Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-16-2012, 10:30 PM
vvooss vvooss is offline
Mein Auto: '85 528e
528e Electrical gremlins
I had a whole mess of electrical gremlins which were eradicated when the main ground clusters were renewed - new connectors/fresh wires, etc. All the gremlins are gone, except for one - when I turn the left signal, more often than not I get a buzzing sound and no turn signal action. Sometimes, as I travel to the touch-and-hold left signal it'll start buzzing as I start the stroke. Sometimes I'll get to full left turn, it holds, the signal is blinking and before I finish the left turn the buzzing starts up. We replaced the turn signal relay..... but this one head scratcher remains. Thanks for all your help...
Vladimir Vooss
'85 528e Lapis Blau
Old 05-18-2012, 05:12 PM
catso's Avatar
catso catso is offline
catso
Vladimir Vooss
'85 528e Lapis Blau
Maybe you need a new turn signal switch? The previous owner of my car had to replace it. Also the bulb holders in the tailight assemblies are known to suffer from contact area corrosion. Try changing to new bulbs and clean up the electrical contact areas as needed. Also make sure the plugs to the assemblies are corrosion free and making good contact.
![/I][/FONT]
Old 05-18-2012, 05:18 PM
Mein Auto: '85 528e
Good point about cleaning up the turn-light bulb sockets and the bulbs themselves. It's all about ground and impedance, in most cases - isn't it?
Thanks for the tips,
Vladimir
Old 05-18-2012, 05:39 PM
catso's Avatar
catso
Vladimir
Corrosion is the E28's biggest enemy.
![/I][/FONT]
Old 05-18-2012, 05:49 PM
Mein Auto: '85 528e
I believe you, but why do you say that corrosion is the E28's enemy?
The simple crimping of wires exposed to the elements as in the turn signal sockets
and others I have seen did have me scratching my head - a tad skimpy, I thought.
Vladimir
HTML code is Off
