The X5 SAV Forum
Old 05-21-2012, 07:57 AM
kiao kiao is offline
Mein Auto: 2004 X5; 2004 330cic
2004 X5- wont start (EWS / DME issue)
Hi,
I will start by highlighting I am mechanically incompetent and in need of some help.
Car details:
2004 X5 4.4
65K miles
Bought from dealer 6 months ago- no prior issues
Went to start car and no crank in ignition. No clicks, no sound, no nothing- just dead. All lights / electronics worked however car would not turnover and display showed "engine failure / transmission failure" errors. Thought it was battery so jumped start- no success. Tried spare key-nope. Ended up having it towed to my mechanic.
Mechanic thought it was starter motor / battery so replaced and said it was fine (i.e. car started). I went to pick it up and exactly the same issue- no start, errors but electronics working. Mechanic re-examined and diagnosed EWS and another module which they ordered and replaced. This still didn't work. After 2 weeks they said they think it is the DME which needs to be replaced / re-reprogrammed by dealer.
I have taken it to BMW and they are examining but wondering if anyone has any advice or experienced this. If it is DME, how much should it cost- o i need it replaced or reprogrammed???
THANKS SO MUCH
PS> I have trawled through the site but cant find the exact issue
Old 05-26-2012, 09:34 PM
williamX5 williamX5 is offline
Mein Auto: 01 540i/6 & 04 X5 4.4L
Originally Posted by kiao View Post
Hi,
Car details:
2004 X5 4.4
65K miles
THANKS SO MUCH
Good day,
If I had my guess, it is the ignition switch contacts that direct power to the EWS. There will usually be something else that won't work as a lot of functions work off one set of contacts. This happened to me with my 98 540i and it took me some time to figure out the power was not getting to the EWS at all, but everything else worked... Oh, I do remember that my steering wheel position function (arm below the turn signals) did not work when the EWS was also not working... I had to turn the ignition on and off repeatedly before It would work... It happened to me twice before I took out the contact assy from the steering column and cleaned the contacts... I never purchased a replacement and sold the car a few months ago with it still working... Oh, I had my 540i for about eight years and did all the work it needed... I did everything from fluid changes to replacing the timing chains and guides...
I just got my 2002 X5 4.4 (if my wife doesn't make it hers) and I love it... It would be better if they had them (4.4L) with the six speed that was in my 540i, but the auto hasn't disappointed me yet...
Good luck and let us know what you find out please!
Thanks much!!
Cheers!!
Old 05-28-2012, 01:17 PM
Below is the reply from the dealer.. doesn't sounds promising. Seems to me they are not sure and may just be hoping its DME... anyone have any views / thoughts as $2K is a sizey investment for an 04...I'm using Brahman Miami for what it counts.
"We found that the DME has corrosion from water. We need to replace the DME. There could be something else wrong but this what needs to be done now. The cost to replace the DME plus the time already invested would bring the total to $2108.00 plus tax.""
Old 05-29-2012, 07:33 AM
Good day!
I'm not going to automatically say the dealership is wrong, but the practice of troubleshooting and diagnosing a problem goes little beyone hooking up the computer and plucking & chucking the most probable cause... Very rarely do mechanics break out the volt meter to find positive 12v where it should be and the opposite in some cases... That is how I determined my ignition was bad when I had the same symptoms you have now...
On the other hand, my good friend has an 07 Mini... When he came to me and said the remote doesn't work, I inquired when did it start... "After I left the sunroof open in the rain and it got the mirror wet." I pulled apart the mirror and found corrosion on the circuitry for the remote receiver... I cleaned it up, hooked it back up and it worked... It took me an extra half hour to pull the mirror apart than to just replace it with a $343 new one... I got an apple pie and a six pack of Pepsi for my efforts... WIN-WIN!!
I don't know if you can make them check the voltage out of the ignition, but I would try... That is an $80 part (if I'm looking at the parts correctly) compared to the replacement for the DME...
Good luck!!
Cheers!!
Old 06-01-2012, 09:23 AM
ECU Doctors ECU Doctors is offline
Account Under Review
Mein Auto: BMW
Sounds like your DME might be bad, or your new EWS wasn't programmed correctly.
You say that there has been times when the car didn't crank. Then I heard you say that after your mechanic worked on the car, he found a way to start the car again.
Sound like your DME could be loosing the synchronization with the EWS, or vice verse.
Ask your mechanic if he has tried to do an EWS to DME Alignment to get the car to start.
If this is true, have the mechanic reprogram the EWS and test the car for a few days. (I have instructions on how to to this.)
Otherwise you will need to replace your DME, which is not a big deal.
Old 06-08-2012, 07:33 AM
Another update in this saga. The dealer finally got the new DME, and installed it. Now he is saying that the Mechatronics need to be replaced (the EGS control unit in the transmission).
I have no idea on the legitimacy here- he mentioned a voltage issue. This unit apparently costs $3,200, so with DME and labor the cost for repair is $5,815 plus tax..Advice helpful!!
Also, anyone know of any recourse? I bought the vehicle from the dealer, but its an '04 an no warranty. Im guessing i have none but is there a lemon law or similar for used cars? Its been in the shop for 2 of the 5 months Ive owned it.
