Old 09-13-2016, 01:55 PM
JessicaBMW JessicaBMW is offline
Mein Auto: BMW 645CI
Low beam malfunction
2004 BMW 645CI
Need to know where to start to fix low beam malfunction issue. The problem started with passenger side halo stopped working, then driver side low beam stopped working then passenger side low beam stopped working. I replaced halo bulb and it's working again. I still have low beam malfunction issue but I am not sure what to replace, is it the ballast, ignitor, relay?? Also my high beams will only work if I hold the switch that turns them on and off, if I push switch forward they will not work. Any suggestions?
Old 09-13-2016, 02:09 PM
Ethansesar650i Ethansesar650i is offline
Mein Auto: 650i coupe
Message me
Old 09-13-2016, 02:51 PM
I sent msg.
Old 09-13-2016, 06:05 PM
Originally Posted by JessicaBMW View Post
I sent msg.
I sent you a message asking a few questions so then I can walk you through the process
Get back to me whenever you'd like
Old 09-13-2016, 06:59 PM
HerbP HerbP is offline
You will need to have your codes pulled by someone with the proper software. The codes will not cause a CEL light, but they will be there. Have you gotten any moisture in your lights recently? Is your green light flashing below your light switch?
Old 09-13-2016, 07:31 PM
Herb I don't believe the codes will tell her which component is actually bad
It will only say if it's low beam or whatever it may be
Old 09-13-2016, 08:17 PM
There are not any codes using a scanner for low beam malfunction. Low beam malfunction appears in my service info on the display when I start my car, and yes I did notice moisture on there, and the coating around the fiber optic part of the harness is no longer there and wires look brittle but not broken.
Last edited by JessicaBMW; 09-13-2016 at 08:22 PM. Reason: Need to answer a question
Old 09-13-2016, 08:23 PM
Correct, no codes for low beam malfunction.
Old 09-14-2016, 08:03 PM
You might as well purchase a new light if it is that bad. Mine shorted & burnt all of the insulation off of the wires. My fiber optic cables had very little coating left on them also. I had to purchase 3 modules & a light at the tune of around 1800.00. There are not any available internal parts available for our lights. I did get a new light for around 1300.00, which was a steal!
