Old 09-15-2012, 05:31 PM
umermariner umermariner is offline
Mein Auto: 2000 (E46 )328I
Actually, I also checked at the realoem.com... it is the part number 63126934836, and states "Electronics box ALC uncoded"... So seems like these models do not require coding..However, this part number says ended (no price), and the one below that parte # 63127189312 has the price of $147.35 for two modules. Not sure what that means. Does that mean the one that states Ended, was not used in my car, but the one that has the price was used in my car? Direct link is http://www.realoem.com/bmw/showparts...97&hg=63&fg=05
Old 04-04-2013, 04:18 PM
Boom335 Boom335 is offline
Boom335
Mein Auto: 335i XDrive
Did you get it fixed? Did you DIY or take it to a repair shop? I'm having the same problem on my 09 335 for the right headlamp. The headlight itself works but I keep getting the adaptive headlights warning.
Any recommendations for an Indy shop in Northern NJ/ NYC area?
Old 04-04-2013, 05:14 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
Try here for a shop
http://www.bimmershops.com/
Do you see any moisture in the light housing?
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 04-04-2013, 05:22 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
The LMA definitely needs to be coded to the car, it is one of the units that stores the VO (Vehicle Order) of your car. That is like the DNA, it contains a list of numbers that specify what options are fitted to your car, the CAS module is the other unit that stores the VO. The reason it is stored in two modules is for the case where one if these modules (CAS or LMA) fail, at least then there is a back up.
The reason a unit is listed as "uncoded" is because the unit is sold without pre-coding, ie it must be coded. A new unit must be coded with:
- VIN of your car
- VO of your car
- Specific coding configuration for your market
If you buy a used LMA then you have the additional tasks to do in order to make it work properly in your vehicle:
- Re-write VIN (I believe dealer software cannot do this)
- Update software version on module (potentially)
It would be a fluke if you fitted a second hand unit & it worked 100%, to top this off if you CAS module were to subsequently fail then you would be in all sorts of trouble. Other equipment not related to the CAS or LMA module may not work.
For the e63 there were numerous versions of the LMA fitted over the years. There are two things to consider
- LM1/LM2?
- Xenons/no Xenons
The LM1 unit was fitted to e6x up to about 03/07 built date, as mentioned there was more than one part number for the LM1, if your car had an LM1 & Xenons then any LM1 module that is suitable for Xenons (marked LWR) will work in your car
- LM2 (marked LM II) was fitted after 03/07, these LM/ units again had multiple part numbers as different revisions were released, all will work in cars either equipped with an LM1 or LM2 originally.
Check on www.realoem.com for the part numbers before you buy, there is always some a a available on EBay, in the photos you'll see a 7 digit part number on the module, Realoem.com lists the full 11 digit number, the 7 digit number is the last 7 digits of the 11 digit number.
To find a guide on how to code a new unit search out a guide written by Bruce Miranda on the bmwcoding forum. You need "BMW Standard Tools" to do it = NCS Expert, Tool32 & WinKFP.
I'm about to upgrade my LM1 to an LM2 in order to get the new features like, Angel Eyes as DRL, Welcome Lights & Cornering fogs, hence knowing the above. I'm gonna write my own more detailed guide based on Bruce's guide when I do the job.
Old 04-04-2013, 06:37 PM
roseng's Avatar
I had the same issue and it was not the LMA or the CAS modules, especially if it's only happening on one side.
I would look to the ALC (Adaptive Light Controller) or the SMC (Stepper Motor Controller).
The ALC is mounted on the bottom of the light housing and you have to remove the front bumper to get to it. I would guess it's that module.
If you have any moisture at all in the housing it can settle there and take out that module.
Old 04-08-2013, 12:24 AM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Alot of people just code out the Adaptive Function instead of taking the costly route of replacement. Different folks, different strokes though.
Old 11-27-2013, 12:02 PM
lebcardiag lebcardiag is offline
Mein Auto: F30
is there away to disable this warning from both the instrumental cluster and CIC using NCSexpert
Old 11-27-2013, 12:24 PM
There is definitely a way, however; my question is does it let the rest of the functionalities work as fine? Like self leveling (when you turn on the head lights, they are pointed lower, and then raise) etc...
Thanks.
Old 01-05-2014, 03:30 AM
64nickle 64nickle is offline
Young niga in aBeamercoup
Send a message via Yahoo to 64nickle
Mein Auto: 05 645ci BMW
Last week low beam out function came on I was told I need a control unit this week Adaptive Headlight malfunction i'm hoping is just the control unit that I need already looking forward to getting to fix already but if there something else I just might blow my car up
Old 01-05-2014, 03:39 AM
Originally Posted by sunnyice View Post
I called 2 Indy shops in my area and they both quoted around $700 for replacing the module! $300 is a really good price!