Are my options really either paying the repair or defaulting on my financing payments? I'm happy for them to take back the car and lose my deposit..
Old 06-08-2012, 03:43 PM
Good day!!
Have them swap out the ignition and if that doesn't fix it, send me the bill...
Cheers!!
Old 08-02-2012, 10:05 AM
Just thought i'd provide an update on this. After changing the Mechatronics still had same issue. Ended up the DME the dealer first installed was a dud. After replacing the DME again all up and running and so far so good.
Total bill= $6300. Luckily i was able to claim it on my insurance so only cost me $500 out of pocket.
Old 01-23-2013, 03:23 PM
330dm3 330dm3 is offline
Mein Auto: 330d
Hi sorry to bring up old thread but It's totally relevant and unfortunately we don't halve a erm land rover section I also have a td4 that wouldn't start so I replaced the ews and realigned it then car starts for a day or so then loses alignment so i fit new battery aligned it again and I drove home. Just gone to go out and it's lost sync again!!! Any ideas Why they lose sync it's costing me 50 per resync!!! It still cranks when it.doesnt start and it's an auto.
Old 01-23-2013, 08:02 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
I thought if the EWS was not in synch with the DME the engine wouldn't even crank? Once the EWS is synch with the DME it remains synch until you replace the DME or replace the EWS. Sound like you have another problem.
Old 02-27-2015, 01:28 AM
1SRS7886X5 1SRS7886X5 is offline
EMPR"X5"ARIO
Mein Auto: e53 X5 4.4i
Very true i just bypassed my ews and ignition turned engine for first time in 8 days of trouble shooting ignition drum and switch, relays, fuses, fuel filter, fuel pump, battery, cps and everything possibly related to no crank no start symptoms!
Fyi,
1). I disconnected battery for overnight charge
2). I believe in process of unplugging relays looking for faulty ones the dme and ews became affected breaking the synching not authorizing us to start our ultimate driving machine.
3). After 8 days of reading and researching the net while tearing my e53 4.4i apart, realized that this was the best decision for this all too common, complicated epidemic.
"cut and connect the two thicker wires from ews and the ones from ews box as well and you will love to listen to the wonderful sound of your engine thru the exhaust when you turn the once failing ignition switch." p.s. Thank you lord for always answering prayers !
Old 07-08-2015, 09:16 AM
x5 Beast x5 Beast is offline
Mein Auto: x5 4.4
Does this actually work? My x5 is at the shop and I'm told it'll take two weeks to get the new ews from Germany. The BMW cranks but won't fire. Shop was able to recode to start it but falls out of synch the next time you try to start it. Does this bypass actually work? Can't be without my car for two weeks? Let me know if anyone has had success with this. Greatly appreciated.
2004 x5 4.4 160,000km
Old 07-08-2015, 06:34 PM
EMPR"X5"ARIO
No crank no start X5 4.4i
I also tried all remedies under the basic common sense trouble shooting starting with battery, fuses, ignition switch, fuel pump and many hours of bimmerfest knowledgeable feedback and YouTube do it yourself remedies, Where I came across the EWS bypass remedie that actually worked. However keep in mind that there are many similar symptoms that are closely related that sound and feel like they could possibly be the problem. Playing the elimination process of possible problems yourself instead of paying someone to play the guessing game will save you a lot of money and finally help you to get to know your X5 and appreciate It as it deserves.
Old 07-08-2015, 06:38 PM
EMPR"X5"ARIO
You won't be able to use keyless entry. But he Beast will run again you choose !
Old 07-10-2015, 07:26 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Why can't you use keyless entry? FZV (central locking system) & DWA (anti-theft alarm siren system) are 2 different systems than EWS. They don't even operate on the same radio frequency nor use the same components to get to their control modules.
EWS operates on a 125 KHz AM radio frequency and the transmission of that signal goes from the EWS control module to the Ring Antenna (around the ignition) which powers up the EWS transponder inside the key. The key's transponder then sends the EWS's ISN (individual serial number) back to the EWS control module...and if the ISN matches the same ISN coded into the EWS control module and DME/ECU...the car will start.
The keyless entry system is related to central locking FZV (and DWA works in conjunction here). And that occurs when you press the remote key's button...it sends either a 315 MHz (US/Can/Aus) signal or 433 MHz (Europe and most other markets) RF signal to the aerial in the tail gate spoiler...which then sends that data to the FZV receiver (also in or near the spoiler)...which then sends that data to the GM. The GM is the control module for FZV & DWA...and this is where data is sent to the central locking system to lock/unlock the vehicle...and to the DWA system to arm/disarm the vehicle.
Just because EWS was bypassed...I'm not sure why you've lost the ability for remote keyless entry unless FZV & DWA are waiting for a signal from EWS that the key has been recognized as "good"...thus it waits for that signal to lock/unlock & arm/disarm the vehicle.
Have you tried reinitializing your remote keys? And you're sure there are no other issues with your central locking and alarm siren systems? I ask the latter because that will prevent remote FZV/DWA from occurring.
Q {BMW CCA Member #191509}
(SOLD)
dme, ews, wont start, x5
