6 Series DIY
6 Series Do It Yourself (DIY) forum. |
Had driver side headlamp go out on my 650I, found out it can be a bear, so added a few pictures to
help the next person out.. Pictures will detail sequence of removal and replacement of bulb, which will require removal of front tire,depending on which bulb you are replacing. Good Luck!!! |
awesome nice thanks for photos
SMG Premium Sound Sport / Cold / Comfort Access 19" OEM Logic 7 Premium Sound HD Radio Heads Up Display Park Distance Control K&N air filter Aluminum Racing Pedals 6000k headlight upgrade fog light upgarde 2010 MV AGUSTA F4 titanium/RED frame 2010 Audi Q5 S Line |
Great pics. Thanks.
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
Hi There,
I appreciate the response and am very happy it was found to be helpful..Luv the site and contribute every chance I get.. Enjoy!!!!! |
Thank you!! Just what I was looking for.
Sent from my PC36100 using Bimmer App |
Thanks for the heads up!!!!!!!!!!
No problem,glad it could help!!
Blanque47x,
Great pics, thanks. Which bulb did you end up buying (type and brand)? I need to know which type is the closest one to the one the car came with from manufacturer. Thanks. Jose Luis |
HI THERE,
PICKED IT UP FROM EBAY.. BMW Xenon headlight HID D2S BULB LIGHT LAMP SELLER WAS : factory_oem_xenon HOPE THAT HELPS.. |
Hey, just want to say thanks for this. Almost got raped at the dealer for $750 for R&I for 2 bulbs.
No problem....had same dealer issue..
Good luck!! |
i thought you had to remove the bumper? or is that for certain years?
live fast, drive faster 2005 BMW 645ci Coupe (daily driver) 2001 BMW z3 3.0i vert' (TOTALED RIP) 1991 NISSAN 300zx 2+2 (gave to brother) |
Hi..
I don't know about that,however I would not think that would be necessary for any year! |
Great thread, thanks! I am unfortunately in the need to replace my driver side xenon as it is turning pink.
What I don't understand is what you are saying about the removal of the front wheel, depending on which bulb you are replacing. Can you clarify this a little bit please? Also, approximately how long did it take you to do this? Thanks again! |
Hi There,
If the side marker bulb needs replacement,because of its angle, you may want to remove the tire to give you more area to work in..Speaking for myself, if it happens again, I will definitely remove tire.. Now as far as time, I would say give your self about 2 hrs, depending on how nimble or fat your fingers are.. My hand is big, so I had rough go at it... Blaque47x |
