X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
I am receiving the following errors on my 2004 BMW X3 3.0.
P0171, P0174, P0305, and P0313. I have reset the codes and they return the same errors. We have checked the intake areas for leaks by spraying with carburetor cleaner and no leaks detected. We have removed the oil cap and checked for suction. None noted. We have replaced the spark plugs. The symptoms are the car idles roughly. When accelerating, the car doesn't seem to accelerate, or stays in same gear, or kinda pulls back almost jerkedly, like driving over a washboard. When you depress accelerator to overcome this, it seems to pull out of it. Can someone suggest what to try next? |
Have you checked the cyclone separator also known as a CCV? It is the device under the intake that takes the oil and fumes recycles the oil back through the dip stick and fumes into the engine to be burned. If this is plugged it will cause a lot of issues.
Check you intake, pull the throttle body and look inside with a flash light to see if oil is laying in the bottom. Best suggest I can provide at the moment... |
This explanation from a 3 series forum makes sense to me: http://forums.bimmerforums.com/forum...88&postcount=7 As you have ruled out an obvious vacuum leak, other than looking for a less obvious one, it does sound as though you might have to go down the oil separator road. |
I would pull out the DISA valve and check that. That threw a code on my x3. Check if the flap is broken and, if it moves freely, it needs replacing.
It's always a good thing to post the car's mileage, gives a better idea on what else could be going on.
I would assume, by the year that has over 100,000 miles. Have you replaced the fuel filter? A clogged filter will cause some hesitation, but I would rule out fuel pump first. (You'll need some equipment to test this) But it sounds to me, looking at the codes and your description, like a fuel starvation issue. As said above CCV will cause a lot of strange behavior on these cars, but I'd rule out fuel issues first.
"If everything seems under control, you're just not going fast enough" -Mario Andretti. ___________________ River City Bimmers Chapter 2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta. 1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black. Last edited by X3-terrestrial; 05-21-2012 at 06:40 AM. |
| Tags |
| cylinder misfire, p0171, p0174, p0305 |