Word me too 700 and the dealer 2500 so 300$ is almost unreal
Old 01-10-2014, 07:49 PM
No more bull**** indey shops
I have a question my right low beam went out I took it to a indy shop, they told me I need a control unit module but the only thing is they haven't put my latch back on to prevent any water to get inside the lights or anything now all my wires are sticking out my tires ate all the wires up he said come tomorrow because I am very very upset can I sue him?
Now adaptive headlamps came on smh he owes me a whole new light Assembly
Old 01-10-2014, 10:57 PM
roseng's Avatar
Was this a BMW shop?
Old 01-25-2014, 02:36 PM
ttuite ttuite is offline
Mein Auto: 650I cabrio
Ok, I just want to make sure I am understanding this correctly. Low beam out. I had water in my headlight. Resealed headlight and fixed problem. Through swapping parts I found out it was the control module. Took it apart and it was burned up. Bought one off of Ebay and put it in. Headlight now works. Adaptive message is still present. My questions:
1. This was a used control module. Can BMW code it for me? What is a reasonable price for this service?
2. Is this something I can do myself if I buy the DIS software and cable?
3. Where is the best place to buy the software and cable? I am running Windows 7 64 bit on my PC.
Old 08-30-2015, 03:42 PM
j_luisito j_luisito is offline
Mein Auto: 2007 650i Convertible
Hi Guys,
I have a similar problem with both of my xenon adaptive headlights. Both are 100% out though. The computer says "left/right low beam malfunction".
Everything else works on the light assembly (angel eyes, high beams, etc.). I already replaced the bulbs and the ballast (light control unit mounted right below the headlight harness/assembly), on both sides to no avail.
The problem first started with flickering on one side (passenger). Then moved to right side and both. Now xenon lights 100% out, both sides.
Any insights as to what else I may look for? I though about replacing the ignitor as well (but both sides broken?). I think the issue might be something else and common to both sides.
and by the way, mine is a 2007 650i convertible....
Any help is appreciated.
Thank you.
-JLS
Old 08-31-2015, 12:00 PM
BadAzz650 BadAzz650 is offline
Mein Auto: 650i Convertible
guys I just went through this with my 650i convertible. I first replaced my control module which would solve the problem for a while, but the adaptive headlight indicator kept coming back on and going back off. Sometimes would come on and go right back off, sometimes stay on all day, etc. I brought it back to BMW service and apparently the condensation over time actually rusted the internal components inside the headlight itself and was making it inoperable. Result....Replaced the headlight. Through BMW as well, with no warranty, out of pocket about $2,000 w/ installation. I hope this is not the outcome for you! Needless to say.. works great now. I have also installed the LED halo's and now looks great!
Eric E
Old 10-25-2015, 02:44 AM
dave321 dave321 is offline
Mein Auto: E64
The problem I've got is I turn the lights on, they calibrate but don't turn with the car and I don't have a fault code coming up!! Any ideas?
Old 10-25-2015, 08:27 AM
HerbP HerbP is offline
You have a bad module on either the left or right side of the headlight. The modules will need to be tested with BMW Standard Tools.
This is the part number you will need. You might need 1 or both, depending on the diagnostics.
Control unit for Head Light
63 12 6 939 069
Old 10-25-2015, 09:33 AM
Mein Auto: E64
Thanks, would that not through up an fault though?
Old 10-25-2015, 07:09 PM
It probably would not show up on a generic code reader, but yes it would throw up a warning in the BMW diagnostic program. If your lights are not moving side to side, you are most likely getting an adaptive headlight warning on the cluster. Not knowing what year model you have, it is hard to say what type of warning you might have? If you have an 2004 to 2006, you most likely will see a flashing green light where you turn your lights on.
Old 10-26-2015, 03:18 PM
Mein Auto: E64
It's 2004 645Ci. No, don't have any warnings or flashing lights. Bulb was flickering today on passenger side then when off. Took hid ballast out to have a look and found the the build is stuck in it. Am I missing something, is there a specific way to get the bulb off the red and black Hid ballast?
Mein Auto: E64
Sorry, meant to sat that the bulb is stuck in!
Old 10-26-2015, 04:57 PM
You have to unscrew the black plastic collar to get the bulb out, after the ballast is removed.
Old 10-27-2015, 01:36 AM
Mein Auto: E64
Yeah, I can't seem to get the ballast off the bulb. As I turn thr ballast the bill turns with it and the black collar too
Old 10-27-2015, 01:50 PM
Rick D Rick D is offline
Mein Auto: 08 650I Convertible
Originally Posted by swood02 View Post
These things are not as simple as the sealed beams I had on my 1955 Chevy.
I dunno, pulling out those springs with a needle nose to hook on the retainer rings was always a pain for me............. LOL
Old 10-27-2015, 09:17 PM
The collar must come out, to get the bulb out. Here is a pic of where the bulb goes in, & the collar goes around. Not the best pic, but I hope it might help.
