. cable. Now, I've just gotten the message that the urea is low. Back to the dealer.
Old 07-26-2012, 12:08 PM
ard ard is offline
Resident Curmudgeon
glad they are covering it.
I dont want to know what a urea service is out of plan!
N or RV? Post postive comments on service, if you have them, in the dealer feedback forum...
A
Old 08-27-2012, 03:13 PM
U235 U235 is offline
Mein Auto: 08 Z4MC
My X5 is getting this recall performed now, I'll report back. I've felt my X5 to be a bit sluggish recently, not sure if I've just gotten used to the torque, but I recall it feeling quick before, now it just feels average.
We're driving it 175 miles on the interstate this weekend on a familiar route so I should be able to compare to the last trip I made (weather is similar, AC, etc.).
My wife is now driving the X5 full time and in our commute she gets high 20s and I used to get low 22s on the same commute, but she doesn't really know how to drive for best economy. I try to get to speed reasonably quick, glide at speed with minimal gas and avoid red lights.
Hopefully post recall some pep will return.
Old 09-28-2014, 07:16 AM
twssas twssas is offline
Mein Auto: 2011 X5 35D
I know this is an old thread.......but......
My X5D was involved in this recall, and had SCR, and EGR Valve, and reprogrammed in August, 2012.
Vehicle is now out of warranty.(3 months ago) 32,000 miles on vehicle. Emissions light came on yesterday (amber engine image), so my suspicion is this issue may be raising its head again.
I know, you really cant tell until the vehicle is tested to find the "code", but my question if it is this same issue, is there an "extended" warranty on the work that has been performed in 2012?
I am just trying to due a little due dilligence before I call my dealer for an appointment, and understand what options I may have, if indeed this is the same issue.....my service advisor is generally pretty good about working with me......but you never know....
2011 X5 35D Space Grey/black
2015 535 MSport. Mineral Grey/black
Retired: 2010 535i Platinum Grey/black
Totaled: 2010 X5 35d Space Grey/black
Retired: 2007 530i Saphire Black/black
Old 09-28-2014, 08:31 AM
ard ard is offline
Resident Curmudgeon
I don't know of any extended warranty, but BMW has been know to goodwill when you're close to the factory...
There are many, many things that can set a CEL so I wouldn't assume anything yet.
Be careful of what you agree to with respect to $$$ and the dealer visit. they will most likely say CS engine light on, check and advise
tech will read codes, erase, run a few test plans. Recommend replacing parts based on results of the tests.
Unless they will pay for this, I would decline and consider options. It is imporant that you only sign the original work order if it includes something to the effect of "report all codes as well as test plans run (and results) in writing to owner". If they wont do that, tell them you wont sign a document that exceeds $0.00. If you are expected to pay a penny, you get to see the results.
Then research it here and elsewhere.
If you read up on some of these issues, they can turn into multi-thousand dollar fishing expeditions...
Old 09-28-2014, 09:26 AM
FredoinSF FredoinSF is online now
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Agree with ard and also would suggest studying your local emission warranty information.
There are horror stories on the diesel forum having to do with carbon build up (CBU). It is being reported with the 335d; I do not recall any confirmed cases of an X5 being plagued with similar horrific CBU related expenses. I am going to paraphrase and possibly start a rumor, but the the theory is that some variations in the EGR system combined with the additional weight of the X5 puts extra load on the motor, thereby reducing CBU on the X5.
Regardless, I believe the dealer service dept are not trained well enough in troubleshooting the diesel emissions system and are throwing parts at the problem over the course of multiple visits. Not great when you're under warranty, nightmare when it's out of pocket. Note that there is also a recent SIB about a recommended intake cleaning procedure that significantly cuts the labor costs. It seems not all dealers are aware of it.
I would start with the dealer but cut the cord very quickly if feeling like I'm getting tangled up in a fishing expedition. Consult a BMW independent with some diesel experience, and if none in your area, possibly a VW or MB independent who may have more / better experience with diesels.
Old 09-28-2014, 10:56 AM
I couldn't stand not knowing.....so.......Neighbor had a code reader.........P2458: diesel particulate fliter regeneration duration.
I went ahead a cleared the light and drove about 5 miles. Light did not return.
I do a lot of very short drives: 2-5 miles, occasionally about 10-12 miles. What little bit I researched about this, short trips do not do the regeneration process any favors......I may need to a longer trip at high speed.....
Anyway more to learn here.........
Old 09-28-2014, 12:14 PM
Going for a drive would be the cheapest fix and not at all unpleasant. If only it could always be that easy.
Old 08-24-2016, 12:44 PM
///machine ///machine is offline
Mein Auto: E93
I just paid around $900 CAD to have the NOx sensor replaced in my 2011 x5 35D
Would the recall have caused a problem for NOx sensor?...also would the sensor have been included in the recall? Did I just waste money?
