The X5 SAV Forum
Old 05-18-2012, 09:28 AM
afnnj1212 afnnj1212 is offline
Mein Auto: 2006 X5
Auxiliary Fan Replacement Cost
How much to replace 2006 X5 Auxiliary Fan?
Old 05-20-2012, 08:14 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Plan on $800 at a dealer, maybe $600 at an indy. Last time I checked, the fan alone was about $400. Bumper has to be removed to gain access to it.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 05-20-2012, 06:16 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
There is a guy doing OEM FANS on Ebay for about $250 at the moment.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 05-21-2012, 02:25 AM
chillycheung chillycheung is offline
Mein Auto: 05' X5 E53 3.0i
I just have mine replaced last week. The radiator and the pipe were replaced as well due to overheat. The indy charged me about $1000.
_______________________________________________
05' X5 3.0i
Old 05-29-2012, 06:20 PM
Siberiangroup Siberiangroup is offline
Mein Auto: X5 2002
Dealer will take 1K +part. I've got estimated for 1650$.
Ok, I bought AUX fan online for $357 , replaced in two days.
I don't have much time, spent about 4 hours a day, so, 8 total.
The worst part in a process- remove an install fan, it goes thru the buttom, that took most time.
It should be a guide on forum w/steps and picture. It saved me 1K+.
PS. Sorry for my english.
Sent from my PC36100 using Bimmer App
Old 05-31-2012, 12:15 PM
chris55552 chris55552 is offline
Mein Auto: BMW X5
Like you im in Louisiana and going through the same exact problem and replacement/repairs on this. I was wondering how hard it would be to replace this fan myself like you did. As you know when you pop the hood it appears to be accessible through the very front but does the fan connect through the backside closest to engine. Could really use some advice on this so thanks alot in advance
Old 06-01-2012, 05:29 PM
Mein Auto: X5 2002
http://www.bimmerfest.com/forums/sho...d.php?t=472548
Check this out, scroll down to link for picture.
Old 06-24-2012, 07:30 PM
bakker bakker is offline
Mein Auto: 2001 bmw x5 3.0i
I bought the part off Ebay for $174.99. And 3 hours of mine own time in the back yard a/c works great. Do ot your self its easy and you will save allot of money.
Sent from my Bimmer App
Old 07-09-2012, 02:55 PM
gerchik gerchik is offline
Mein Auto: 2003 BMW x5. 3.0
AC fan price and quality
HI everybody.
I am in the search for the AC fan. It is not working.
I was looking online and found a few on Ebay.
They are around $200 with a free shipping.
Do you know how good are they, any qulaity issues, fitment?
Old 07-09-2012, 08:56 PM
ylwjacket's Avatar
ylwjacket ylwjacket is offline
Refugee
Mein Auto: 2005 3.0
I can let you know about fitment this weekend, because I just ordered one. Hoping it gets here by Friday, and I can do it Saturday. Gonna be a big weekend for the X: Aux fan, oil housing gasket, new belts, new plugs, and valve cover gasket. Gonna be a swell weekend.
Old 07-10-2012, 08:13 AM
Thanks, please let us know how was it.
Old 07-10-2012, 08:52 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
If you replace the belts, you should do those pulleys also. Get the Vanos seals done too while you are at it.
http://www.beisansystems.com/
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 07-10-2012, 05:08 PM
ylwjacket's Avatar
Refugee
Mein Auto: 2005 3.0
Which pulleys - the idler and tensioners. Or all of them? How do know if they're bad? They seemed ok when I was in there last weekend.
Old 07-12-2012, 09:29 PM
ylwjacket's Avatar
Refugee
Mein Auto: 2005 3.0
Figment on the $200 fan is the same as the original.
It took about 45 minutes to take apart the bumper and unbolt the fan. Took maybe 20 minutes to get the old fan out through the bottom, and about 30-40 to put the new one in. About 25 minutes to bolt it in and put the bumper back in. So maybe 2.5 hours total. But, while I had the bumper off, I spent about 45 minutes repairing a dent in my left front 1/4 panel, where someone hit me in a parking deck. I was backed in, and they hit me right by the turn signal, so I pushed that dent out while I had access to it.
I checked, and the 2 fans were exactly the same size.
I ended up taking a razor knife and shaving a little off the top right front of the fan housing, to make it easier to get it in. Once the corner was in, the whole thing slid in ok. It was about 5 mm too wide, which was a real pita. So I sort of tapered some shavings on the corner, to get it started so it would slide in easier.
Hope that makes sense.
New fan works fine, and was under $200 (I paid 180 on eBay). Hopefully that replacement fan lasts awhile, but for now at least, it seems to work just fine.
Old 07-14-2012, 07:53 AM
infamous212 infamous212 is offline
Mein Auto: '04 BMW X5 4.4i, '05 G35
For the past few months, I've been wondering where this auxiliary fan is located and unable to locate it... definitely NOT in front of the radiator, like '03 and older... Can someone tell me where this AUX fan is located on '04 ~ '06 yr models??? I'd really appreciate!!!
'04 4.4i BSM/TB w/ spt & premium pkg, pan roof, navi.
'05 Infiniti G35
'00 e39 M5 (sold)
Old 07-14-2012, 10:37 AM
ylwjacket's Avatar
Refugee
Mein Auto: 2005 3.0
http://realoem.com/bmw/showparts.do?...87&hg=64&fg=55
http://tis.spaghetticoder.org/s/view.pl?1/05/74/35
It is right between the bumper and the radiator. It is the black fan right up front.
Old 08-09-2016, 08:44 PM
rbelton rbelton is offline
Mein Auto: E39
I have had good luck with the TYC brand on Amazon. Here's a complete DIY guide for the replacement, it's not that bad:
